Easy Stealth Footswitch / Pedal to Minimize Windows and Show Desktop
13,192
38
24
About: Hi there, member since long time ago, don't have many instructables, but happy to browse around.
I spend most of the time at a computer programming, and in a matter of no time I end with all my screen real state filled with windows. Also, most of the time my feet are very lazy, so I took the idea I saw somewhere to do a very easy and cheap foot pedal to hide / unhide all the windows by using my feet.
Also, I had a lot of friends that would like to hide all the IM and youtube screens when the boss passes by, so maybe this will help =P
Most of the modern computer keyboards don't use the "Scrll Lock" (or Bloq Despl in spanish) for anything, so we will use this key to trigger the hiding function in windows.
I hope you have fun doing it as I had fun making it.
BTW, I was a member like for 4 years now, but this is my very first instructable.
Thank you!! and please have a look at my blog for extra pics: my blog
UPDATE: Just to be clear, this instructable is not about hacking your actual keyboard, but hacking and attaching an extra one to your regular computer, so you end using your regular keyboard and also this hacked one, both at the same time. Have fun!
Step 1: The Parts
1) An unused old keyboard - for the keys functionality (I had A LOT of unused keyboards at home)
2) A multimeter - not a must, but it really helps to check everything OK
3) An arcade switch - this will be the switch on the pedal
4) An unused cardboard box - I had several unused boxes from AMD processors, U can use one of these boxes
5) A soldering iron
6) A dremel tool
7) Some cable, about 6 ft.
8) The AutoHotKey free windows application that you can find here: http://www.autohotkey.com/download/
Step 2: Unscrewing the Keyboard and Finding the "Scroll Lock" Key
A keyboard works by closing a circuit between 2 plastic layers; when you press a key, the 2 layers get in contact and a current flow between this connection, sending a signal to the microcontroller inside the keyboard.
1) You will have to disassemble the keyboard. Remove all the screws you might find in the back, and release the back cover.
2) Then, remove the thin plastic layers thar are inside the keyboard.
3) then, put the cover on the back and turn the keyboard facing up, to put the layers over the keys to write with a permanent marker where the keys are, one for the upper layer, and one for the bottom layer.
Step 3: Finding Which Pins Works for Our Key
Then, you will have to find wich two pins on the microcontroller are the ones to be pressed together to close the circuit and send the key code to the computer, so:
1) Take the upper plastic layer (it's glued to the bottom layer, you can use a Xacto knife to cut the small glue spot that puts the 2 layers together.
2) Put one of the multimeter probes at the brown spot, and then put the other probe in the first of the circuit track endings
3) Get the resistance reading in the multimeter (the one with the OHM symbol on it) , if you don't get any reading, move the probe to the next pin in the track endings, until you got some reading.
If you don't have a multimeter don't worry, just follow the track until the ends, just don't get lost because of the tiny lines =P
Once you find where the key ends, do the same procedure for the bottom layer of the keyboard
Step 4: Soldering the Cables in the Keyboard Microcontroller
Ok, so now that we know which pins (or track endings) are the ones for our key, we have to solder some cable in the keyboard circuit.
Before soldering the cables, use the dremel tool to remove the black material over the tracks in the circuit, this will help the solder to stick to the circuit.
I will solder cables for the "Ctrl", "Alt", "Right arrow", "Left arrow" and "Scroll Lock" because I'm using this circuit for another project in the near future. But U just need to solder the cables for the scroll lock keys.
Step 5: Making the Foot Switch / Pedal
Then, you have to install the arcade switch in some kind of support. I used an old AMD processor cardboard box, very sturdy and lightweight.
1) Cut a hole in the box
2) Remove the black switch of the button and screw down the yellow casing
3) Tighten the yellow button with the plastic black nut
4) Solder cable to the ends of the switch
5) Attach the switch again to the arcade button and close the box
Step 6: Solder the Foot Switch to the Keyboard Microcontroller
Solder the two arcade switch cable endings to the soldered cables in the microcontroller, this way every time you press the button, the circuit will short, "pressing" the Scroll Lock key.
I used another old nokia cellphone box to keep the brains of the circuit to be used later in future projects.
