Electric Mountain Board
174,792
504
191
The goal was an electric conversion with minimum damage to the board and the ability to remove the system for standard riding.
Step 1: Parts and Tools
I tried to get as many parts as I could locally but most had to be ordered online. The prices are approximately what I paid. Total cost of the project not including the board was about: $350
Board: MBS Core 95 from MBS Mountainboards. $300
Brakes: MBS V5 Brake Kit also from MBS Mountainboards. $60
Motor: 24V 300W Electric scooter motor from my local scooter shop. $30
Sprocket and Chain: Scooter sprocket and #25 chain also from my local scooter shop. $20
Steel pieces: 16ga sheet steel, perforated square tube (14ga), perforated bar and two flat bars (14ga) from Lowes. $20
The batteries, charger, controller and throttle were all ordered from Monster Scooter Parts.
Batteries: Two 12V 10 Ah scooter batteries. $65
Charger: 24V 1.6 Amp XLR Battery Charger and XLR charging socket. $38
Controller: 24V 500W Universal Voltage and Speed Controller. $33
Throttle: Generic 4-wire thumb throttle. $13
Other parts: Wire, electrical tape, wire connectors, nuts and bolts, zip ties, tie down straps. $35
Tools Used:
Socket set
Sawhorses
Hacksaw
Hammer
Adjustable wrenches
Hex key wrenches
Pliers
Clamps
Drill and bits
Jigsaw and blades
Metal files
Wire stripper
Chainbreaker - $30 from Monster Scooter Parts
Step 2: Mounting the Sprocket
The MBS brake system comes with the mounting hardware (screws and spacers) needed to mount the sprocket to the wheel.
I used the pattern from the brake rotor to drill holes for the mounting screws into the sprocket. The initial holes were then widened to allow the mounting screws to sit flush against the sprocket.
Step 3: Installing the Support Bar
After measuring from the rear foot strap bolt I cut a notch in the support bar big enough to fit over the truck. The sides are bent up to create the gap. The left flap should be removed to make room for the brakes later.
A longer bolt the same size as the foot strap bolt is used to connect the support bar to the board. Rubber washers and padding are used to prevent scratching.
The upper bar and lower bracket were installed so that they did not scratch the board or interfere with the future position of the motor. The upper bar is solid steel to prevent bending at the notch and the lower bracket is perforated steel allowing it to more easily be bent around the truck.
Step 4: Mounting the Motor
Using the sheet steel I cut a rectangle so that it could be bolted to the support bar with enough room for the motor to fit between the two bolts.
The motor was then positioned on the sheet to align the two sprockets and the holes were marked for the motor mounting bolts. Once drilled the holes were lengthened to allow minor adjustment of the chain tension.
Two pieces of solid steel bar were drilled and used as brackets to lock the motor to the support bar.
Step 5: Wiring, Throttle and Batteries
Wiring:
The controller comes with a paper describing the connectors and wire colors. Most controllers are similar and this diagram shows a good example of connector wiring: Controller wiring diagram
The only difficulty was with the throttle which had 4 wires but only 3 on the controller. After some testing the 4th wire was used as a power on indicator and I connected it to the red wire of the power light connector.
Using pin connectors and female blade connectors I replaced the originals and added an on/off switch in place of the key connector. (I also transferred the labels to the new connectors)
The motor wiring had to be reversed to make the motor run counter clockwise so the board would not run backwards.
Throttle:
The thumb throttle was placed on the end of the brake handle after removing a rubber cap. The throttle wires were then fed down through the handle and sleeve following the brake cable.
Batteries:
Two 12V scooter batteries are wired in series to provide 24V to the controller and mounted to the middle of the board using small tie down straps. This PDF file is very helpful and shows how to wire the batteries: Battery Wiring Diagrams
Step 6: Brakes
The brake installation instructions and parts descriptions can be seen in this PDF: V5 Brake Manual
The brakes were installed according to the instructions provided with very little modification. The sprocket is used in place of one of the brake rotors and the cap that tightens the left brake pad had to be replaced to provide more room for the arm to move.
The controller is attached to the deck at the spot where the brake leash is normally connected.
Step 7: The Chain and Finishing Touches
Chain:
Once everything is together the chain can be broken down and sized to fit. Chain tension is very important or the chain pops off whenever you try to turn.
This was the most difficult part of the whole project. A lot of trial and error was used to get the tension correct. I tried several ways to keep the tension even including using springs and rollers but in the end found it was easiest to just keep the chain short and tight.
When measuring the chain to take out links you have to stand on the deck because the weight of the rider pushes down on the support bar and moves the motor closer to the sprocket.
Finishing up:
I used zip ties to keep all of the wires neat and put the battery wires inside the Velcro for the foot strap to keep everything out of the way. I also put a furniture cap on the end of the support bar to cover the sharp edges.
Step 8: Project Notes
Here is a short video of the board in action.
Total time to put this together was about two days and then several more getting the chain tension just right.
I'm not sure of the battery duration or range but I have ridden it for up to 45 minutes without having to charge it.
If I had it to do all over I think that I would have made it just a bit faster. Its still fun the way it is though.
