Easy Micro Camera Shots
12,082
34
11
Easy micro camera shots (or at least how I do them)
Hello, tis your old windbag Osgeld here spreading a easy way to do micro shots!
I started this the week before I moved, I found instructables in this apartment, and it seemed somewhat fitting to do one last one before I boxed up my gear,
Basically I am shoving my radio shack magnifying glass in front of my old freebie digital camera.
The results are quite decent when you want to get a really close up shot of something... which can be really handy for certain situations, like, oh maybe, instructables
Step 1: Gear
Magnifying Glass:
I have a radio shack pocket style one that has 5x, 10x and 15x lenses. I picked it up at my local shack on clearance for 5 bucks, or they sell them online for 9
http://www.radioshack.com/family/index.jsp?categoryId=2032311
Digital Camera with LCD and a manual / macro mode:
Mine is a old Toshiba PDRM500, it was given to my wife a few years ago from her dad and it was quite old then. Its 2 mega pixels, and last time I had it battery powered it sucked down 4 cheap gas station AA batteries in 6 or 7 shots.
You don't need a great camera, I use this one in all the closeup shots and it does fine (even if it is tethered to the wall)
And something to take a closeup of:
In this case, some qfp telephone chip on a pcb from a digital answering machine I still have yet to scavenge
Step 2: Camera Setup
The Following step should be about the same for any half way recent digital camera, but please consult your owners manual for detailed instructions for your specific make and model
Set your camera into manual mode:
On most cameras its just a simple matter of turning the wheel on top to the icon of a camera with a M beside it. You can use automatic mode (no M beside the camera) but it might be difficult to get a good shot.
Set your focus to macro mode:
Once in manual mode, look through the menu and find out how to change your focus from automatic, to macro mode.
On both mine and my wifes (much nicer and newer GE) camera, they just had to be set in manual mode then push the menu button. Once in the menu I just selected focus and set it to macro
Finally Zoom all the way out:
You will not be able to use the camera's built in optical zoom much if any at first, so zoom it all the way out
Step 3: Shot Setup
You want to hold the magnifying glass directly over the camera lens, you want the center of both lenses over each other
Get close, watching the lcd until you get a good clear image of the item you want
Steady your hands, here I have my elbows propped up on my legs, then my hands are propped on the edge of the table.
Adjust the magnifying lens and your hands one final time, watching the lcd for the clearest image of the subject
Hold down the shutter button half way, let the camera adjust its focus, my camera flashes a green box on the screen when its got it (and a annoying chirpy noise). If all looks good on the lcd continue pushing down the shutter button to take the picture
Step 4: Check Results
It is very important to go ahead and check every shot you take right after you take it. It is very easy to slight move something while holding the camera and magnifying glass AND pushing a button
You can tell pretty quickly if you need to take another or not. If your image looks good on the first go, most cameras let you zoom in while your viewing the image, do so and make sure you got what you want.
If everything is okay, move on to the next shot and enjoy!
Questions or comments please let me know!
Step 5: More Result Images
The first 3 are from pimp my pong
The last one was one of the few pictures I saved when I first started to play with this. It is an image of a single strand from a floppy drive ribbon cable, with a solid core wire
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    11 Discussions
    KraZe_EyE
    8 years ago on Introduction
    Hey just checked out your VCR jog wheel. Really cool.
    But I did something like this with a scavenged photo copier lens. I have a 1.5 in one and a 1/2 in one. I can use the small one with my camera phone, just line it up and hold flat against the phone body. I haven't tried using the large one with a digital camera, I mostly use it as a loup. Nice write ups, keep it up!
