Electronic Projects for Beginners
14,782
160
30
About: Fixer, Finder, Fabricator.
If your wanting to get into electronics and need a place to start this instructable is for you. There are a number of very cheap kits on eBay and Aliexpress that you can get for 2 or 3 dollars which can give you some experience in component identification, soldering and fault finding. Some of the kits are better than others and they don't come with instructions, but the PCBs are usually well labelled, so you don't really need a step by step guide to assembling the circuits.
If your looking for the Instructable for laser cut cases to fit these kits you can find them here https://www.instructables.com/id/Battery-Cases-for-Electronic-Kits/
Step 1: Where to Get Your Kit?
I got the kits from eBay but other websites like Aliexpress or Banggood also have the same or similar kits.
Flip flop LED flasher $1.25
Sound activated LED Flasher $1.00
DIY Electronic doorbell. $1.82
Electronic LED dice $ 1.69
Lucky rotary LED wheel $1.22
LED chaser $1.24
Wireless FM Microphone $1.55
Electronic LED hourglass . $3.70
Step 2: Before You Start
Before you start it is very important that you be able to identify electronic components and understand if they are polarity sensitive and know how to read component values. You will also have to have good soldering skills, as many of the pins are very close together and poor soldering will ruin your project very quickly.
If you solder a component in the wrong place or around the wrong way your project will likely not work, or your component could be damaged.
Research can easily be done with a google search, here are some names to get you started. Draw up a grid in your folio with a row for each of the following
  • Resistor
  • capacitor
  • Transistor
  • PCB
  • IC . (555) (4017)
  • Microcontroller (1704)
  • IC socket
  • Switch
  • Trimpot
  • LDR
  • Inductor
  • Microphone.
  • Diode
  • Zener diode
In your grid, you need 5 columns for each of the following.
  • Name of component
  • photo
  • symbol
  • A brief description of how to read the components value.
  • Is it polarity sensitive, how can you tell which way around it fits into the PCB
You also need to think about making a case or cover for your project, this can be easily done with a laser cutter or 3D printer and a bit of thought. Check out my other Instructables which will show you how to use the laser cutter and 3d printer, and there are some examples of students case designs in the photos.
Step 3: Learning to Solder
A good way to learn to solder is practising on a piece of Vero board and some header pins.
Tips for well-soldered joins are.
  • Make sure the soldering Iron is clean, melt a little solder on the tip and clean off with a wet sponge.
  • Soldering iron need to be up to temperature before you start. Use proper resin core 60/40 electrical solder. (Lead-free solder can be difficult to work with)
  • Heat the pad and the wire with the soldering iron Bring the solder in from the opposite side of the iron Melt the solder onto the pad and wire.
  • Avoid putting the solder directly on the soldering iron when soldering
  • Lots of practice.
  • Cut the excess wire after you have soldered a number of components in.
  • Always use sharp side cutters, and never pull or twist the wire to snap it off, the PCB can be easily damaged.
Step 4: Making a Start.
It usually best to start with the components that will sit low on the PCB first and fit the tallest components last.
Start with the resistors, and either use a resistor colour code chart or multi-meter to check the resistance value before fitting them to the board.
For some reason, many of my students get this wrong and end up with resistors in the wrong location, which can be very difficult to repair.
All the circuit board are very well labelled just keep an eye out for similar looking markings. eg 22K, 22R and 2K2 are NOT the same things. Also, some board are board may use a decimal point eg 2.2K and 2K2 are the same.
The LEDs can also be Labeled in different ways, so make sure you fit them the correct way around. They may have a + or - a diode symbol or a circle with a flat.
Step 5: Flip Flop
A flip-flop circuit is a basis for all sorts of electronic circuits, this one flashes two LEDs alternately. Its the perfect for your first project and can be modified to make the LEDs flash faster or slower. You could use the finished project for a model railway crossing, or tail light for a bicycle.
You will also need a battery and it will work with 3-9 volts
Parts List
  • 2x LEDs
  • 4x Resistors 2x 470R 2x10K
  • 2x Capacitors 47uf
  • 2x Transistors 9014
  • PCB
It also comes with a circuit diagram, but it's in Chinese and hard to read.
Photos show a simple laser-cut case, and a button cell and laser cut switch were used to keep the size small. The laser cut cases will be the subject for my next instructable
Step 6: Sound Activated LED Flasher
The Sound activated LED Flasher, Is a great beginner project, it has a microphone, and when there is a sound it flashes 5 super bright LED.
It only has a few components and is very easy to build and get working. You will also need a battery and it will work with 3-6 volts
Parts list
  • 5x LEDs
  • 3x Resistors 1M, 10K, 4.7K
  • 2x 9014 transistors
  • 2x capacitors 47uf, 1uf
  • 1x Microphone
  • PCB
  • plug and wiring
It also comes with a circuit diagram.
