Embroidery Basics
18,881
129
6
About: I am a landscape designer and advocate for native plant-focused and sustainable landscaping, but in the past I have worked in costume production and clothing alteration. I taught myself to hand-tailor, draft...
I love sewing machines. They do almost everything better than I can, or at the very least, faster and more uniformly.
When it comes to embroidery, though, handwork is inimitable, and machines still can't come close to it. Machine work is precise, but it's flat, hard to the touch, and stiff; hand embroidery is plush, soft to the touch, and pliant. I also find hand embroidery's imperfections add to its charm; one of the things that makes embroidery so beautiful and valuable is the knowledge of how much time it takes to do well.
And embroidery is very time-consuming. It takes patience to learn, because precise stitching doesn't come naturally. But it isn't difficult, and with careful prep and a few multipurpose stitch types, you can make something attractive and unique.
The work I'll be using to demonstrate basic embroidery techniques in this instructable is a square from a much larger, very long-term quilt project. I was about ten hours into this square when I started the instructable, and I'm very happy with it despite a few mistakes (which I will point out for your benefit!).
This instructable will cover some basic tips for dealing with thread, and the following common embroidery stitches: backstitch, stem or vine stitch, and satin stitch.
Step 1: Set-Up: Fabric, Thread, and Supplies
You only need a few things to do embroidery, but you do need all of them. Here they are:
- Embroidery hoop (preferably more than one, of different sizes) - these are cheap and easy to find and they are completely essential. When using the hoop, stretch the fabric taut, and pull the edges so that the weave is straight in both directions.
- Embroidery needles - these are larger than regular sewing needles, with an eye big enough to accommodate the larger thread.
- Embroidery thread or "floss" - there are a few different kinds available. DMC makes most of what you'll easily find, and their six-strand floss runs about 50 cents for an 8-meter skein. It comes in a huge variety of colors and is a solid choice for starting out.
- A thimble - technically you can sew without one, but I really strongly recommend using one. Embroidery takes a long time and will eventually make your needle finger sore. I like leather "quilting" thimbles.
- Small scissors
- Chalk pencils (or a regular pencil, but graphite is hard to remove).
When you choose your fabric, I recommend starting with a mid-weight linen like I'm using in the photos. It's nice to be able to clearly see the weave you're working on. Cotton is also a good choice. Avoid anything too fine or too thick, and avoid jersey or anything stretchy - embroidery will deform it.
Step 2: Taming Your Thread
You don't have to make any mistakes for your thread to turn into a knotty, tangled mess. That happens by itself, so you must be proactive at all stages of sewing to keep your thread under control.
That starts when you thread your needle. Thread has a twist direction (it's either S or Z), and you want to be sewing with the twist, to make your thread less likely to tangle. Generally speaking, you can accomplish this by threading your needle off the spool first, and then cutting it. Tie the knot in the spool-side end immediately after you cut it, with the leading end hanging loose through the needle.
What if you're sewing with that DMC six-strand floss I recommended, that doesn't come on a spool? I do try to keep track of which end I'm threading, but it doesn't make too much of a difference with this stuff. You're going to split the strands anyway (I like to sew with three rather than six), which is most easily done by slowly pulling three strands to the left and three to the right as the length of thread hangs free in the air.
How long should your thread be? The shorter it is, the more easily you will manage it. Of course, embroidery uses a lot of thread and that means you will be running out more often -- I like a longer thread myself, but I recommend starting shorter (about 12-18") and then working up from there as you get better at managing thread.
I use a plain knot to start my sewing; I find that, for this thickness of thread, three knots on top of each other is what I like. Aim to tie the knot close to the end of the thread -- about half and inch from it -- and stack the knots by catching the thread of the second knot on top of the first one.
Once you are sewing, you will need to keep an eye on your thread all the time. Pull it through slowly with each stitch, and stop if there is even the slightest bit of resistance. You can easily untangle a spontaneous knot if you catch it before you have tightened it by pulling on it, but once it has tightened, you may have no choice but to cut your thread and start again. When the thread is underneath your hoop, simply rest two of your fingers on it as you pull it, so that it must slide between them before going into the fabric. This will prevent most knots. Again, if you detect resistance, stop and investigate.
Why does this matter?