    AndyGadget
    10 years ago on Introduction
    If you're using manual mode you should also set the aperture to minimum (smallest 'F' stop) to give you maximum depth of field so more of the picture is in focus. Get plenty of light on the area too to allow a fast shutter speed and reduce shake.
    rimar2000AndyGadget
    Yes, it is. But the increase in the depth of field is at the expense of sharpness. Sometimes it is appropriate one thing, sometimes another. Each case must be analyzed individually.
    jarvistrimar2000
    This is not true. Small aperture (at least up to F11) --> sharper picture. For prime lenses, this continues till you start to see diffraction effects at around F200 (i.e. a pinhole camera). Zoom lenses (i.e. all digital cameras) are a bit more complicated. You should almost invariably be shutting down below the widest aperture of the lens, which is where the lens performs worst (particularly with softness in the corners at wide-angles, vignetting with telephotos). Maybe you're confusing this effect with either long shutter --> motion blur, pixel noise (digital sensor), or the autofocus failing to have sufficient light to focus sharply?
    rimar2000jarvist
    No, I am not confused. If you have a larger aperture, you have more light from the subject to form each pixel of the photo. The edge diffraction is always present, and it is more perceptible when the diaphragm is littler (greater F). This is valid specially for good quality lenses.
    But I agree with you that for practical purposes is usually preferable to sacrifice a little sharpness (it is almost imperceptible) towards the depth of field. So I added "Sometimes it is appropriate one thing, sometimes another. Each case must be analyzed individually."
    jarvistrimar2000
    The majority of 'softness' (i.e. lack of resolution) in a lens comes from imperfections, most notably spherical aberration (due to lens elements being constructed in a spherical shape as an approximation to the parabolic ideal lens) and chromatic aberration (due to different wavelengths of light, colours, being refracted by different amounts by the same optical element - the prism effect). Expensive lenses have better features (such as aspheric elements, better coatings, higher refractive index glasses, etc.) which lessen these effects.
    In this case, with using a close-up filter or a simple magnifying glass, you've got an enormous imperfect element ruining all these compensating factors.
    Spherical aberration is reduced at smaller apertures as the lens area closest to the core of the optics is closest to the parabolic ideal. Chromatic aberration is where most of the clever lens design goes into - with strange reflective coatings and compensating elements introduced. But again, generally I understand that the lens is most effective in suppressing it within the parallax approximation when the light rays are closest to the origin.
    You're quite right about diffraction being present always, but the effect is proportional to the F-number (in fact, the Rayleigh criterion resolving distance x=1.22 x (Wavelength Light) x (F-stop)). It is irrelevant while the size of these Airy disks is less than the sensor / film grain size. I believe for a compact camera with a small sensor this is around F11 and above.
    Fundamentally, the lens manufacturers are fully aware of the diffraction limit, which generally gives the upper F-number for a given lens, which is why compact cameras (with small sensors) generally can't stop down below F8 or F11.
    The Wikipedia article is really quite good:
    http://en.wikipedia.org/wiki/Spherical_aberration
    Spherical Abberation "...is proportional to the fourth power of the diameter and inversely proportional to the third power of the focal length, so it is much more pronounced at short focal ratios, i.e., "fast" lenses."
    The Airy Disk article is the most 'photographic' friendly article on Wikipedia on the subject of Diffraction:
    http://en.wikipedia.org/wiki/Airy_Disk
    Stop down a few notches and I promise your images will be sharper, the wide open apertures are only there for when you need the most light possible.
    rimar2000jarvist
    You knows the matter.
    I mentioned the effect of the diffraction on littler diaphragms because I learned this in 1962-63 when I studied some optic. That effect is dramatically perceived when one look through a telescope: the stars looks as points, much smaller than one can see they at naked eyes. Obviously, I am saying a good telescope, with 8 inches o more aperture, and excellent lenses.
    I will see that Wikipedia articles, they seems very interesting.
    Put a common cheap lens in front the cam's objective and I promise your macro images will be sharper. You can see the result also in my instructable https://www.instructables.com/id/How-to-take-clear-pictures-for-Instructables-with-/
    Thanks for your comment, and pardon my "automatic translator" English.
    AndyGadgetAndyGadget
    That was ambiguous (if not totally incorrect).
    The smallest aperture is the highest F stop.
    So it should be set to F8 or F11 or rather than F2.8, F4 or F5.6.
    (And I agree with Jarvist about the sharpness.)
    hg341
    cool i did this before i saw this a few days ago with a 35mm film viewer7x
    my camara is at 6x for all pic with the 7x 35mm film view
    the first and 2nt are my of my eye the last is a 1mm wide cut on a wood table
    jstrickland
    You're doing macro shots not micro. Micro-photography is done through a microscope. Macro photography is close up photography, which is what you are doing.