Step 7: Programming the Scroll Lock Key to Hide All the Windows
So far, the foot switch only presses the scroll lock key, which is kind of useless. We need a freeware program called AutoHotKey to tell the computer to minimize all when we press the key. This program has a lot of functionality (sadly, only under windows and not in Linux), but we will use just the basics. If you want more information you can read the embedded help.
So:
1) Download the program from http://www.autohotkey.com/download/ download the "Install AutoHotKey" option.
2) Install the program, it's pretty straightforward
3) Then we have to program the code in a text file called minimize.ahk , you can find the file for downlad below, but in case you want an explanation of the code, here you have:
SetScrollLockState, AlwaysOff ------------ this will turn off the scroll lock LED light
ScrollLock:: --------- if you press the Scroll Lock key, the function will minimize all the windows
WinMinimizeAll
return
+ScrollLock:: -------- if you pres the Scroll Lock key, while holding the Shift key, all the windows will return to the screen
WinMinimizeAllUndo
return
You can download the file below, and save it inside the AutoHotkey folder in you computer.
Step 8: Load the File Automatically
Then, we have to load the file everytime windows starts, so you have to add a shortcut inside the "Startup" folder under the "Programs" tab at the "Start" button under Windows XP
Just drag the shortcut to the "Startup" submenu under "Programs"...
Step 9: The Video of the Pedal
I guess you can see the video here:
http://www.youtube.com/watch?v=vB0eY56Yr0U
Step 10: Done!! Start Hiding Your Windows!!! =P
Then connect you fabulous pedal to your computer, I used a PS2 to USB adapter, so don't need to reboot anything.
Once you reboot (or load the script by right clicking in the AutoHotKey icon in the taskbar) you will be able to hide ALL the windows with just the press of a pedal!!!
And, if you press the pedal while holding the shift key, all the windows will be restored.
Well, this is a very quick computer MOD, you can use another kind of pedals, or a nicer box, but the idea is to kep it very simple.
This is my first instructable, so please let me know what you think about it!!!
THANK YOU!!!
P.S. I have a video with the pedal working, but I don't know how to upload the videos, any help?
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    24 Discussions
    bbear4
    7 years ago on Step 4
    Love it!
    And just mentioning the other project, I had to go check that one out too! I started working on this and got frustrated trying to find the two pins to close the gap for the keys I needed. I didn't think of using a multimeter rather than trial and error with a keyboard button test. It was a cool program though. It'll highlight the keys you press on an on-screen keyboard so you know if they are working. I don't remember its name but a google search will find it along with multitudinous others and might come in handy for someone reading this.
    Now that you've shown me a better way to isolate the keys I need, I'm going to make a similar switch.
    TY
    eliastorrebbear4
    Reply 7 years ago on Step 4
    Hey thanks to you for your comment!
    Good luck with you project, hope this instructable helps you. Let me know if you need something else.
    ¡Cheers!
    Tubehacker01
    9 years ago on Step 7
    Yeah, that's exactly what I got.
    However, I made this work by simply replacing ''+ScrollLock with Pause. It works perfectly now, so I'm more than happy.
    I'm currently running win 7, maybe this has something to do with it...
    Tubehacker01
    Hey! That file doesn't work, it only minimizes and doesn't undo :( Any ideas why?
    GREAT INSTRUCTABLE +++++
    eliastorreTubehacker01
    Reply 9 years ago on Step 7
    Hi!
    mmm I'm not sure why it is not working, do you have this on the file?
    ScrollLock::
    WinMinimizeAll
    return
    +ScrollLock::
    WinMinimizeAllUndo
    return
    Just delete the dashes, keep the code and let me know
    daneframe
    9 years ago on Step 3
    I've hacked Keyboards before, and usually use a Sharpie to trace the contacts, but this method of finding the correct pins saves a LOT of time and frustration. Thanks for the post! :)
    darklucifer
    10 years ago on Introduction
    would it not be better to have it trigger the computer to "lock" instead of minimizing windows?, or perhaps minimize the windows and then lock?
    eliastorredarklucifer
    But I guess the idea is to look as if you were actually working =P a locked screen looks more suspicious hehe
    thanks for comment!
    kwah
    Just a quick note that a Windows version of AutoHotKey is available (I currently have it installed in XP) - if anything, I think that you have gotten this wrong way around:
    ""This program is very powerful (sadly, only under linux) and has a lot of functionality, but we will use just the basics. If you want more information you can read the embedded help.""
