Easy Table Saw Sled
71,097
420
19
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
A table saw sled (or cross cut sled) makes cutting wood against the grain safer, and much easier. There are lots of technical ways to approach making a table saw sled, but sometimes you just need a simple and elegant solution to a problem. This is possibly the easiest cross cutting sled you can make, and it still achieves accurate cuts.
Cross cutting sleds (in case you didn't know) are used to cut against the grain of wood on a table saw, or cut very small pieces without fear of chopping your fingers off. Cross cutting (or mitre cuts) is a topic that is covered on the free Table Saw Class, which will bring you from zero to hero on being a table saw pro.
This cross cut sled can be made with scraps and only requires three cuts to be precise, the rest can be slapped together with reckless abandon and sill make perpendicular cuts. At the end of the Instructable we'll use the 5-cut method to check the accuracy of the sled once it's created.
Ready to get cross cutting? Let's make!
Step 1: Tools + Supplies
This table saw sled uses scrap wood, relying on a few precise cuts and a very straight piece of hardwood. Here's what you'll need to make your own:
The calipers are essential to get an accurate measurement of your table saw mitre track. You'll also need a solid tri-square to align the sled fence to the blade, which is what will determine if your cuts are square or not.
Before making any cuts make sure your table saw is calibrated, otherwise every cut you make will be off. Table saw calibration is covered extensively in theTable Saw Class.
Step 2: Measure Mitre Track
Almost all table saws have a standard mitre track dimension of 0.75" wide x 0.375" deep. Before making any cuts it's best to check to determine your mitre track dimensions.
Digital calipers have 4 measurement points: exterior dimensions (the large jaws that go outside an item to be measured), interior dimensions (the smaller jaws that go inside an item to be measured - located above the larger jaws), depth gauge (a probe that extends out the end), and an exterior depth gauge (the hammerhead front of the calipers and the inside jaw of the moveable side - example).
Use the interior measure to check the width of your mitre track, and then use the depth gauge to see how deep the track is.
Step 3: Cut Track
Set the table saw fence to the track width dimension and make a rip cut on your straight hardwood scrap. Next, set the fence to the mitre depth and run the cut hardwood through again.
We're using a hardwood like oak here as it's a very dense and durable wood that's not prone to warping. Using this as our track will allow the sled to glide smooth and not get stuck in the mitre track.
Step 4: Clean Up
Before checking your cut it's wise to clean up your table saw surface and mitre track of any sawdust or debris. If you neglect this step you're not going to get an accurate assessment if your cut fits snugly in the track.
Step 5: Test Fit Track
Place the cut hardwood into the mitre track to test the fit. Try pushing the hardwood along the track and see if it sticks anywhere, then try wiggling the hardwood laterally against the track to see how much slop or play there is.
You're looking for a snug fit, with no play, and a smooth glide. If you're getting caught up anywhere check the track to make sure there's no debris, then try sanding sections of the hardwood to get the correct fit. If all else fails you can always remeasure and rip another piece of hardwood until you get the proper fit.
Step 6: Plywood Sled Base
With the track cut we can make the base of the sled. The greatest thing about this style of sled is that your sled base doesn't need to be perfectly square at all.
I used a scrap piece of ¼" plywood that had very uneven edges - perfect for this application!
This plywood base will sit on top of the track and be the bottom of the sled. Since it's only serving as a platform and no measurements will be made from it, there's no need for it to be anything other than a flat surface we can cut through.
Step 7: Glue Base to Track
Insert the hardwood into the mitre track.
Apply a small bead of glue on the hardwood along the length making sure not to use too much or accidentally spill any glue onto the table saw. You only need a small amount of glue, since we'll be adding screws to attach the hardwood to the plywood later.
Once glue is applied place the plywood on top of the hardwood track, aligning the plywood so it's approximately square to the track and the center of the plywood is in line with the saw blade.
Add weight to the plywood over the glue and allow the glue to dry overnight before moving.
Step 8: Secure Track
once the glue has dried slide the glued assembly out of the miter track and flip the plywood over.
Drill pilot holes along the hardwood length and countersink each drilled opening. Hand screw fasteners in each opening to mechanically secure the hardwood to the plywood. The glue and screw combination will ensure the two parts are mated securely.
It's important to countersink the openings so the screw heads are inset from the hardwood track surface, thereby not hindering any movement when the sled is in the track.
Hand sand any burrs or rough spots from drilling.
Step 9: Glue Sled Front Fence
The sled front fence (the part furthest away from you when operating the sled) does not need to be accurate, since it's only job is to keep the structure of the sled once we cut the kerf in the plywood.
I used scrap wood glued along the front edge of the plywood, only making sure that the scrap wood was reasonably square so that the surface would glue correctly to the plywood.
Step 10: Cut Partial Kerf
Before gluing on the sled back fence, which needs to be square to the blade, we'll need to make a reference cut. The back fence needs to be perpendicular to the saw blade and perfectly square to make accurate cuts.
