Enhance Sphero Maneuverability With Liquid Latex
2,492
9
5
Sphero robotic ball is a popular robot controlled via bluetooth. The device surface is hard, smooth plastic, which is perfect in terms of device durability, however on most surfaces Sphero slides too much, harming its maneuverability.
Sphero vendor provides a cover for Sphero to deal with this maneuverability issue - the cover is called Nubby Cover. However, from my experience Nubby Cover has following disadvantages:
  • too thick
  • its offroad-like nipples downcrease the maneuverability and fine-tuning of sphero movements
  • you have to remove the cover from Sphero prior to charging
  • overpriced (~16 USD)
Due to this reasons, I ordered 250ml of Liquid Latex from eBay (price ~10 USD) and tried to cover Sphero with latex.
Step 1: Use Holder to Fix Sphero
Use some holder to keep Sphero from moving. I use the a clip holder for soldering.
Step 2: Minimize the Contact Surface
We want as much of the area of Sphero to be covered with latex, so that we use narrow pins to keep the Sphero in fixed position.
Step 3: Protect Your Table From Latex
Put some plastic cover below the holder - when you will paint the Sphero with latex, redundant latex will drop off.
Step 4: Prepare Latex and Painting Brush
Put small amount of liquid latex into a pot and prepare a brush for painting.
Step 5: Cover Sphero With Latex
Use brush to apply thin layer of latex onto Sphero surface. If the latex layer is too thick on bottom of the Sphero and too thin on its top, wait a minute and use brush to "redistribute" the latex more properly. Try to keep the layer as thin possible, you can always thicken the latex layer later.
Step 6: Wait Until Latex Is Dry and Test the Charger
Once latex is dry, check Sphero surface. If you applied only thin layer of latex and did it properly, the latex layer should be barely visible. Put your Sphero on contactless charger to make sure it is being charged properly.
Step 7: Drive Sphero
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    5 Discussions
    rockerape
    4 years ago on Introduction
    I want one of those toys. Hey how about cutting a condom or a balloon in the shape of a ring and wrap it around the Sphero? with two or three rings you can cover at least 70% of the ball? I think that will work too.
    TangMurockerape
    Reply 2 years ago
    I've just done a similar thing with party balloons (because they don't have a teat on the end you can cut it so there's only one opening. It has become grippier but picks up all the dust off the floor and it is harder to see the lights through (I went for 6 to try and give it a bit of a cushion. I might try removing a few to see if it helps with the brightness (also they are plain white balloons which isn't helping the transparency x_x - I will see if I can find clear ones)
