Electronics Components Salvage
67,690
482
25
If electronic parts are not in your local electronics shop, you would probably salvage parts from old electronic appliances. I salvaged components mostly from old and damaged appliances because I don't bother to tamper the WARRANTY VOID stickers and I don't want to destroy the working appliances.
Warning: No power should be applied while dismantling the appliance and watch out for big capacitors.
Tip: Put one hand on your pocket if you are working with electronics that store high voltages.
Here is a list of things where you can find electronic components:
- Computer power supplies
- Motherboards
- TVs or CRT monitors
- Amplifiers or sound systems
- Radios and Car Stereos
- Electric fans
- Automotive
- Microwave Ovens
- Bulbs (like CFL and LED)
- Christmas lights
- Flashlights
- Cellphone chargers
- Digital / Analog Clocks
- Toy Robots
- Telephones and Networking equipment (like Routers)
- AVR(Automatic Voltage Regulators) and UPS(Uninterruptable Power Supply)
Step 1: Tips on Salvaging Electronic Components
- You should have a bag or a case where you put all your tools in there.
- These are the basic useful tools when you are salvaging:
-Screwdrivers
-Pliers
-Wire cutters
-Multi-meter
-Soldering iron
-Desoldering pump or solder wick
Step 2: Computer Power Supplies
You could salvage its transformers, regulators, ICs, Inductors, capacitors, heatsinks or anything that you need.
Step 3: Motherboards
You could salvage all those conectors, sockets, heatsinks, capacitors, and inductors. I won't salvage the ICs because I have no need for it.
Step 4: TVs or CRT Monitors
I'm planning to salvage some of the connectors and other components inside like the capacitors, speakers, wires and any other components that you are needing. But be careful, older tv's and crt monitors have high voltage picture tubes inside.
Step 5: Amplifiers or Sound Systems
The inside of these sound systems has many components like: capacitors, switches, knobs, potentiometers, jacks, LEDs, chips(if you need them), big heatsinks, cooling fan, and anything that you would need. Here's a use for the cooling fan you have salvaged: https://www.instructables.com/id/DIY-Car-Cooling-Fa...
Step 6: Radios
Salvage all those things that you want like the knobs, pots, transistors, jacks, speakers, and even the casing.
Step 7: Electric Fans
Salvage the knobs(if there is), selector switches, wires, and even the motor(if it will still work)
Step 8: Automotive
You can salvage all those fuses, relays, halogen bulbs, horn, and all other things that you can salvage from an old car.
Step 9: Microwave Ovens
There are parts in the microwave oven like capacitors, transformers, power resistors, relays, and even the digital timer module (if it has one). You can reuse the digital timer module as an appliance timer. I made a digital timer only from the microwave oven's timer. Link: https://www.instructables.com/id/Digital-timer-from...
Step 10: Bulbs (like CFL and LED)
The parts to be salvaged in these bulbs are the transformers, inductors, capacitors, and transistors.
Step 11: Christmas Lights
You can salvage bulbs and a plug from a string of Christmas lights.
Step 12: Flashlights
Salvage all those LEDs, capacitors, switches. These parts are most likely to be found in a rechargeable flashlight.
Step 13: Cellphone Chargers
What you can salvage from a charger is a small transformer, capacitors, wires, and a usb port(if it has). There are diodes and resistors but I do not salvage them because they have short leads.
Step 14: Digital / Analog Clocks
If it is a digital clock that would be plugged into the mains, you would most likely salvage the red seven segment displays. It also has capacitors and resistors. If it is an analog clock, you could salvage its coil. The clock on the picture can have piezo elements if it has a mini alarm tone.
Step 15: Toy Robots
You could salvage the motors, speakers or an IC from a talking toy robot.
Step 16: Telephones and Networking Devices
Telephones that don't work anymore can have those piezo buzzers also and their handsets could have a electret microphone and a small speaker.
Routers and networking devices can have plenty of those leds and you can use their beefy wallwarts for powering your other projects.
Step 17: AVR and UPS
Automatic Voltage Regulators have relays, indicator LEDs, switches, a volt meter and those comparator ic's.
Uninterruptable Power Supplies can have plenty of relays and power transistors. Aside from that they also have quad-comparators like the LM339 ic. They can also have those big heatsinks.
Now you already know where to salvage all those parts and components that is not available on your local electronics store. Thank you for reading. Please leave a comment below if you have ideas and suggestions.
