Easy Crochet Pumpkin
1,823
46
10
About: Have been called a "Mad Genius" of Interior Design. Love a challenge, especially upcycling trash. Have more ideas/day than Trump has lawsuits. Diagnosed with Parkinson's 6 years ago. The body goes to hell...
Crochet Pumpkin
Cooler weather brings out the nesting instinct in many of us. And nothing says nesting like starting some crochet projects. And if you're going to crochet, why not embrace the season and make some pumpkins. These are quick, easy and can be used in a multiple of ways. Even if you're a beginner, if you can do a single crochet, you can make these.
Step 1: Materials
Yarn of your choice. (for this 'ible' I used what I had on hand). Orange and green.
Crochet hook of choice. I'm using a 'K', or 6.5mm for this project, more for the sake of speed. A smaller hook will make a tighter stitch.
Row marker (a paper clip or bobby pin will work)
Yarn needle
Polyfil (or stuffing of your choice)
Step 2: Make Your Pumpkin Body
With the orange yarn, start by chaining 3. Slip stitch the ends together to form a small circle. Do 10 single crochet (SC) through the center of the hole. This creates your base. Inert your row marker to help you keep track.
Row 1: Do 2 SC in each stitch in the row.
Row 2: Do 1 SC in the first stitch, then 2 SC in the next. Repeat this pattern for the remainder of the row. (keep moving your row marker)
Row 3: in the first 2 stitches, do 1 SC. In the 3rd stitch do 2 SC. Repeat for the rest of the row. Your circle should be between 3-4".
Rows 4-11: SC in each stitch. This builds up the sides of your pumpkin. Move your marker
Rows 11-14: Time to decrease. SC in first 2 stitches, then either skip a stitch, or bring your yarn through the next 2 stitches (so you'll have 3 loops on your hook) and pull your yarn through all 3 loops. This will give you a neater, tighter look.
At this point you should just have a small hole left at the top of the body. Tie off but leave at least 24" of tail. You'll use this to create your sections.
Step 3: Stuff and Section
Using your filling, stuff your body. Don't over stuff because it will make it more difficult to create the pumpkin's sections. Thread the yarn through the yarn needle and sew closed the top. To create the sections, bring the needle straight down through the center of the body, out the bottom and down through the top again. Pull tight. This is one section. You can repeat for as many sections as you like. 6-8 sections look best on a pumpkin this size. Tie off tightly when complete.
Step 4: Create Your Stem/Curl and Assemble
Using your green yarn, chain 12. Turn your work and do 4-5 SC in each stitch. This will create the curl effect. Tie off and leave a long enough tail to tie to the top of your pumpkin. Tie it on and your done!
Step 5: Uses
It's very easy to change the size of your basic pumpkin and it has many uses. Add a wire spiral to the top for a place holder for a party. Add heavy duty magnets and arrange on your door (providing it's metal) as a wreath. Add hangers and put anywhere, or just pile high in a bowl and enjoy!
If you have pets, (especially cats), you'll find these make excellent toys as well. (Consider yourself warned). These are also machine washable on the delicate cycle in cold water.
Hope this 'ible' gave you a warm fuzzy :)
Step 6:
Made with Yarn Contest 2016
Third Prize in the
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    10 Discussions
    Kittenfluff
    2 years ago
    I did it. I liked a straight stem on it better.
    indywave
    2 years ago
    I made these last year!!! My mom loves them!!!
    16, 3:22 PM.jpg
    christa627
    2 years ago
    I've seen a similar pattern somewhere online, but it just had a straight stem instead of a curly vine. I really like these, they are such cute fall decorations! You can crochet some other veggies (I've seen patterns for corn and eggplant) and a cornucopia and use it as a Thanksgiving decoration :-). We did that, but now the toddlers always want to use the cone as a hat! :-O
    Katjarichardschrista627
    Reply 2 years ago
    I've done other veggies, but none have turned out as cute as these. Thanks for the comment!
