Led Solar Powered
1,346
12
5
About: new science projects, science experiments : rotating magnetic field device - research, small generator using a single neodymium sphere, fidget spinner generator, how to make a simple electric motor, pulse mo...
simple energy recovery sistem using solar panels and led ( without batteries )
Solar panels generally consisting of two layers of silicon - semiconcuctor material and a separation layer, are wired together and assembled into panels or modules.
Step 1: Simple Energy Recovery System
A LED light is capable of being powered by a single low-voltage solar panel.
with this simple system you can recover energy.
http://sciencetoolbar.com
Step 2: Materials :
1.led (from a wasted led bulb)
2.solar panels
3. wires
Step 3: Operations :
1. cut a led from a wasted led bulb
2. connect wires between the solar panels and led
Wrap the positive solar panel wire around the positive terminal from the LED.
Wrap the negative solar panel wire around the negative LED terminal
3. Place the solar panel in a source of bright
(The light source shall illuminate the camera if there is no sun light in the room)
a sciencetoolbar project http://sciencetoolbar.com
  • Build a Tool Contest
  • Pie Contest
    Pie Contest
  • Weaving Challenge
    Weaving Challenge
5 Discussions
sciencetoolbarTsu Dho Nimh
Reply 1 year ago
The light source shall illuminate the camera if there is no natural light in the room
Josh_Blackburn
1 year ago
I'm a bit confused, how is this energy recovery? Is the point just to show that a solar panel produces electricity? Or am I missing something?
