Easy Hogographic Projector
Here is an easy way to make simple holographic projector for smart mobile phone.
I was inspired by the work of mikroGanesh and made this simple and modified projector.
Step 1: You Need:
1> Transparent sheet
2> Cardboard/thick paper
3> Smart Phone
4> drawing tools like ruler, drawing compass, pen etc.
5> Glue and cello tape
Step 2: Make a Square Pyramid Using the Transparent Sheet
Draw the template on a transparent sheet ( follow the below video instruction). It is the template of a square pyramid of base side length 7cm consisting of only 4 sidewall w/o base. Cut it using a scissor along the outer line. Fold along the 3 folded line. After three fold the pyramid will be completed. Stick the two end edges using a cello tape. The template is such that the top apex was cut to give it a flat top.
Step 3: CardBoad Base
Have a square 7cm x 7cm cardboard and cut it like X
Step 4: Glue the Pyramid With Base
Glue the Pyramid upside down with the base
Step 5: Place It on Top of Smart Phone to See the Holographic Video
download some holographic video from youtube and place the pyramid as shown. There will be 4 images. Each lateral side of the pyramid should face to each image.
Step 6: Enjoy the Hologram
Increase the brightness of the phone screen, dim the light and enjoy the 3D holographic image/video from side.
Step 7: Step by Step Video Instruction
Step 8: For More Project Watch
    • Pie Contest
      Pie Contest
    • Pocket Sized Contest
    • Paper Contest
      Paper Contest
    5 Discussions
    BenJ8
    3 years ago on Introduction
    Thanks for sharing! It works like you said and the stand helps with stability. Very cool!
