Experimenting: Yeast, Hydrogen Peroxide Chemical Reaction (fire)
107,793
23
45
Experimenting with Yeast and Hydrogen peroxide. When Hydrogen Peroxide (2 H2O2) reacts with yeast it makes water (H2O) and Oxygen (O2) 2 H2O2 -> 2 H2O+O2 im just board and want to share my chemical reactions with others.
It relights the piece of wood because the air inside the cup is so rich it changes the flash point (correct me if im wrong)
Supplies:
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    45 Discussions
    ChemGirl
    6 years ago on Introduction
    Hi i make shooting things!
    I'm ChemGirl and I noticed that your post information is incorrect. Your chemical equation is incorrect, because you for got to add the chemical formula for yeast. However, since yeast is a complex structure, there isn't a chemical formula for yeast.
    Thanks!
    PashaA4ChemGirl
    Reply 2 years ago
    Yeast is a catalyst and does not undergo a chemical change and therefore is not written as part of the chemical reaction but noted above the arrow.
    zir100102
    3 years ago
    You spelled board wrong it's bored.
    reywolfhobobling
    if the gas is heavier than air you can pour it, if it is lighter than air you cant. http://chemistry.about.com/od/funfireprojects/a/candle-science-magic-trick.htm for reference
    hoboblingreywolf
    Yes, however O2 is not significantly heavier than air, and in this situation there was no gas being poured.
    UrbanNinjaUrbanNinja
    ...and yes I know that you would have to light it first. I am just curios if it would make lighting a campfire easier.
    adsa
    Liver may be used with hydrogen peroxide for a similar reaction, in which catalase is produced liberating lots of oxygen, at which point you can use a candle or similar for re-ignition
    codongolevhalogirl
    everything cool has science in it. like, for instance, if you burn something with liquid oxygen, the oxygen rich environment makes it explode. which is cool.
    El Manohalogirl
    This is dangerous when you mix the resulting oxygen with something like hydrogen, gasoline, or anything that burns. There's a reason oxygen canisters have a warning about not operating near a flame, cigarette, etc.
    geeklord
    I love simple pyro experiments like this. Any other ones that someone can suggest? I'm working on getting potassium nitrate for flash powder/smoke bombs, but I have magnesium.
