End Grain Cutting Boards Build Process
4,509
85
16
About: I am a woodworking hobbyist working out of my backyard shop in my spare time. I am a professional driver and work about 55+ hours a week and am raising 3 kids. Not much time for woodworking lately.
Hello fellow woodworkers,
In the spirit of sharing woodworking knowledge I am writing this tutorial for anyone interested in constructing these beautiful end grain cutting boards. Take a look at the photos of the four styles I have made, or create your own pattern’s and follow the steps I have outlined in this tutorial.
Step 1: What You Will Need
Tools I used are table saw with cross cut sled, 6” jointer, 13” plainer, chop saw, band saw, router table with ¾” round over bit # 80 cabinet scraper or belt sander, disc sander random orbit sander and clamps. Supplies used are 4/4 hardwood stock of multiple species, Tightbond 3 glue, Mineral oil, paper towels or painters rags and bees wax finish for a optional protective top coat.
Step 2: Creating Your Own Pattern
Creating your own pattern is as easy as laying out a grid of equal size squares that is 17 x 17 squares. Each square is ¾” x ¾’. The finished boards will measure 12 ¾” x 12 ¾” x 1 ¼” thick. I designed my patterns using “paint” program on my computer. Or use a cad program that allows color fill. Grid paper with color pencils will work too but making changes is difficult.
Here’s a sample of one of my “paint” patterns.
Step 3: Before Getting Started
Once you have decided on a pattern count the squares of each color representing the desired wood species in ½ of the pattern plus the center row . Figure on one board foot of stock for each 10 squares. This plan will yield three identical boards. The individual pieces of stock are cut to 10” long primarily for the purpose of milling the stock as you cant run small 1 ½” or 3” pieces of stock threw the plainer. Look closer at the pattern and you’ll see that the top half is a mirror image of the bottom half that has been flipped left to right. There fore you only need to create pieces for half of the pattern. The center row does not repeat but the work pieces are the same length and there will be some waste from the un used glued up strips. Or create pieces for the entire pattern to make 6 identical boards.
Before getting started check the condition of your jointer and plainer knives. You will be working with dense woods and tear out can cause small voids in the cutting board surface. Changing plainer knives mid project can cause problems. If there is just a slight variance in stock thickness the patterns will not align correctly.
Step 4: Milling and Cutting Your Stock
Milling and cutting your stock
Begin by rough cutting your stock to lengths of 10” Mill the pieces by flattening one face at the jointer.
Step 5: Run the Pieces Threw the Plainer
Now run the pieces threw the plainer milling them to ¾” . I recommend checking each piece with a dial caliper to confirm they are the exact same thickness. This is important for proper pattern alignment in the final glue up stage. Detecting a thickness problem now will save you much aggravation and disappointment later.
Step 6: Rip Strips 7/8” Wide at the Table Saw
Next joint one edge on the work pieces and rip strips 7/8” wide at the table saw. ( TIP: laying the pieces on a piece of plywood makes transporting them to your work bench a snap.)
Step 7: Lay the Pieces Out Row by Row
Once all the pieces required to create your pattern are ripped you’re ready to lay them out in the order they will be glued up in. Using your pattern as a guide lay the pieces out row by row one on top of the other with the ¾” milled faces vertical and facing each other as shown here.
Step 8: Glue Them Up One Row at a Time
Try to orient the grain direction of each piece the same for the purpose of tear out free plaining after they are glued up.
Remember you only have to complete half of the pattern plus the center row to make three boards. Each glued up row will be milled to ¾” later. When your sure the rows of stock are in the correct order glue them up one row at a time keeping them in the same order. I lay the pieces on their sides except for the first one and spread a generous amount of glue with a roller on one side only. Rotate and assemble the pieces applying good even clamping pressure. Consistent clamping pressure is important or the pattern may not align correctly.
Step 9: Scrape and Plain One Side Reasonably Flat
I recommend wiping off the squeeze out now with a damp rag to save scraping labor later.
Once the glue up’s have cured remove them from the clamps and scrape and plain one side reasonably flat in preparation for milling.
Step 10: Now Mill the Glued Up Sections to ¾”
Now mill the glued up sections to ¾”. Be sure to pay attention to grain direction and alternate sides to ensure both faces are flattened.
Step 11: Cross Cut Each Glue Up
Using a cross cut sled at the table saw trim one end of each glue up. Then set the fence to 1 3/8” and cross cut each glue up into 6 pieces.
Step 12: Lay Out the Pieces in Order
Now for the moment of truth. Lay out the pieces in order using your pattern as a guide.
Step 13: Glue Up Your Boards
Carefully align the lines of the pattern and make sure things look good. If there are any alignment problems this is the time to correct it. This means creating a new glue up for the problem row or rows. If the proper steps where taken to check the thickness of the milled stock there shouldn’t be a problem.
Now you’re ready to glue up your boards. The glue up procedure is the same as before. Glue up only 5 or 6 rows at a time to prevent slippage and alignment problems. Press each glue covered piece firmly in place paying strict attention to pattern alignment.