    That is in step 7 and to my knowledge, this is a Windows-only program that can be run under linux with WINE (it stands for Wine Is Not an Emulator) but due to the way that WINE works, AHK has only very limited 'power' - something to do with WINE acting similarly to a sandbox I think but I would advise that you look into that yourself if you're interested.
    Anyhow, the point is that AutoHotKey is NOT linux-only.
    Other that that minor correction and a couple of doubts re: bringing hardware into the workplace from home (that's not generally isn't commonplace.. is it?), its a Cool first Instructable =]
    Keep up the good work!
    -- Kwah
    eliastorrekwah
    Awww, you're right!! I dunno why I put that comment about linux, actually autohotkey is only under Windows, my mistake. I will update that ASAP.
    Didn't get ur last comment about bringing the hardware =P
    Thanks for ur comment!
    kwaheliastorre
    I didn't read/understand this 100% in depth but from what I can remember reading you are going to modify a keyboard and then plug modified keyboard (with a foot pedal attatched) that into the computer. If you are going to use it at work then you've either got to modify your work's keyboard or bring one in from home.<br/><br/>If its like most offices I've heard / read about, something like this would be frowned upon at least a little (health & safety etc).. It might be worth noting that I'm in the UK.<br/><br/>{....}<br/><br/>I've just skimmed through again and it seems I might have miunderstood slightly - the instructable is for creating a foot pedal that is completely seperate to the keyboard? <br/>I imagined that you were going to short out the path from the scroll lock key to the controller using the foot switch but it seems that you were proposing to build something seperate from the keyboard that has its own USB port - effectively making the computer think that it has two keyboards attached to it?<br/><br/>Meh, maybe I'm wrong here too but my excuse is that I only skimmed through =P<br/><br/>Happy hacking<br/>
    eliastorrekwah
    Yeah, your'e right about the second tought, this instructable is about hacking an extra keyboard, so yes, te computer thinks it has 2 keyboards connected at the same time. I have A LOT of old unused keyboards, I thouhgt this would be a nice end to them. Thanks again for reading!
    berky93
    lol I was just going to use the autohotkey script and modify it a bit to change what keypress hides all windows (and not bother with the foot switch, since I have a laptop and dont usually even have my feet on the gound) but then i read the comment about windows + d useful! still this is a great instructable
    pyrogoth
    i would just like to say that you dont even need to bother with the auto hot key script at all, al ud need to do is find the "win:" and the "D" keys, and u could make a dual switch to press both or you could get one of those switches that are specifically made to be connected to two things at once and u only need to push 1 button, just an idea its a small bit of extra work but its worth it incase some1 pushes the scroll lock while playing a game or something other wise there would b no use to haveing the switch because some1 could just push the scroll key but all in all a good instructable
    eliastorrepyrogoth
    Yeah, you're right. But the idea behind this was to show another use for both the feet and a almost-dead key. And keep the hardware as simple as possible, like with this one switch button.
    You can see other approach in the other instructable, where key combinations are used. For this specific instructable I tried to keep the hardware as simple and affordable possible, also this kind of arcade buttons are very sturdy, so it can withstand the stress under your feet.
    Thanks for your comment!
    SeanJay
    10 years ago on Step 1
    Hey so doing this for my pre-IB personal project dont have a dremel tool is theyr anyway of doing this without it ??
    eliastorreSeanJay
    Reply 10 years ago on Step 1
    Hi there! Don't worry, the dremel is just to make the work easier. You can use regular sandpaper to clean the tracks of the keyboard microcontroller. Ask for a sandpaper sheet at your local hardware shop. The sandpaper roughness is measured by a number, a bigger number, like 500, means smaller grains and a small number, like 10, means bigger grain. So, ask for a #500 sandpaper and use it to remove the black coating of the tracks. Or just ask for a soft sandpaper, and be careful to remove the black coating but not the copper layer. Hope this help you! Let me know, and thanks for watching!
    Guy.Fawkes
    10 years ago on Step 8
    "add a shortcut inside the "Star" folder under the "Programs" tab at the "Start" button under Windows XP" On the English versions of Windows, the folder name is "Startup."
