Easy LED Trunk Light Upgrade
4,030
56
6
My new electric car (a BMW i3 REX) is chock full of cool technology, but it has one of the most anemic trunk lights I've seen in a while. I decided to upgrade it by adding a strip of warm white LEDs to the underside of the package shelf that covers the cargo area.
What you'll need:
Waterproof LED strip ( I used a warm white strip); The waterproof versions are top coated with a clear silicone that will help protect the LEDs if something in the trunk bumps them.
https://www.amazon.com/gp/product/B01339F5ZO/ref=o...
Molding tape - used to secure the LEDs to the underside of the shelf (I would not rely on the strip's own adhesive)
https://www.amazon.com/3M-03614-Scotch-Mount-Moldi...
Quick tap wire splices - makes it easy to connect to power and eliminates the need to solder connector to the car
https://www.amazon.com/Quick-Splice-Connector-22-1...
Polarized connector - I already had one (salvaged from a 12V light), but they're available online:
https://www.amazon.com/Sea-Dog-Polarized-Connector...
Wire
Soldering iron, heatshrink tubing, misc small hand tools
About an hour of time
Supplies:
Step 1: Power Up!
The current truck light pops out easily and can be removed from the power connector (first pic). I spliced into the light's wires using self-tapping splices https://www.amazon.com/Quick-Splice-Connector-22-1...
Step 2: A Little Light, Please
After trimming the waterproof LED strip to length, I soldered on a length of 2 conductor wire and covered the connection with heatshrink tubing. Next, I used 3M body molding (https://www.amazon.com/3M-03614-Scotch-Mount-Moldi...) tape to stick the LED strip to the underside of the package shelf, and more tape to secure the wire along the side of the shelf. I did this during the fall - we'll see if it holds up once summer temps start hitting the 90s.
Step 3: Connecting to the Trunk Light Circuit
After reinstalling the package shelf, I used a 12 VDC polarized connector so that the shelf can be removed for more cargo space. After recconnecting the wires to the "old" light, I reinserted it.
Step 4: Finished!
Here are the after & before pics. The new light makes a huge difference when accessing the trunk when I leave for work (always in the dark). Total time was < 1 hour.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    6 Discussions
    Pib2
    1 year ago
    Neat, this could even be solar powered!
    OrestisRPib2
    Reply 1 year ago
    everything could be solar powered.
    wkparkerOrestisR
    Reply 1 year ago
    Perhaps, but I think I'll let them work out the kinks in the solar-powered trans-Pacific airliners before I book a ticket. :-)
    wkparkerPib2
    Reply 1 year ago
    In a way, it is. A portion of my electricity comes from renewable sources, including solar, so some of that is going into the battery when I charge it
    sdwilliams58
    1 year ago
    Thanks! Nice instructable. You can use this project in several ways around your car/truck.
    wkparkersdwilliams58
    Reply 1 year ago
    Thanks for the comment. I'm planning to do the same thing for the front trunk ("frunk"), which doesn't have a light. Probably my next 'ible!