    • Faux-Real Contest
      Faux-Real Contest
    • Remix Contest
      Remix Contest
    • Paper Contest
      Paper Contest
    25 Discussions
    LasithaC
    1 year ago
    good article
    EsorP1
    2 years ago
    Is there voltage regulator in computer power supply
    RobertC2EsorP1
    Reply 1 year ago
    Yes, there are at least three (3.5V, 5V, 12V) in most ATX power supplies.
    Suraj GrewalEsorP1
    Reply 2 years ago
    yup, but mostly its either a zena diode or inbuilt into an smps driver.
    fifty_ohmsmaster-maker
    Reply 2 years ago
    You should buy a cheap soldering iron just for the salvaging purpose, but if you intend to take electronics seriously, I suggest you invest on a temperature controlled iron.
    rah187
    2 years ago
    Great instructable! I salvage stuff too, and you covered basically anything that a person new to salvaging would need to know. I take things apart all the time to extract the useful components. In fact, two out of my three instructables that have been published have to do with dismantling electronic devices and taking out the components. One is on CFLs, and the other is on CRT televisions.
    deswiger
    2 years ago
    I love doing this, wish I had a warehouse. Thanks for the share, nice job. Semper Fi
    HermieG
    2 years ago
    looking for an amplifier module for a Mackie Thump 12' powered speaker
    Panfishman
    3 years ago
    Very good ideas! Thanks! I am getting into salvage, and you provided some good tips!
    Gelfling6
    3 years ago on Introduction
    My only gripe, lately, is some towns with dumps and transfer stations, are opting to "Electronics Recycling", and basically taking instant possession of ALL electronics for profit selling them to metal salvages (read Miners, mainly looking for gold, platinum, Neodymium.) The drawback I see, is these Miners usually use caustic and corrosive chemicals to dissolve the metals they want, but it leaves non-recyclable, and contaminated scrap, to say nothing of the chemicals that are still poisonous, and ladened with heavy metals. My home town is pretty much one of these towns, and if you attempt to remove any device from the storage bin, You are essentially stealing from the town. This has pretty much cut off the supply of functioning devices I was once able to salvage... You should check with your town's laws on recycling...
    On a side note, One handy tool I found, was a small butane blow torch. (Like they use for fancy cooking.) Though brutal, I found it works best for fast melting all solders (lead/tin, copper/tin, & silver solder.) but quick action is needed to remove the components, using a pair of pliers, a wire hook. (grab a single side of a resistor or capacitor) gloves, safety glasses or goggles are always key for protection!
    jplaissGelfling6
    Reply 3 years ago
    I cannot agree more.
    I have enough to share, but won't hand it over to a "scrapper".
    Live near Southern Indiana?
    Neel DhebarGelfling6
    Reply 3 years ago on Introduction
    What I suggest is you buy a small bin for electronics that people want to throw away and label it. Put it near those recycle bins and chain it to the building or the ground. The label should tell people to put electronic waste there and tell the town not to take it. A flap can be installed or slit can be cut to deposit items and the box should be locked. You will tend to get good yields. If you're good with electronics, build a circuit that will give a dollar(or quarter) for every electronic item.
    You are correct, it is considered an alternative revenue stream, and also allows municipalities to present themselves as very "green". Your only chance to beat the system is to make- what I call "asset recovery sweeps"- of your neighborhood. I find late Sunday afternoons good for pickin's as many garage sales have ended earlier, and the owners just short haul the leftovers to the curb.
    Yonatan24
    I made an Istructable with a huge list of what components I keep when taking apart electronic devices, and where they are usually found, If anyone is interested:
    https://www.instructables.com/id/What-to-Keep-When-Taking-Apart-Electronic-Devices-/
    This is great! NOTHING that is broken is 100% broken. The majority is still perfectly usable. Since electronics is an expensive hobby (several dollars for some parts) I encourage everybody to use broken/discarded/thrown away parts to salvage and use in their projects.
    Most people just don't know the value of 'broken' electronics. If you know a bit about electronics it's just a transistor that needs to be replaced lots of times and it can be fixed very cheaply. The components can be sold if your not a hobbyist yourself online.
    Neel Dhebar
    Most ICs salvaged from computers are not very popular with hobbyists and circuits are not easy to find. Also, finding a BT66 or NE555 is difficult in computers but there might be programmable microcontrollers.
    iffee
    I have been doing since decades but according to my experience it is difficult to manage and find from the parts already salvaged. Now I keep boards and likewise things on their boards and chassis. when ever I need any component, I look them and find easily and salvage the parts required. Specially the small parts like resistors/diodes/zeners and transistors are easy to find.
