Easy-Peasy CD Sleevesey
18,513
24
12
About: I'm a professional video game programmer.
Make a double CD/DVD sleeve from an ordinary sheet of paper. No cutting required!
Supplies:
Step 1: Materials
Get a blank sheet of letter sized (regular) paper (other sizes like A4 may work).
I used some scrap paper from my printer.
Also, get a CD or DVD.
Step 2: Place the CD
Place the CD/DVD in the center of the paper, and about 2/3rds of the way up.
(After a few tries, you'll be able to judge the right spot more easily).
Step 3: Fold # 1
Using the CD/DVD as a guide, fold the bottom of the paper over the CD as shown.
You can make a loose fold then remove the CD to make a better fold.
Make sure this fold is straight!
Note: The more accurate and firm your folds are, the better this will work.
Step 4: Fold # 2
Now fold one of the sides behind as shown. Again, use the CD/DVD as a guide of where to fold and make the fold straight.
Step 5: Fold # 3
Repeat this process for the other side, and it should look like this.
Step 6: "The Tuck"
Turn the sleeve over and grab the two folds you just made, then tuck one inside the other as shown.
Step 7: Position Is Strength
This sleeve holds 2 CD/DVDs, but if you are using just one, place it in the side with the tuck to prevent the sleeve from coming undone.
Congratulations! You've recycled some scrap paper into something useful.
The next step shows a variation of the sleeve.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    12 Discussions
    guitarmonk15nitrox027
    Easy-Peasy CD Sleevesy, Easy-Peasy CD Sleevesy, Easy-Peasy CD Sleevesy, Easy-Peasy CD Sleevesy, Easy-Peasy CD Sleevesy. Beat That!
    emmjul
    11 years ago on Introduction
    If you punsh two holes in the top you can collect them in a folder. I like it
    sharath
    13 years ago
    A nice & simple project. I tried it & it worked. One little suggestion: Make sure that all the folds are neat & firm.
    CameronSS
    I burned a LOT of DVDs that I made for my church's 50th anniversary. I put a couple in jewel cases before I ran out. I put ten in store-bought sleeves before they ran out. Finally, I put twenty-one in these paper sleeves, using a discarded legal pad. Great, simple system. I like.
    OniLinkSword
    12 years ago
    LoL. I used to do this all the time when I was trying to protect a CD I was given or I didn't have a case at the time. Nice to see I wasn't the only one that had this idea. _
    bluelion
    13 years ago
    no cutting, and no glue ... I modified it for one cd/dvd with a bigger "margin" and leaving the "tucked" folds to the back of the cd.... this covers most of the cd leaving .5" visible at the top
    bluelion
    13 years ago
    use a bone folder or a plastic ruler over the folds...