Step 14: Flatten One or Both Faces
Gradually add clamping pressure checking for slippage as you go. Wipe the squeeze out for better pattern visibility. Allow the glue to set up before repeating the glue up process until the board is complete.
Remove the board from the clamps and flatten one or both faces with a # 80 cabinet scraper or belt sander. The edges are very prone to tear out so stop short of the opposite edge when scraping. You want to get one side of the board reasonable flat so it doesn’t rock on a level surface in preparation for plaining.
Step 15: Trim the Edges of the Board
Using a sled at the table saw trim the edges of the board flush Removing only what is necessary to flush the edges. Try to keep all four edges even in appearance
Step 16: Round the Edges at the Router Table
To flatten the boards I ran them through my plainer. Before doing this the edges must be rounded over or sever tear out will occur at the end of the cut. I rounded the edges at the router table with a ¾” round over bit. Chase the work piece with a wood push block to prevent tear out at the end of the cut.
Step 17: Plaining End Grain
Plaining end grain can be murder on your knives and could even damage your plainer if great care isn’t taken to make very light passes. I rotate my depth adjustment wheel 1/8 of a turn or less for each cut.
Step 18: Final Steps Before Finishing
Once the board is plained flat and smooth round the corners. I used a half dolor to get the desired radius. Make a template of the radius and use it to draw the curve on each corner. Remove the bulk of the waste at the band saw then sand to the line using a disc sander. Now round over the edges again with a ¾” round over bit at the router table. Sand the boards with a random orbit sander to 220 grit. If desired mist the boards with water to raise the grain then sand with 220 again when dry.
Step 19: Seal the Boards
Seal the boards
Clean the dust off and apply a generous coat of mineral oil to all surfaces. Allow to soak in for 10 minutes or so and wipe the boards dry with paper towels or rags. Place narrow stickers under the boards and let them sit for a couple days. Some oil may wick out from the wood so wipe them dry again as needed. To add a final luxury to the finish wax the boards with a edible bees wax finish.
Step 20: Use and Care of Your End Grain Cutting Board
Use your end grain cutting board for all of your slicing, dicing and chopping needs in the kitchen. To sanitize the board after use wash it with mild soapy water. Never submerge in water or place it in the dishwasher. If you’re concerned about bacteria especially after cutting meats use a mister to spray the surface of the board with white vinegar and wipe dry with a paper towel. Proper surface treatment is important to guard against germs and/or mold growth. Cutting boards should be finished regularly (once a moth is optimal) with a mineral oil to maintain their beauty and keep the wood from warping and cracking.
Never use any vegetable or cooking oils to treat or finish the cutting board, as in time the wood will reek of a rancid spoiled oil odor. Wipe the mineral oil on with a clean cloth, let stand for 10 minutes or so and thoroughly wipe dry with a fresh clean dry cloth or paper towels. To further protect and beautify the finish apply a bees wax top coat. Apply the beeswax in much the same manner as the mineral oil. Rub the wax on with a clean soft cloth, allow to dry. Then buff to a lustrous shine using a fresh dry clean cloth.
I hope you found this useful and will enjoy building your own version of these end grain boards.
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    16 Discussions
    Dewoodwork
    6 months ago
    Thank you for the comments, this is my first instructable. I actually did the photos and the write up about this project for a woodworking magazine but they turned it down. Now it’s out there for the Woodworking community for free.
    dadswoodshopDewoodwork
    Reply 6 months ago
    Ha!!! Great Instructable! See.... I told you it was a good idea to post here!! :)
    Clear, easy to follow, excellent photos for guidance... Really well done.
    Can't wait to build one.
    --Allen
    seamsterDewoodwork
    Reply 6 months ago
    The boards are beautiful, as are you photos in each step. Very nicely done on your first instructable!!
    wudwerks
    6 months ago
    Nice job! Do you mind me asking what woods you used and where you got them?
    Dewoodworkwudwerks
    Reply 6 months ago
    Hello, thanks. wood species I used include Maple, White oak, lyptus, purpleheart, bloodwood and walnut. I am able to get all these hardwoods from local hardwood suppliers here in CA. USA. I also work with species like wengee, paduak and cherry.
    Alex in NZ
    6 months ago
    These are beautiful. I've made a chess board using a similar process, but the variety of colours (colors) you've used make for a very dramatic appearance. Thank you for showing this :-)
    DewoodworkAlex in NZ
    Reply 6 months ago
    Thank you and you're welcome. I like to share with the woodworking community. I had the article posted on another site for a few years but the photo host wants to charge me to hot link the photos now.
    Kink Jarfold
    6 months ago on Step 20
    WOW! Your selection of woods and patterns is excellent. And your Instructable is a breeze to follow. Well don, my friend, well done! KJ
    DewoodworkKink Jarfold
    Reply 6 months ago
    Thanks. I made 3 of each in the pic and gave them all away as Christmas gifts. Well...I did keep 1 ; )
    DewoodworkAMbros Custom
    Reply 6 months ago
    Thanks for the complement. I'm familiar with his work, quite inspiring.
