Easy One Piece of Paper CD/DVD Case
971
16
4
Hello! Have you ever had a CD/DVD that is just laying around without a case and your afraid it will get scratched or damaged and then be found expendaple? In this Instructable I will be explaining how to make a simple CD/DVD case out of only one piece of 8 1/2 by 11 sheet of printer paper! This CD/DVD case will save you the time and trouble of going out and buying those expensive plastic cases!
Step 1: Gathering the Materials
The only materials you will need are a standard CD or DVD and one sheet of 8 1/2 by 11 printer paper. Really that's all you need!!!
Step 2: First Folds
First, place your CD/DVD at the top about halfway off the paper as seen in the picture above.
Step 3: The Folding Continues
Next, fold both sides in toward the center and make a crease going down.
Step 4: Only a Few More Folds
Now fold the paper and CD/DVD down the length of the CD. The images above shows this.
Step 5: Two More Folds Then You're Done!
Then take the top left and right corners and fold them down to make triangles.
Step 6: Fold Down and You Are Done
Finally, fold the top down to where you can tuck the tip you made in step 5 in with the CD/DVD. Once this is completed you have now finished your paper CD/DVD case!
Step 7: Enjoy Saftey for Your CD/DVD
I hope you had an enjoyable and easy time making this paper case for your CD/DVD. Feel free to post in the comments how yours turned out.
    • Paper Contest
      Paper Contest
    • Organization Contest
    • Weaving Challenge
      Weaving Challenge
    4 Discussions
    I made one of these as well. I suggest putting your cd in the same way I did in my instructible, it will close more nicely. https://www.instructables.com/id/Nearly-free-CDDVD-case/
    Hey zork the destroyer, appreciate the feedback. The only difficulty I found with having the CD on the inside was it was difficult to insert and remove the CD when you need to use it.