Step 7: DIY Electronic Doorbell.
The DIY Electronic doorbell is also another great little kit, although it doesn't really sound like a doorbell more like a dying frog in an electric fence. There is an error on the circuit board as the 100uf (C5) is not labelled. Of course, you could use this for a doorbell or prank your friends by wiring it to a toilet seat, or locker door. It is an easy kit to assemble and you will also need a battery and it will work with 6-9 volts
Parts List
  • 1xSwitch
  • 1x Speaker
  • 4x Resistors 47K
  • 2x Zener diodes
  • 1x IC 555 timer
  • 5x Capacitors 1x 10uf 1x 100uf 3x10nf (code 103)
  • 1x PCB
There was no circuit diagram with this kit
Step 8: Electronic LED Dice
The Electronic LED dice is a little more difficult it has quite a few more components and doesn't come with an IC socket so you need to make sure you place them correctly in the PCB the first time. Although the kit is well made and it looks nice the dice don't really function properly as you can get some weird LED combinations and its possible to roll a zero. Well, you get what you pay for it was only a $1.69 but a little disappointing.
Thanks to instructable user jimdkc for pointing out the error that makes the dice malfunction. There are 2 errors you need to look out for, first the transistor Q3 on the PCB is mislabeled and should be a 8550. Next some kits only come with one 8550 transistors and there should be two.
The dice works perfectly if the correct (8550) transistor is fitted to Q3
It also has some very high-value resistors, and most cheap multi-meters will not read above 2MΩ, so you will have to read the colour codes.
Parts list
  • 7x LEDs
  • 9x 10K
  • 3x 470R
  • 1x 1K
  • 1x 4.7M
  • 1x 3.3M
  • 1x 10M
  • 3x transistors 8050 and 2x 8550
  • 1 push button switch
  • 2x ICs . 555 and 4017
  • 2x capacitor 1uf and 100pf (code 104)
  • plug and wiring.
  • you will also need a battery and it will work with 3-6 volts
Step 9: Lucky Rotary LED Wheel
The Lucky rotary LED wheel Works much better than the dice, you push the button and the LEDs chase around a circle and stop at a random point. You could come up with all sorts of games with it. I had someone suggest a cricket or baseball game by labelling the LEDs 1 run, Home run, foul, ball, strikeout etc.
ICs can be difficult to fit so make sure the pins are straight before you try to plug them into the socket
Parts List
  • 10 LEDs
  • 2x resistors 470K
  • 2x resistors 1.2K
  • 3x capacitors 47uf. 100uf. 100pf ( which has a code of 104 )
  • 2x ICs a 555 (timer) and 4017 (decade counter)
  • 1x push button
  • 1x 9014 transistor
Step 10: LED Chaser
The LED chaser is a great kit and is similar to the Lucky Rotary LED Wheel, but is a little more challenging as it is on a smaller PCB. It also has a trim pot which allows you to adjust the speed. You could use it as a display, or maybe tie it to a bike wheel to make a cool looking POV light. Some of the PCBs have a minor error as the resistors are miss numbered there is no R4
Parts list
  • 12x Resistors 10x 1K, 1x 10K, 1x 2k2
  • 10x LEDs
  • 2x IC 555 and 4017
  • 2x capacitors 1uf
  • 1x trim pot 50K
  • 1x plug and wiring
  • you will also need a battery and it will work with 3-6 volts.
Step 11: Wireless FM Microphone
The Wireless FM Microphone kit is not hard to assemble but is very difficult to fault find and get working. It looks like a great kit but it hasn't really got any way of adjusting the transmitter frequency so you may end up with it on the same frequency as a radio station. You can the frequency a little by stretching the inductor coil but this is not ideal. $1.55 disappointment.
Parts list
  • 3x resistors 220R, 22k, 2K2 (they are all different)
  • 7xCapacitors are all the little ceramic type with codes, 103,104, and 10p, 30p
  • 1x Battery Snap
  • 1x switch
  • 1x microphone
  • 1x transistor 9018
  • 1x inductor
  • you will need a 3-volt button cell
Step 12: Electronic LED Hourglass
The Electronic LED hourglass is the most difficult kit to assemble as it has the most number of parts and getting the LEDs in the correct orientation it can be confusing. the LEDs all need to be the same height also or it will look very bad. I recommend you solder one line of LEDs in at a time and cut the leads before attempting the next row.
The Hourglass has a microcontroller and a TXD and RXD pins so it should be able to reprogramed to do other things with the LEDs
The Kit comes with a few spare LEDs also, this is because you're likely to find a dud, mine had 2. A great kit and will take your soldering skills to next level.
