Easy Pallet Coffee Table
5,009
126
13
Hi, in this instructables, I will show you how I made my pallets coffee table.
You will need:
1 or 2 pallets.
1 beam (~200 cm).
Wood glue.
1 compressed wood plate.
Clamps.
Miter saw.
Circular saw.
Think safety first! Use gloves and protection glasses to avoid injury!
Step 1: Find Pallets and Cut Them Down.
Find pallets and cut them down.
Depending of the size you want your table to be, you can go faster by cutting pallet's plank with the circular saw like on the drawing, cut on the red line(only small planks needed and this way you will not have nail holes). Keep at least 2 long planks for the side.
Cut the planks at 45° to do the patern on the table like on the second drawing.
For the center planks, you can cut them like an arrow.
Send all your planks.
Step 2: Glue the Planks
Try your planks on the compressed wood plate before glueing them. Some planks will fit better with one rather than an other.
Glue the planks to the compressed wood plate. You can clamp a second plate on top of it to apply a pressure on all the table at the same time.
Step 3: Cut the Overflow
When glued, remove the second compressed wood plate.
Flip the table and cut the overflow.
I have used a compressed wood plate the size I wanted the table so it was easy to cut the planks.
Step 4: Cut and Glue the Legs
Cut the legs in a beam. Be sure to have a perfect cut to avoid table swing when finished. Sand them.
Glue the legs on the bottom of the table, on the corners to be ras.
Step 5: Glue the Sides
Cut the sides at perfect lenght. You can cut at 45° for a better finish.
Glue them to planks and legs.
Step 6: Enjoy Coffee
Enjoy coffee on your new pallets wood coffee table.
My table is not vernished, I like the raw wood.
Thanks for reading and do not hesitate if you have any notes.
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    13 Discussions
    LaurentP21dudus
    Reply 4 months ago
    Thank you! Still using it everyday, 2 years after creation :-)
    mollux
    2 years ago
    That's a beautiful way to make a coffee table top! I'm wondering about the legs though, are they secure enough just glued on like that? Wouldn't they need some sort of bracing? I'm not sure, I'm just asking.
    LaurentP21mollux
    Reply 2 years ago
    Think you! It is super strong. I can sit on, there's no problem. Glued surface is quite big. 8cmx8cm for the top and it is also glued on the side plank. Forgot to say it in the instructables but, put heavy weight (did it with 2 sand bags of 25kg each ) on the table for 24h when gluing the legs.
    I used pattex wood glue : https://images-na.ssl-images-amazon.com/images/I/51fvzoQ-4-L._SY355_.jpg
    eyeguy6
    2 years ago
    Your design is great, but your how to is lacking a ton of info.
    LaurentP21eyeguy6
    Reply 2 years ago
    I have added information and drawings. Do not hesitate to say what you don't understand.
    LaurentP21eyeguy6
    Reply 2 years ago
    Thank you for your feedback. English is not my first language and it is not easy to have the good words.
    I will try to add some more informations.
    LaurentP21ClenseYourPallet
    Reply 2 years ago
    Thank you. It is easy to made and way more beautifull than lines parallel to sides.