With your saw de-energized remove the insert and remove the riving knife, then place the insert back over the blade and lower the blade completely into the table. We'll be bringing the blade up through the plywood base to create a reference cut which we'll align the back fence to.
Place the sled into the mitre track and place the plywood directly over the lowered blade. Start the saw and slowly raise the blade until it's about 1" higher than the surface of your plywood base, steadying the plywood with your other hand (away from the blade) as needed to prevent the plywood from wandering during the cut.
Kerf is the material that is removed when cutting and it's equal to the thickness of the blade, this is described in more detail in the Table Saw Class.
Turn off saw and de-energize for the next steps.
Step 11: Select Wood for Sled Back
The sled back fence is the only other piece of wood that needs to be precise for this sled. This back fence will be where you align your wood to be cut in reference to the saw blade, so it needs to be square and perpendicular to the blade.
Use the tri-square to ensure your wood choice is completely square and straight. Like the front fence, the back fence wood should be as long as your sled is wide.
Step 12: Glue Sled Back
With the saw de-energized and the blade extended up through the plywood, place the tri-square against the face of the blade. Know that the saw teeth are slightly wider than the face of the saw, so make sure your tri-square misses the teeth and sits flush against the blade face.
With the tri-square flush against the blade align your square back fence to the perpendicular arm of the tri-square to locate it 90° to the blade.
Apply a small bead of glue to the back fence and place on the plywood. This is the most critical part of the entire sled, as misalignment here will result in every cut made on the sled being at an angle. Take the time to ensure your back fence is totally perpendicular to the saw blade.
Step 13: Examine
Reposition the tri-square on either side of the blade to check the back fence for squareness.
When satisfied the back fence is aligned perpendicular to the saw allow the glue to dry overnight before moving.
Like with the hardwood track, after the glue has dried you can flip over the sled and drill and countersink openings to attach the back fence with screws.
When the back fence is secured, raise the blade up about ½" higher than the surface of the plywood and run the sled through the blade completely. your sled is functionally complete!
Now, how do we know it's accurate?
Step 14: Check Accuracy (5-cut Method)
To check the accuracy of the sled we'll use the 5-cut method, cutting a piece of scrap 5 times, rotating after each cut, to see the deviation from perpendicular.
By making multiple subsequent cuts on the same piece of wood, the resulting 5th cut will have magnified the error and show us our deviation.
Start with a rectangular scrap piece of wood and label each side 1-4 counterclockwise. This scrap piece doesn't need to be square to begin with, the 5-cut method can handle any scrap piece of any shape.
Place side 4 against the back fence and line side marked 1 with the saw blade, move the sled forward through the blade to make a cut along side 1 removing a small amount of material. Move the sled back and rotate the scrap piece clockwise so that side 1 is now against the fence and side 2 is lined up to be cut. Repeat this process for all 4 sides until you are back to side 1 at the saw blade.
After cutting all 4 sides make one final cut along side 1 again, this time make the cut of a decent size. The off-cut here will be the piece we measure to see the sled accuracy.
Step 15: Measure 5-Cut
If your back fence of the sled is perfectly perpendicular to the blade there there will be no deviation of measurement between the top and bottom of the 5th cut.
Use calipers to measure either end of the off-cut and write down the readings.
One end reads 0.512" and the other 0.575", a difference of 0.05" (50 thou) or 1.5mm. This is less than 1/16" compounded along 4 sides of my roughly 1'x1' scrap piece.
How accurate you want your sled to be is up to you. If you want more precision then you'll need to make minor adjustments to the back fence and redo the 5-cut method to check your adjustments.
Before going too far down the rabbit hole of accuracy I caution you to think about a few things.
Sled capacity
The 5-cut method is taking advantage of compounding the error with each successive cut, so the error you read on the 5th cut is not the same as a single pass.
Also, think about the capacity of your standard sled cut, it's probably not going to be a long cut, but a short cross grain cut. How much deviation is there going to be when your cut is 1" rather than my sample piece which is 4 cuts along a 1' length.
Being Realistic
Are you cutting wood that requires a level of precision reserved for a high tolerance space shuttle, or are you a hobbyist with a need to make fairly accurate cross cuts. This is a homemade sled to make cross cuts, further refinements can always be made later through trimming or sanding. Don't sweat the small stuff.
Step 16: Cross Cut
This table saw sled is simple to make, cuts accurately, and can easily be made in an afternoon.
What I'm showing is only a very basic start, table saw sleds can be customized with all kinds of clamps, tracks, and hold-downs to suit your needs. Once you make one sled there's no limit to the types of additions you can make, why not make a few and have sleds on hand for every specific cross cut you make!
Though this sled is simply made, it's wise to treat it like any precision tool and not just toss it around. You've spent the time to calibrate the fence and track to take care of your sled and you'll have it around for years to come.
Happy making!
Have you made your own simple cross cutting sled?I want to see it!
Share a picture of your cross cut sled in the comments below and get a free Pro Membership!
