Electric Chicken Scalding Pot
For those of you that raise and butcher there own Chickens you know how important proper scalding of your birds is. Scalded to cold and the feathers won't come out and to hot the skin rips and makes a mess of your bird. I have in the past used a wood fired pot and a propane burner but both were very difficult to keep at the right temperature over the course of butchering. This is my solution to that problem. This pot is made out of a junked hot water heater and uses the thermostat to keep the temperature constant
Supplies:
Step 1: Strip and Cut Your Tank.
First you need to find an old hot water tank. Make sure it's an electric one. Not a very challenging thing I don't think. I picked up mine from my local dump. That's not an option for most but between talking to your friends and local scrap dealer it should be easy to find.
Next you need to strip the tank down. there is probably a better way to do it but I just knocked off the top with a hammer then used some tin snips to cut down the side. then remove the insulation. I saved the tin and insulation for future projects.
Next mesure and mark your line to cut. I cut mine just below the top heating element. measure down and mark a line all the way around.
Now cut it. I used my angle grinder with a cutting disk. don't forget you safty glasses! metal in the eye hurts! After you finish your cut use the grinder to smooth out the edge so you don't cut yourself.
Step 2: Build Your Box and Wire It Up
Since there will be water splashing all over this thing I think it's important to cover the electronics. I built a simple box around the thermostat and heating element. I was going to get fancy and cut the wood to the curvature of the tank but I decided to just make it square and fill the gaps with silicone.
Cut your top and bottom board first. place it where it will be on the tank and measure from the tank up to the top of the board. Cut your end pices this wide. This way your box will kind of follow the curve of the tank. Cut your end boards and screw it together.
Next drill a hole in the side for your power cord
Now mix up your glue. I used dollar store epoxy. stick it on and let it set up.
Silicone the edges with silicone the can take the heat. High temp silicone is your best bet I think. But other might work as well.
Now pull your power cord through the hole in the side and wire up. Connect the ground to the ground on the thermostat plate. The thermostat should be hooked up to the element so connect one end of your power cable to the heating element and one to the thermostat. Note that even if the element is 240v it will still work on 110v
Step 3: Set It and Close It Up
In my research I have found that 150 F is a good temperature for scalding. set you thermostat at that temp or what ever you chose.
Cut a plate to cover the front of the box and screw it on. You could use hinges and a latch but I think once it's set I won't need to open it up so I am not worried about it.
Next fill it with water and plug er in. make sure you test the temperature with a thermometer and adjust your thermostat accordingly.
Remember that someone threw this tank out and you likely don't know why. The element or thermostat might not work. If the pot dosent work trouble shoot the electronics.
Step 4: Conclusion
I hope this project goes together for you as well as mine did. probably only took 2 hours from start to finish. I hope this helps meany of you out there and makes batching a more enjoyable experience.
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    3 Discussions
    fertilecreek
    3 years ago
    Great instructable and idea! Thank you for sharing.
    We found that adding a bit of neutral dish soap to the water helps to penetrate the feathers quicker. While not as big of an issue for chicken the dish soap is essential for scalding ducks. Without adding the soap plucking ducks was a nightmare. It also seems that upping the temperature 5-10 degrees works well for ducks.
    Farmerdiy fertilecreek
    Reply 3 years ago
    glad you liked it! thanks for the tip. I will definitely try that. anything that makes the job a little easier is much appreciated :)
    amberrayh
    3 years ago
    Cool project. Thanks for sharing how you did it!
