Easy LED Light
Color changing LED decorative light
-Small mason jar
-Decorative marbles
-RGB LED submersible light (which can be found here)
-Drill w/ hole saw
-Hot glue gun
Step 1: Drilling
Drill a hole in the top of the mason jar big enough for the light to fit through. I would recommend to use a hole saw attachment. I didn't have the right attachment on hand so mine is pretty bad.
Step 2: Hot Gluing
Only hot glue the top part of the LED to the lid. Make sure that the bottom part is still twistable or else the light won't work. Seal any holes with caulking or hot glue so water won't leak.
Step 3: Finishing Up
Pour decorative marbles into the jar. Add marbles as desired. Fill with water once your done pouring marbles. Screw on the lid and watch it light up! :D
    • Paper Contest
      Paper Contest
    • Epilog X Contest
      Epilog X Contest
    • Warm and Fuzzy Contest
    4 Discussions
    mach1950
    1 year ago
    Can I ask why you add water? Does it change the appearance of teh light?
    nwwoolsey01mach1950
    Reply 1 year ago
    Yes the water reflects the light better, makes it shine brighter, and makes cool reflections on walls.
