Ez Arduino Spidey - Making a 12 DOF 3D Printed Quadruped Robot
16,228
128
37
About: We love robotics!
This is an inexpensive 3D printed 12 DOF quadruped robot using Arduino kind control board. It has two playing modes. One is autonomous pilot mode which the robot walks and performs actions randomly. This is the default. The other is control mode where the robot is controlled by iPhone or Android phone via BLE technology. This page should guide everyone to make one easily.
Supplies:
Step 1: Printing 3D Models
Download the 3D printed STL models files here. Suggested parameters for slicing the models to print are as followings. You may adjust them to fit the 3D printer you're using. If you don't have a 3D printer, you may find online 3D print service.
  • bottom/top thickness: 1mm
  • shell thickness: 1.2mm
  • ayer height: 0.2mm fill
  • density: 10%
  • support: yes
  • adhesion type: skirt or brim
Step 2: Software
Software are free to download:
uploading the Arduino code by open firmware.ino in the Arduino Software, see step 10 on IOS app and step 11 on Android app to control the robot.
for HuaDuino, in Arduino IDE software:
  • the board selection: "Arduino Nano", processor "ATmega328" for AVR Boards support version 1.6.20 or older.
  • the board selection: "Arduino Nano", processor "ATmega328 (Old Bootloader)" for AVR Boards support version 1.6.21 or newer.
Step 3: Hardware
The components can be found in ebay, amazon, aliexpress, DX and etc online store.
  • a HuaDuino board, it is Arduino Nano compatible with enhanced features. It integrates everything on a single PCB. It's a lot easier for people to make a bot with it. Embedded battery charging circuit, battery charging is more convenient. It can be found on Amazon and ebay.
  • a single 3.7V 18650 lithium ion battery or battery pack with XH2.54 connector, if you want longer running time getting a pack with two 18650 in parallel. You may like to use this 18650 battery holder. However, it is also fine to use 3.7V 10440 lithium ion and 3.7V lithium polymer battery dimension not bigger than W35mm, L70mm & T60mm.
  • 12 x Tower Pro SG90 or compatible 9g servos.
  • a female-female dupoint wire or anything you can figure out for connecting two pins
  • some m2x6 tapping screws
  • a BT-05 CC2540 Bluetooth BLE module - this is optional if you don't need App control. Baud rate is required to set to 115200. For iOS app, the service UUID must set to 0xDFB0 and characteristic must set to 0xDFB1. Below is the code to do that automatically. Attached is the reference of the AT command set to configure CC2540.
The following Arduino program issues AT commands setting BLE module service UUID, characteristic ID and baud rate, assuming the BLE default baud rate is 9600. For running below code in HuaDuino with the module onto it, the S1 switch must be set to the BT position.
void setup() {
  Serial.begin(9600); //change to fit your BLE initial baud_rate
  Serial.println("AT+UUID0xDFB0\r"); // uuid
  delay(50);
  Serial.println("AT+CHAR0xDFB1\r"); // characteristic
  delay(50);
  Serial.println("AT+BAUD8\r"); // set baud rate to 115200
void loop() {}
The steps you should do of uploading the Arduino sketch to HuaDuino for BLE control are as following
  1. insert the BLE module, switch S1 to USB side, turn on huaduino,
  2. uploading the above ble module setup program
  3. turn off huaduino, switch S1 to BT side
  4. turn on huaduino, let the ble module setup program run in few seconds.
  5. switch S1 to USB side
  6. uploading the robot program
  7. switch S1 back to BT side, the robot now can be controlled by BLE
Step 4: Installation of Servos and the Control Board
Step 5: Legs
Step 6: Servo Wiring
Connection to digital pins of HuaDuino are as followings:
  • D2 to front right femur servo
  • D3 to front right tibia servo
  • D4 to front right coxa servo
  • D5 to back right femur servo
  • D6 to back right tibia servo
  • D7 to back right coxa servo
  • D8 to front left femur servo
  • D9 to front left tibia servo
  • D10 to front left coxa servo
  • D11 to back left femur servo
  • D12 to back left tibia servo
  • D13 to back left coxa servo
Step 7: Calibration
Using a female-female dupoint wire between A5 and 3.3V pin, the robot servos will be set to default reference angles. This is the status for installing servos and having servo arm capping on the correct angle.
Step 8: Installation of Servo Arms
while the female-female dupoint wire connected between A5 and 3.3V pin, puts the servo arms to the servo shaft
Step 9: Finishing Up
insert the CC2540 Bluetooth BLE module to the board's Bluetooth connector, and slide the S1 switch to the BT side, finally closes the robot with the top cover and eyes.