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
191 Discussions
Kreepymidget
3 years ago
I'm looking at making an electric mountainboard and I'm just wondering what a round about top speed will be. As far as I can remember I am using 2 12v 7ah 250w batteries, motor rpm of 2600 - 2850, 11tooth motor sprocket, 80 tooth rear sprocket with 8in wheels.
iMAZET
3 years ago on Introduction
I am looking at making a electric skateboard/ electric mountain board, these guys www.scramboards.com
have the parts I need, I am not sure whether I am going to buy one of there conversion kits or just some of the other parts they sell. I'll have to work out what I want first. There board convert E MTB mountain boards to 2wd 7.2 hp. I don't think these company is fully stocked yet but they said they would be in a few weeks when I called them. Hope this was helpful to anyone looking for a conversion like me. :)
PaoloC2
4 years ago on Introduction
i embraced the challenge and started too!!!
i got a core95X and 1000w system
i m having just a problem with sprocket.
as i m dividing brakes and engine system, i don t have the brake platter to drill.
my rims are the classic mbs ones with 3 screws and they don t really fit the sprocket screws.
would it be better to forge a metal platter of half cm, to have a spacer as well?
or i dunno if there are any good ideas for this and the engine mount... :/
nediffs
I'm thinking of making this but a bit different. Using this board http://www.atbshop.co.uk/mountainboards/scrub-psyc... + the breaks (Are you sure all i need is the breaks and a drill to mount the sprocket ?) And then using similar setup to yours to mount 2x500w (scouter, reversible) motors on the back. This would be enclosed in tight box, and somewhere near my back foot there would be batteries to allow bigger range(+ the ones on the middle). Any thoughts?
What is your current avg. range in miles/km (give or take a few) ?
Vurpnediffs
Reply 4 years ago on Introduction
All I used to mount the sprocket was the brake kit plates as a template and a drill. Sounds like it should go pretty fast. I haven't used my board in quite awhile and never calculated an average range but the higher the amp hours on the batteries the more range you will get.
Vurpinstructableduke
Reply 4 years ago
It steers but not as well as it did without the motor. Turning around requires a larger area.
Progress so far. I removed the sheath that housed the cable for the breaks and replaced it with a cable guard. I tethered the handle bar to the board with some 550 para-cord. I have mounted the motor to the truck and its surprisingly sturdy. I haven't gotten a chain and sprocket or mounted the motor control. 1000w setup.
http://imgur.com/a/vQX2O
Update: the worst part of this project is finding the right chain (in my case 05T which is what came on the motor) I've already spent ~$40 in sprocket and chain. It may come down to spending another $40 to get a chain/sprocket set from a motorcycle/scooter store. I have no scooter stores around here, its all dirt bikes.
chopstx
7 years ago on Introduction
Great idea, now im hooked after watching videos on youtube of these things.... :)
I have a lot of questions tho before i start spending money on the wrong stuff.
Is your setup 1 wheel drive? Do you need 2 motors(one on each wheel) and 4 batteries to make 2wd version? Wouldnt the board always turn with 1wd?
Would a Atom 90 be suitable for this?
If I am 140 pounds could i get away with a 400 watt motor? And still have good torque and speed? This would just be used for going around the neighborhood and on trails, not legit mountain boarding.
any way I can use a lever handle for throttle?
Thanks alot and great 'ible!
Vurpchopstx
It is one wheel drive and I have never noticed any turning.
The MBS Atom 90 board should work fine.
Depending on how fast you want to go I would try to get the biggest motor you can afford, a 400 watt will get you around but wont be super fast.
The throttle on this is electric so if you mean a lever throttle that uses a tension wire to control speed it wont work with this setup.
Good luck on your build.
chopstxVurp
thanks! do you have any experience using rc motors and esc's instead of scooter stuff?
Vurpchopstx
Never used those but I have looked at some of the other builds that have them and they seem to work really well.
chopstxVurp
Yeah I think that if they will electronically work together, I would like to use a 750 watt scooter motor with a rc esc and controller.
I still have some research to do so if anybody that sees this has tips, tricks, or info that could help me build an electric mountainboard, I would greatly appreciate it!
RC ESCs are three pin/output where as scooter motors are only two. This is because RC motors (brushless I assume) are different in making than Scooter motors. an ESC with a scooter motor just wont work. Look at my other post where I got my scooter motor kit. Im waiting for it to come in the mail. Once its done, I'll post pictures and a video of it.
Vurpevanwehrer
Reply 6 years ago on Introduction
The batteries and motor are somewhat heavy I would say it weighs about 20-25 pounds.
As soon as I can get some money saved up, I'm going try this out on my MBS Atom 90 board. I've already bought and installed the braking system. Now I'm trying to come up with a mounting plan to work around the brakes.
http://www.monsterscooterparts.com/36-volt-1000-watt-motor-controller-throttle-kit-standard.html
Do ya think 1000w might be a bit overkill? Im a 6ft 3in, 220lb guy, so Im just at the weight limit for this particular board. I've done some down hill and some jumps before I installed the brakes to see how it does. It hasn't broken yet.
VurpThe Expert Noob
I think having more power is better even if you don't need it. You can always use less throttle if it is too fast. Not having enough power will mean slow speeds and more hassle to change.