Parts List
  • 57x super bright LEDs
  • 1x 1704 microcontroller (it not labelled correctly on the PCB)
  • 1x Pushbutton
  • 1x Switch
  • 1x Power socket
  • 1x IC socket
  • 4x header pins
    • Tape Contest
      Tape Contest
    • Weaving Challenge
      Weaving Challenge
    • Remix Contest
      Remix Contest
    30 Discussions
    liquidhandwashGWSC
    Reply 8 weeks ago
    They could be, I've also seen similar kits in Australia from dick smith electronics and jaycar.
    I was looking for cheap as possible for my students, as i have a limited budget, and every project is X20 so the price of running a class can get out of hand if your paying $25+ for each kit.
    AspireS3
    Question 6 months ago
    Am interested to do DIY project of 2*15w bluetooth speaker... I have followed modules and circuits boards but I have dubbed in circuit integration so please help me to how to do this...
    5v DC power supply - 1
    5v-12v DC - DC boots up circuit board - 1
    15w amplifier circuit 12v DC input - 1
    15w speaker - 2
    Please help me...
    1 answer
    liquidhandwashAspireS3
    Answer 6 months ago
    Can you send me a link to were you got the circuit from?
    jimdkc
    11 months ago
    I believe, on your LED Dice circuit, if you replace each of the 10K resistors that go between the 4017 output pins to the transistor bases with a series diode + 10K resistor combination, your circuit will work much better:
    4017 Output Pin----|>|----^v^v^v----Transistor base
    This will properly isolate the 4017 outputs from each other...
    You can do this by desoldering the 4017 end of each resistor, solder the anode of a diode (1N914 or 1N4184 small signal diodes should work nicely) in each newly vacant hole, the solder the cathode lead of the diode to the newly freed lead of the resistor. You will need 8 diodes.
    I have two of these kits waiting to be assembled. Maybe I'll build one with and one without diodes to compare the difference!
    jimdkcliquidhandwash
    Reply 11 months ago
    OK... I was confused by the fact that there is no connection to pin 2, the Q1 output of the 4017. However, I did not notice that one of the LED driver transistors is a PNP. So when the Q1 output goes HIGH, all the other outputs are LOW and that PNP transistor turns on.
    I also found this schematic, which also appears to be nearly identical:
    http://www.555-timer-circuits.com/led-dice.html
    I'll build one of my kits this weekend and see how mine works.
    liquidhandwashjimdkc
    Reply 11 months ago
    Just had a look at the dice kit again, and found that there was only one 8550 in the kit. I have around 20 of these kits for students so I had a look in a couple of others, 2 were the same and one had two 8550 in the kit. So it looks like a bit of a lucky dip as to what you get. I replace Q3 with an 8550 and it now works perfectly.
    Reply 11 months ago
    Cool!
    You can replace the borrowed or missing 8550's with almost any small signal PNP switching transistor, such as a 2N2907 or a 2N3906.
    I buy 2N3906's (and the NPN complement 2N3904's) by the hundreds on ebay or geek.wish.com for a couple bucks!
    jimdkcjimdkc
    Reply 11 months ago
    Or, S8550's are just as cheap!
    jimdkcjimdkc
    Reply 11 months ago
    Oh, wow! I just realized that pin 2 of the 4017 is not connected to anything at all... That's how you can throw a "0"! Yikes!
    I have a new project... trying to fix this circuit!
    Reply 11 months ago
    That would be great, as Im no electronics whizz, i would like to know the fault in the design and how to fix it. let us know how you go with it, Ill send you some laser cut cases.
    Reply 11 months ago
    Check your transistors carefully. TWO are PNP, and THREE are NPN. Make sure the PNPs are in the right place.
    I believe, going by the legends on the PCB, that Q1 and Q3 should be PNP (8550) and Q2, Q4, and Q5 should be NPN (8050).
    All the driver positions on the board are labeled 8050. Q3 is mislabled.
    If you mixed up these transistors, that would explain your odd results!
    Reply 11 months ago
    Thanks Jimdkc, Now you have pointed it out I can see the error. From memory there was only one 8550 in the kit, so with a mislabeled PCB, as well....
    iceng
    1 year ago
    Impressive presentation.
    BTW I have programed straight machine language for the 8051 and the PIC series..
    liquidhandwashiceng
    Reply 1 year ago
    Thanks Iceng, you should have a look at the the kit, and see if you can program it to do something cool. The hour glass thing is pretty neat, though.
    icengliquidhandwash
    Reply 1 year ago
    Baught the hour glass and lookin forward to play with it ;-)
    jimdkciceng
    Reply 11 months ago
    Would be cool to wire up a couple of tilt switches to it and program it so you can flip it over and have the LEDs "flow" back the other way.