Step 10: Plays Using IPhone
To success doing this part, you must configure CC2540 Bluetooth BLE module, see the step 3 - hardware
  • opens the iOS app and closes it the robot
  • after few seconds the BLE paring between the robot and iPhone should be done, you will see the connection symbol changed to green
  • press the top middle virtual button will switch the robot to control mode
  • press bottom middle virtual button will turn back to autonomous self walking mode
Step 11: Plays Using Android Phone
  • open the Android app while robot is on pressing the connection symbol closed the top edge
  • after few seconds you should see listed BLE device and select it and connection symbol should turn to blue when successes
  • press the top middle virtual button it will switch to control mode
  • press bottom middle virtual button will back to autonomous self walking mode
Step 12: Battery Charging
  • plugs a 5V power source micro USB cable to the robot USB port
  • a red light indicates charging
  • a green light indicates charging completed
Make it Move Contest
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    37 Discussions
    Adriouz
    Question 5 weeks ago
    Hello Manic, thank you for giving to everyone the opportunity to built a robot. That's a great project for beginners like me!
    I just've just tried to turn on my spydey robot and it's a failure... The spider reacts oddly. She is shaking and she can't carry herself. I attach a video.
    Do you konw what could be the solution?
    Thanks in advance.
    manic-3d-printAdriouz
    Reply 5 weeks ago
    cannot open the video, can you upload to youtube and share the link here?
    Reply 5 weeks ago
    you didn't do correctly on step 7 and 8, the sevos are not on the correct angle before you put on the servo arm and applying the screw.
    Miklash
    Здравствуйте, спасибо большое за Ваш проект. Я собрал робота на Arduino nano, робот передвигается в автономном режиме. У меня есть Bluetooth HC-06, подскажите пожалуйста как правильно подключить его к Arduino, и настроить. Заранее спасибо.
    1 answer
    manic-3d-printMiklash
    Reply 5 weeks ago
    This robot is not using hc-06, but the BlueTooth LE module BT05, building instructions are fairly clear. Since you used different electronics it is hardly to give you advises.
    johweb
    6 weeks ago
    Hello. Nice spidey ! ;)
    I built it and autonomous mode is working fine. So I wanted to try the control mode.
    BT05 is seen by PlayBLE, but icon stays orange, I can't control it... Is there any test I can do ?
    Thanks in advance.
    manic-3d-printjohweb
    Reply 5 weeks ago
    Verify the UUID and CHAR of BT05 are set correctly, see Step 3.
    johwebmanic-3d-print
    Reply 5 weeks ago
    You're right. I did the step 3, but without checking.
    I realize now that I have a cheap BT05, and it doesn't keep UUID and CHAR. Thanks for your help, it's on my side now to have it working !
    leemillard
    2 months ago
    I have just finished this robot and its very jerky, and 1 leg shakes like mad extremely quick, any ideas ? i've bought all the exact parts as mentioned.
    Tomerfre
    Question 5 months ago on Step 3
    Hello
    I finish building the robot.
    When I try to uplaid the Arduino SW I always get this message:
    Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
    Sketch uses 26366 bytes (85%) of program storage space. Maximum is 30720 bytes.
    Global variables use 906 bytes (44%) of dynamic memory, leaving 1142 bytes for local variables. Maximum is 2048 bytes.
    avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
    What I'm Doing wrong?
    Thanks
    Tomer
    manic-3d-printTomerfre
    Answer 5 months ago
    Arduino IDE didn't find the COM port. Did you install the usb driver? If you did, you might select the wrong port. You can use the windows device manager to see which COM port it is. And you can try to disconnect and connect again the USB cable, it will be more obvious to see it in device manger.
    Tomerfremanic-3d-print
    Reply 5 months ago
    Thanks for your replay
    The issue was an incorrect programmer, the correct is Arduino ISP.
    Now I have an issue to connect to the BLE my phone doesn't recognize my cellular phone (Samsung Galaxy S8 )
    I get the message BT05 reject the pairing
    Any suggestion?
    Thanks and have a great day
    Tomer
    lef11
    Question 7 months ago
    Can you please send me a description of how this receives input?
    I want to make a controller for it but i am not completely understanding what you are doing with the input.
    MilanL1
    hey i just got my huaduino board from the link you posted and when i connect only one leg the leg works but when i connect all of them its like it has no power it turns off... i tried with nano and the robot shield and it works but i bought this one so it will work niceley. Any suggestions ?
    haitham10
    7 months ago
    GOOD ROBOT >BUT I CANT CONTROLED BY BLUETOOTH CAN U HELP ME ???
    ncostis
    9 months ago
    i cannot seem to be able to upload the code to huaduino.
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x79
    avrdude: stk500_recv(): programmer is not responding
    is it possible to share the setting of the arduino for huaduino?
    manic-3d-printncostis
    Reply 9 months ago
    it may due to 1 - you didn't turn on the power switch, 2 - the S1 switch wasn't on the USB side, 3 - you had the servos connected that causing usb port failed to power up the board properly.