6 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
19 Discussions
JosephS354
6 months ago on Step 7
If you've ripped your track so there is space under it per my comment on #5... here you'll need to put some pennies or washers under it to raise is up so you can glue the plywood. But don't use yellow glue (takes too long to set up) - use either CA glue ("superglue") or a strip of narrow double-sided tape. That way you can install your screws in just a cpl minutes and keep moving on!
JosephS354
6 months ago on Step 5
This step (#5) - you'll have much better luck with your track if you orient the grain of the wood to run vertically (up-down) instead of horizontally (side-side) as shown here. Wood expands/contract with the grain.. it's better to have it expanding down into the track instead of binding up (or getting loose) side-side in the slot.
Secondly - if your track is 3/8" deep - rip your track so there will be some space under it for sawdust and expansion. I make mine 5/16" thick. Then, use pennies or a few washers under it to raise it slightly proud of the saw table for gluing to the plywood.
irvinmt
10 months ago
great instructions. i used the plans with some modifications to make my own sled. i have not had a chance to try it out on a project, but initial cuts look good!
pbesong
1 year ago
great instructable. i just made one. I like the idea of adding plexiglass to the top. i'll do that when i can get a small piece. this was the first thing i made since i upgraded my old 70's Craftsman 113 table saw with a new Delta T3 fence. hoping to do lots of projects now that I have this. thanks for posting!
pbesongpbesong
Reply 1 year ago
forgot to mention that instead of using a guage to measure the width and depth of the miter guage channel, I used the miter gauge itself to move the fence to the correct width for both cuts by placing it between the blade and fence. worked pretty well. you have to be careful cutting the depth since there wasn't much to push with at that point.
Nuonaton
2 years ago
If you put a strip of plexi/acrylic across the top in line with the blade, You add a degree of safety by creating not only a splinter deflector, but also a physical barrier to keep your hands away. (Seems common sense, But I've seen people hurt themselves when they were distracted. Hunger, tired, work, stress, all equal a distraction) I used clear plastic from a large toy package as my cover. It works perfectly, But it does prevent taller pieces from going in, so making it removable is key.
MelEdge
2 years ago
I built a similar sled and quickly realized that I needed to put a block of wood where the blade exits the sled to enclose the exiting saw blade to prevent ever having my thumbs in the path of the blade. I also put a piece of Plexiglas from the front to the rear fence above the blade to prevent anything flying off the blade from hitting be in the face, and also to prevent my fingers from getting too close to the blade path.
mikeasaurusMelEdge
Reply 2 years ago
Clever additions to your sled. Do you have pictures of your sled? Maybe you can share your build process as an Instructable?
MelEdgemikeasaurus
Reply 2 years ago
Here is a photo of my sled with the features I added for safety. I also added a hold down clamp and an adjustable stop to use when the cut length is longer that the front fence. When I am holding small pieces to cut with my fingers I hold them tightly up against the plastic shield over the blade which prevents them from getting in the blade path. However, usually I will use the hold down as seen in the photo
fdc313MelEdge
Reply 2 years ago
Nice blade safety feature I will be adding this to my sled.
TK Trooper
2 years ago
Can i ask why you only attached one track guide to the sled when there are 2 tracks visible on your table saw? Was this intential? To save time, is not essential or is there another practical reason?
I plan on making one of my own. Cheers.
mikeasaurusTK Trooper
Reply 2 years ago
Using both mitre tracks doubles the chance of the sled binding in the slot. You only need one track to keep the sled parallel to the blade and cutting accurately.
TK Troopermikeasaurus
Reply 2 years ago
Cheers, i thought it was something to do with functionality, just wasn't quite sure what. Thanks for replying and thanks for the instructable
labdude
2 years ago
Nice work!
I'd like to add that most calipers have a fourth mode of measure - called "step". The left edge of the jaws are ground coplanar to each other at 'zero'. If you place the caliper such that the left edge of the fixed jaw is square to your reference surface, you can measure the height of a feature with the edge of the moving jaw. You could, for example, measure the depth of your miter slots this way. The depth rod is good for inside depth, the 'step' is good for outside measurement.
mikeasauruslabdude
Reply 2 years ago
Today I learned something new!
Thanks for sharing this. I investigated my calipers after reading this comment and tried it out, and it's another very accurate way to measure the mitre track depth.
Here's an image that shows what labdude is talking about.
wetrat1
2 years ago
Your Instructable made sense. The next one I make will be like yours. I made a sled a few years ago. It has been used for a lot of different projects including for making frames.
LeeG87
2 years ago
I am confused about the cross-cut terminology. The pictures show cutting with the grain of the wood if I am not mistaken.
mikeasaurusLeeG87
Reply 2 years ago
Though primarily used for cross-grain cutting, a sled is a great way to secure smaller pieces of wood to make cuts on the table saw without fear of cutting your finger off :)
Epimethius
2 years ago
Excellent way to make the sled. I will do this. Also learned the 5-cut method for testing squareness.
Excellent video editing. Complete and concise, no wasted time.
Improvements I will try:
- give relief paths for the sawdust, chamfer the base of the blocks
- find some way to micro-adjust the squareness of the base block before permanent fastening.
