Easy T-Shirt Sketching
55,630
430
87
Using a bleach pen you can create a rad shirt in about 15 minutes!
Step 1: Supplies!
You will require:
A t-shirt or other cloth material
A bleach pen
A magazine/cardboard/plastic bag
A water source
Step 2: Insert Protective Lining
Insert your magazine/cardboard/plastic bag inside of the shirt. Smooth the shirt down if you want a flat drawing surface. Wrinkle it up if you want to try some funky effects!
Step 3: Draw!
Shake and squirt a little bit of bleach onto a scrap piece of paper to test for consistency. This will help you get the hang of drawing with the pen before trying it out on your fabric. Check to see how thick your lines are.
Draw! I just freestyled a griffin head, but you can use chalk to lay down a pattern first for more control. Anything you draw on the shirt will leech a little bit and your lines will be about twice as thick as what you draw.
Watch your fabric. It begins to whiten almost right away. I let this one sit for about ten minutes before moving on to the next step.
If you plan on drawing a big pattern plan to do it in batches. Draw, move onto the next step, and come back to draw some more later. Otherwise parts of your lines will not have the same lightness. You can always come back and do more, but you can't undo anything once it is done.
Step 4: Wash
Carefully remove the paper/cardboard/plastic lining from inside the shirt and quickly place your garment under running water. The bleach will be kind of thick so you need to scrub a bit to get it all off quickly. Gloves are a good idea here.
Wring out the shirt and rinse again to make sure all the bleach is gone.
Step 5: Let Dry
Flop your shirt over a bar or put it in the dryer. Then you are ready to wear it!
Since I didn't leave my bleach on for a super long time my lines are a light brown. If I want to make them lighter I can retrace the linework and bleach again. I can also keep adding onto the image again whenever I want or have friends draw on it.
Adding embroidery, buttons, and appliques could be really fun accents to add after the shirt is done drying. Using this technique, which I think looks like reversed batik, you could make some really awesome fabrics to sew with, or curtains, etc.
First Prize in the
Craft Skills Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    87 Discussions
    CrystalDyes
    10 years ago on Step 4
    Please consider using a product called Anti-Chlor to neutralize the bleach after rinsing as water does not stop the action of bleach by itself. This product can be obtained from www.prochemical.com. I have no affiliation with this company other than sending them lots of money over the years to support my dyeing habit! I'm a very satisfied customer.
    booboo39466goosezilla
    Reply 9 years ago on Step 4
    Actually vinegar also contains the neutralizing power plus its a whole lot cheaper.
    I don't think that would be a very safe option.... I'm pretty sure if you mix bleach and vinegar it creates chlorine gas...
    amado maricris
    8 years ago on Step 5
    I am really trying to make a perfect shirt design and apply it perfectly. Thank you for the tips..If i cant make one il show it here...
    Supersyko
    10 years ago on Introduction
    AWESOME, You inspired me to make my own!!! Since im too cheap to buy a bleach pen, im using a high lighter and dipping it in watered down bleach! I wanted to use your design, but 1, i wanted mine to be unique, and 2 im not that good of an artist, im using a phoenix! Im gonna make an instructable like yours using my way, if its ok, ya know, no copyright or something, lol.
    jianqiang
    awesome, I tried this like 7 years ago but with a spraybottle and bleach.......my cardboard stencil quickly died......>.< and it ended up a stinky mess and me out a hoodie
    Bard
    Here is my Bleach experiment I used an airbrush. (SAFTY NOTE: I also used a respirator and goggles. I kept the design simple as being my first try.
    nabzafcasey321b
    i did mine with a stencil and paint brush. you don't was the shirt first it will make put'n on the stencil a lot better www.myspace.com/hoodie_o_productions in the pic section is a pic with me and my hoodie
    goosezillacasey321b
    Sounds like it is worth experimenting with! Try it on some scrap fabric first. I have a feeling the lines you draw will be fairly thick because the fabric may soak up the liquid bleach too much, but try it out and let me know what your results were like. I love to know about new techniques!
    MadMax001
    Hi again...This is my second attempt with this method ..!
    I made a small "booboo" on the shoulder ( The bleach bled..) ..but that gave me an idea to make flames for next time..!!
    I guess it's all in the learning process..LOL
    Have fun..and as you can see you don't need to be an awesome artist to transform a t-shirt..Give it a try !!!
    4113n
    10 years ago on Step 5
    What is a bleach pen? Can i fill a used up high lighter with bleech or something?