Apart from the fact that knotty thread wastes length and thus reduces what you can do with each length of thread while increasing the time it takes to accomplish your work, knotty thread does not make for sound stitching. If the knot pulls through, it is unsightly and also loosens the work, making everything look bad.
Step 3: Backstitch
The backstitch is a workhorse. It's the stitch that was used to sew clothing before we had sewing machines (and still is, if you're doing it by hand). Flexible, strong, with a little built-in stretch, it can follow just about any line, and if you take the time to do it carefully, it's perfectly attractive, too.
In this example, I'm using it to make the squared key design inside the fence, but I have also used it in this piece for the outlines of the animals. It's a good choice for lettering, as well, particularly block lettering.
The backstitch is so called because, on the top of the fabric, you are placing the needle against the direction of stitching. Begin one stitch-length from the start of your line, and make one backwards stitch to the starting point. Then bring the needle back through to the top one stitch-length further from the end of the first stitch, and make a second backwards stitch to the end of the first stitch. Each stitch essentially forms a loop that, on the underside of the fabric, is twice as long as the stitch on top, kind of like a letter P. This looping is what gives backstitch its ability to stretch.
The stitch tends to look a bit messy underneath, especially if you use it for curves. That's okay.
Step 4: Stem Stitch
Stem stitch is basically the other side of backstitch, but done in such a way as to make it very pretty. It's important to keep your thread on the same side of the needle as you stitch with this one. That's what gives the stitch its signature spiral look. On top of the fabric, each stitch overlaps by 50% the one preceding and following it; underneath, the stitches don't overlap. The key to making this stitch look good is keeping the stitch length constant and short (so that your spiral looks tight and even), and beginning each stitch so that it lies underneath the preceding stitch (so that you don't have any extrusions breaking your line). Mary Corbet has a very nice close-up video of the stem stitch here.
Stem stich can accommodate curves but, as you can see with my waves, it is better on curves going one way than the other depending which side of the needle you're keeping the thread, and you can't switch between sides while stitching without breaking the spiral. I don't mind the way the stitch pulls a little on the bottoms of the waves, but that is what it looks like when you hit the limit of how much stem stitch can accommodate a curve like that. At a sharp point, break the stitch line and begin a new one.
Step 5: Satin Stitch
Satin stitch is, to me, the quintessential embroidery stitch. It is the most time-consuming (and thread-consuming!), requires the most precision to pull off well, and looks the most luxurious.
Satin stitch is simply filling in an area of fabric with thread by laying one stitch down immediately next to another. This is where having a nice medium weave in your fabric comes in handy. In this example, I'm filling in the building on the pier with satin stitch; since it's a wooden structure, I want my stitches to look like straight boards, so I'm taking care to follow the threads in the fabric when I make each stitch.
In order to make your satin stitch look good, a little organization is required. I don't recommend varying your stitch lengths so that you have jagged edges to the stitch areas; it looks shabby. Smooth edges look neater. You want to plan ahead how you're going to fill in a region so that you can divide it into manageable stitch areas, and the larger the region, the more difficult this gets. You can see on my sea lion that my planning was deficient, and the stitch areas are kind of all over the place. I wanted the stitch areas to be wavy, because I thought straight edge lines would look odd on an animal and to repeat the water theme, but I didn't really take the overall shape into account and the wavy areas seem to change direction, which was not what I wanted. On the stingray, however, the plan came through and the results are excellent. Of course, the stingray is much smaller, so it was an easier area to plan for.
Why can't you just make long stitches that cover the whole length of the region you're working with? Because long stitches will gape away from your fabric, exposing the background, and sag over time. You can make long stitches if it's really necessary (I used long stitches for the pillars), but then you must secure the embroidery floss to the fabric using thin sewing thread, stitching inside the floss rather than on top of it. For a large region, this is rather impractical.
Step 6: Combine
Embroidery is meditative and satisfying, and I hope you'll give it a try with these three stitches. Start with a small project, and post a photo here if you'd like to share!
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    6 Discussions
    ash_doge
    2 years ago
    Awesome work, how long does it take you to do a piece?
    gtrachelash_doge
    Reply 2 years ago
    Thanks! I work on them over a few weeks at a time on and off, but I would guess about 20 hours for something like this.
    artworker
    3 years ago on Introduction
    At first it looked like you used an embroidery machine. Super hard work! Output is beautiful!
