Enhanced Scuba Gloves
1,583
6
6
In this project, we will be making a pair of Enhanced Scuba Gloves. They will include webbing between the fingers, an underwater flashlight, and a grappling hook. These gloves are super easy to make and everything is removable. We will be running a full test on speed, sight, and strength of the grappling hook. To watch it, click this link: (Coming Soon!)
Supplies:
Step 1: Materials List
You will need:
-Webbed Rubber Glove (x2)
-Underwater Flashlight
-Battery (Whichever Kind Powers Your Flashlight)
-Velcro Straps (Underwater Capable)
-Rope (Strong and Thin Recommended)
-Grappling Hook (Small Enough to Fit in Your Hand)
Tools Needed:
-Scissors (To Cut Velcro Strips)
-Exacto Knife
Step 2: The Flashlight
To start off our gloves, lets begin by taking 2 strips of velcro, and attach one to your glove (Whichever one is easier) and the other to the bottom of your flashlight. You want to make sure that the "on" switch is able to be accessed with ease. The reason we are using velcro here is because you want to be able to remove your flashlight when needed.
Step 3: The Grappling Hook
With your grappling hook, you will want to attach the velcro (velcro 1) to only one side of the string, and attach the opposite kind of velcro (velcro 2) to the bottom of the velcro on the string, thus making a latch. On the glove (the one that doesn't have the velcro for the flashlight) attach some velcro (velcro 2) to hold it in place. Once you put that down, use your exacto knife to poke a hole in the middle of the velcro (velcro 2 on glove) so you can put the side of the string without the grappling hook through to make sure you don't lose it.
Step 4: You Are All Done!
After these simple and easy-to-follow steps, your Enhanced Scuba Gloves are totally functional and ready to use! With these gloves, you should be able to swim faster, see better underwater, and be able to latch onto objects as a holding point! We hope that you enjoyed this project, and do not forget to share this inscrutable, favorite it, and definitely tell us if you ended up making it! We had a great time making it and we hope you try it out yourself
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    6 Discussions
    caleb16204
    2 years ago
    remember to follow and favor it
    caleb16204
    2 years ago
    follow both of us and we will try to make more
    BennyD2618
    2 years ago
    thanks "DIY Hacks and How tos" it means a lot. btw caleb 16204 is my partner
    caleb16204
    2 years ago
    thank you. If you have the right things you can do so much
    yemerson18
    2 years ago
    great job Benny
    That is in an interesting combination of tools. Batman would definitely use one of these.
