Etching Glass With a Rotary Tool
32,081
403
43
Decided to make this tutorial about etching glass with a rotary tool. Had no idea how it would work out but I'm quite pleased with the result. Usually I work with wood so figured this would be a nice project for Beyond the Comfort Zone contest since I haven't had any experience in working with glass.
Step 1:
You will need a printer to print out your designs which you will later trace on the glass. My friend made these in Photoshop with a 10 degree curve so they would end up straight when transferred to glass. You can just print out anything and trace it but then your lines will look a bit crooked on the glass because of the curvature.
Other stuff you need is a pair of scissors, masking tape, rotary tool and diamond tip bits. I bought my bit set for 5$ on ebay.
Step 2:
Cut out your picture and place it in a glass. Secure it with masking tape so it doesn't move.
Step 3:
Securely grip the glass in your hand. Grab the rotary tool like a pen and start tracing the image. Sadly I couldn't take a picture of how I'm actually holding both the glass and the tool but it should be fairly simple to understand by looking at the pics.
Step 4:
Outlines traced and paper inside removed. You can opt to finish at this point.
Step 5:
Filling the insides of the trace. I found that having a dark background makes it much more easy to see what you're doing.
Hope you like the tutorial and have fun etching!
Beyond the Comfort Zone Contest
Third Prize in the
2 People Made This Project!
  • Sweet Treats Challenge
  • Warm and Fuzzy Contest
  • Organization Contest
43 Discussions
blue LED
2 years ago
Thank You, for a clear, concise instructable. Strangely enough just two days ago I was looking at a neat shaped drinking glass in a thrift store and thinking "wouldn't it be cool to put a design in that?" . Now I know how. Off to the store!
merideth
2 years ago
Nice! Great tip on adding the curve to the artwork.
darthwolfmerideth
Reply 2 years ago
Cheers, turned out to be a nice solution for irregularly shaped glass.
syn123
2 years ago
Nice!
eagle4297
2 years ago
I have been doing this for several years now, gave each member of my congregation where I attend an etched mug with a cartoon depicting what their job was. Had fun with an older gentle man who many many years ago fell asleep under a tree while plowing wth 2 mules. Put the man plowing on one side and the man sleeping on the opposite side. They were all a great hit. Did I mention that I got cases of glass mugs from the family Dollar tree.
It don't take a genius to do this, only one with a willingness to devote time to doing something for someone else.
MYTraveler
2 years ago
What does 10 degree curve mean and how do you achieve that? Is there a setting somewhere in printer software?
Nice work?
darthwolfMYTraveler
Reply 2 years ago
As my friend explained it to me, there is some sort of a perspective tool in Photoshop that wraps the image into a cone. Sadly, no, there is not a setting in printer software where you could adjust that.
However, if you need Photoshop the CS2 version is legally obtainable for free from Adobe's site!
Rinner_Rabbitdarthwolf
Reply 2 years ago
Also, pixlr.com is a free online version very similar to photoshop.
Reply 2 years ago
mordicus93darthwolf
Reply 2 years ago
Could you ask your friend where on PS did he finds the perspective tool you speak of please ?
I'll need it in order to try some too ^^
Thx in advance.
ChuckieBob58mordicus93
Reply 2 years ago
I can answer that. I have CS2. Go to Edit>Transform>Perspective. I altered the image first, then did the screenshot to show you. There's no dialog box to put in 10 degrees or any such values, you have to eyeball it.
darthwolfmordicus93
Reply 2 years ago
Friend go back to me, said it was Edit>Transform>Warp and then to
choose a style from it. He's working with CS6 though so I can't confirm
that the same thing exists in CS2; hope it helps.
NihilFBMYTraveler
Reply 2 years ago
You only need to adapt your starting image with such curves if the sides of the glass that you're engraving are not parallel (hence using a correction angle that matches the slant of the glass).
I usually engrave images onto cylindrical glasses or cuboid flasks - the parallel sides mean no need to adjust your template (other than scaling)!
(Nice 'ible though darthwolf!)
mordicus93NihilFB
Reply 2 years ago
True, didn't think that i could use straight glass too :D
Thx.
pookiesmum
2 years ago
I find using a dust mask a good idea doing glass rotary etching. (there are no splinters). I also use a magnifying light which makes it easier. Try making a bag filled with rice to hold your glass, Your glasses look great.
