Economic One-board Desk for CNC or Jigsaw
22,070
422
19
About: I really like building things on my own, so I want to share some stuff!
Hello everyone! This is my entry for the „Flat Pack Contest“ on Instructable, in which interesting designs all about cool stuff which come from a board or panel of a random material are presented. Of course, many other objects and applications fall in this category.
DISCLAIMER: Be save around tools, especially around power tools. Wear protective gear where needed. You MAY NOT use these files I've provided for commercial use.
Who are you?
My name is Andrew and I am an Austrian mechanical engineering student from Graz (23 y.o.). But I like to make tangible stuff too. Working with wood or aluminum, electronics or 3D-printed stuff are exactly my thing. Also, sorry for my English skills. :D
Step 1: Considerations
What is your thing?
A very neat but simple thing I came across making was a desk for my home. There were some problems with off-the-shelf desks. I had some wishes, and so, I decided to make it CNC milled, here is why:
· I needed a generally higher desk (about 75 cm or 29 ½ inch) since I am a tall person
· A nice, sturdy desk which is able to be taken apart is awesome in case the desk has to be moved.
· Low part count
· Easy and quick feasibility on the CNC mill
· Only one board of material
The last three reasons are because of the cost of this desk. Long-winded assignments for the carpenter’s CNC mill are very costly, since the operating hours are more expensive than the material itself. If you have more than one board of wood, the cost will explode (student speaking) since they have to take the time to put another board on the mill for your job. It’s only a desk after all.
So, out of what did you make it exactly?
My design is milled on one 17 mm “multiplex” board which is 2,5 m by 1,25 m
It is designed to be put together without (almost any) tools and then, if needed, to be taken apart with completely no tools at all.
What’s so special about it?
For me, the greatest thing about this desk is the file. I sent an E-Mail to my favorite carpenter with the Autocad-file attached and asked, if it is feasible with the materials and the machine he has. You will know that after a few weeks, you get a table ready to be popped together at home.
For manufacturing many more of these desks, all you need is to order in the number of desks you want to make in boards. Also you will know that every desk is assembled quickly and is equally quickly taken apart.
Step 2: Files and Assembly
So how to put it together, then?!
1. At first, look if there is a part missing. If not, sand down all of the edges a little bit.
2. Connect each table leg with another one. Use a rubber mallet. With four screws on each leg, mount the pieces (as shown on the picture). Make sure the screws won’t penetrate the other side!
3. Plug the six bars into the just assembled table sides. Lock the two lower ones with the locking connectors.
4. Now, place the tabletop on the structure. With the four small wooden rectangles fixed to the tabletop, it won’t be able to move anymore and contribute to the stiffening of the table. Done!
When disassembling the table, you don’t need to undo the screws! Just take it apart in the opposite order. You will have: A Tabletop, six bars, two desk sides and four locking connectors ready to be stored away.
Please note: The desk on the photos doesn't have the pieces on the legs yet. In my case, they haven't been milled at this moment.
Step 3: Afterthought
Is it worth it?
In terms of an enjoyable desk which goes easy on your back since it is higher, yes. That’s also true for disassembling. It cost me 200 Euros – maybe you’ll get it a little bit cheaper.
Thank you for reading my instructable! :)
kind regards,
Andrew (Andreas)
Flat Pack Contest
Runner Up in the
Flat Pack Contest
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
19 Discussions
Julian71
3 years ago
unable to download unless I choose to go "pro", any reason for this?
Thanks
Julian
Penolopy BulnickJulian71
Reply 2 years ago
You can still download any files that Kernel770 uploaded. You just can't download the PDF of the step by step directions if you are not pro.
Kernel770Penolopy Bulnick
Reply 2 years ago
Oh, yes. Thank you, that is a more precise answer!
kind regards,
Andrew
Kernel770Julian71
Reply 3 years ago
Hi! yes this is a pro feature.
kind regards,
Andrew
NGRW
3 years ago
Are you correct in your sheet size? Typically normal sheet size is 2.4 x 1.2
Kernel770NGRW
Reply 3 years ago
Hi! Turned out I was wrong; The sheet size is 2.5m by 1.25m
(http://doldholz.homepage.t-online.de/doldweb/images/stories/dold/dold%20-%203-s%20prospekt%20mehrseiter.pdf Page 3)
kind regards,
Andrew
NGRW
3 years ago
Neat job
LeslieGeee
3 years ago
Your table/desk is beautiful thank you for sharing. The DXF files you provided I cannot open. Is there a possibility you can convert to PDF format and share that way?
Kernel770LeslieGeee
Reply 3 years ago
Hi! I checked the .dxf-files but they should be ok. Please try to find a .dxf-viewer (or .dwg for that matter) online. Sharing the desk in pdf-format is not very useful, since it would be to scale. (Plus, making a .pdf on your own with the .dxf should be ok with the instructables' licence.)
kind regards,
Andrew
Seo10
3 years ago
A beautiful simple design. Could be easily cut by hand too.
Congratulations on a great design for a nice work table that can be assembled and disassembled easily.
Kernel770Seo10
Reply 3 years ago
Hi! Hm, that's true, wouln't be that hard, since all of the conturs are not milled in a half-depth or something fancy... Thanks for the comment!
kind regards,
Andrew
charlesd.parker.33
3 years ago
Nice looking project. Is the table sturdy? Does it wobble from side to side? Thanks for sharing.
Kernel770charlesd.parker.33
Reply 3 years ago
Hi! It is not bad, when the desk is in a corner, you don't have to worry about that. It's also no problem if it stands in the middle of the room, but for heavy duty uses, you can increase the stability with two small aluminium struts (approx. 0.6 m in length) at both leg sides - This is a little addition I made for my desk and it's sturdy as heck now.
kind regards,
Andrew
HisMastersNoise
3 years ago
The beauty is in it's simplicity ..... beautiful and thanks for sharing
fisho1
3 years ago
hey good job love building stuff like this. you might like my shelves they are kinda similar concept
https://www.instructables.com/id/The-Most-over-Engineered-Shelves-ever
Kernel770badly_bearded
Reply 3 years ago
Thank you :) Although I didn't mentioned it, design was also a big factor!
kind regards
primosanch
3 years ago
Very nice. Thanks for sharing.
