FOBO Bipedal Walking Robot
54,493
330
37
FOBO is the fourth prototype from Project Biped.  It is a 3D printed, self-contained, statically balanced, bipedal robot. It has 8 DOF (degrees of freedom) and can walk around its environment and avoid obstacles using an ultrasonic range sensor.  All of the designs, instructions, source code, and parts lists are provided for free.  FOBO was designed to be easily made by anyone with a low cost 3D printer and an interest in learning about robotics.
Supplies:
Step 1: Static Walking
FOBO walks statically meaning that at every frame of the animation it is balanced and won't fall over if it stops.  The walking cycle is 10 key frames with 10 frames interpolated in between each frame.
Step 2: Get the Parts
FOBO uses an Arduino Uno microcontroller to actuate 8 servo motors.  It also has an ultrasonic range sensor so that it can walk around without bumping into things.  FOBO is powered by a rechargeable lithium ion battery that lasts for a couple of hours on a full charge.   All of the parts together cost about $200.  Here is the full list of the the parts along with links to the vendor, price, and quantity.  Note that none of the vendors listed are affiliated with Project Biped ... they are just where I bought my parts from.  If you find a part cheaper from another website let me know and I'll update the list.
Step 3: Print the Robot Parts
FOBO is made up of 17 3D printed plastic parts.  The full list of diagrams showing where each part goes can be found here and all 3D stl files for each part can be downloaded here.    I printed FOBO using an open source Makerbot Thing-O-Matic 3D printer.  All of the parts can be printed in about 18 hours (depending on your printer and settings) with about $10 worth of plastic (193 cc is about 1/5th of a standard spool of plastic).
Step 4: Set Up the Servos
FOBO uses 8 servos to move around.  These need to be aligned before construction begins to make calibration easier.  You can access the presentation with animated instructions here (the image is a screen shot of the presentation).
Step 5: Assemble the Right Leg
FOBO's right leg has 5 printed parts and the following :
4 servos
2 screws  3M 16mm
2 screws  3M 12mm
4 screws  3M 8mm
1 nut 3M
Step 6: Assemble the Left Leg
FOBO's left leg has 5 printed parts and the following :
4 servos
2 screws  3M 16mm
2 screws  3M 12mm
4 screws  3M 8mm
1 nut 3M
Step 7: Assemble the Frame
FOBO's frame has 4 printed parts and the following :
2 radial ball bearings
2 washers
2 screws  3M 16mm
6 screws  3M 12mm
4 screws  3M 8mm
1 Arduino Uno board
1 Arduino Servo shield board
Step 8: Connect the Electronics
FOBO's has the following electronic parts :
4 servo extension wires 6"
2 sections of wire wrap 14" each
1 rocker switch
1 fuse 5 amps
1 DC to DC voltage regulator (5v/6v)
3 solderless wire connectors (female)
Step 9: Put the Head and Battery Case On
FOBO's head is two printed parts and the battery case is a single printed part.  The other items that you'll need:
1 lithium ion battery 2 cell 7.4v
4 screws  3M 20mm
4 screws  3M 8mm
You can access the presentation with animated instructions here (the image is a screen shot of the presentation).  Please be careful when using the LIPO battery and follow all safety instructions!
Step 10: Calibrate the Servos
Time to calibrate FOBO's servos.  This is necessary because the it is impossible for everyone to assemble the servos in exactly the same orientation.  So the calibration describes the unique servo offsets for a specific FOBO.  This allows every FOBO to use actions created by someone else. You can access the presentation with animated instructions here (the image is a screen shot of the presentation).
Step 11: Let FOBO Roam!
Upload the navigation program to FOBO and let it walk around!
Step 12: Create New Actions
You can use the free Poser application to create your own custom animation sequences for FOBO.  Save the actions to file and share them with other FOBO makers.  The image is a screen shot of a step by step tutorial that shows how to use the Poser application to create a new action for FOBO.
Step 13: Program FOBO
There are more applications, such as controlling FOBO via a Kinect, available at the FOBO website.  As always everything is provided free and all of the hardware and software is open source.  Have fun and share your creations!
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    37 Discussions
    Fastmill88
    2 years ago
    hi I am fast mill 88 aka real name Indy P Doungpanya, I really like how you created fobo he is just so cute and so futureistic and i like to make hover converting things so thanks alot
    peraz91
    2 years ago
    Help me please
    rohals
    5 years ago on Introduction
    please suggest the proper program or proper arduino coding for servos bcoz i followed all steps u suggested but while compiling its showing error and code is not processing further so please suggest proper and right coding as soon as possible...
    Ditch the Arduino bootloader and go C. Our emch engineering student had a golfball collecting robot challenge which I sold some bigger steppers motors to, they didnt need them as after changing to C it was running faster...
    botguy24
    7 years ago on Introduction
    Yet again wow! your bot looks so professional! It moves so smoothly too. must have been fun getting it to balance with that big box on top!
    jdowdallbotguy24
    Thanks! There were lots of face plants while I was working out the walking cycle ... but that was half the fun. Future designs will have the batteries in the feet to help with the weight distribution.
    JimRDjdowdall
    Reply 3 years ago
    May have a problem with the batteries in the feet as the servos will not be able to work as well as when the weight is higher up and just shifted over the inactive servos. I know because I had the same idea with a robot I built and with the batteries down low, it wouldn't step as well. It's all about leverage.
    BrandsO
    3 years ago
    Heyy) where I can find the code?
    Cant you get the static walk cycle to place the balance leg UNDER (ie move it inwards to balance before putting the foot down) the robot rather than use the big lean out angle you have. It would look more natural. I wana build a Reaper from some game I used to play, it needs to 'march' and 'stomp'..
    yunkun88
    3 years ago
    This is a very funny robot, I want to do it
    Arduino Tech
    4 years ago on Introduction
    it says :
    This report would have more information with
    "Show verbose output during compilation"
    enabled in File > Preferences.
    Arduino: 1.0.6 (Windows XP), Board: "Arduino Uno"
    Remote_Control.pde: In function 'void SendResponse()':
    Remote_Control:167: error: 'BYTE' was not declared in this scope
    As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
    Please use Serial.write() instead.
    WHAT SHOULD I DO ???????
    kprasad6
    4 years ago
    Hello sir i m from india.I have made this robot bt as i m a beginner so quite unfamilier with arduino programming.I have used arduino and 16 servo controller shield for controlling the robot moments.I have read the navigation program of FOBO and felt some problem in some steps.Sir plzz explain me how FOBO moves forward as written in navigation program of FOBO so that i can modify and write code for my robot.And thnxx sir for sharing this articles.
    my email adress is anantprasad2222@gmail.com
    plzz sit help me in programming my robot.I wil be highly thankfull for you sir plzz plzz.
    gogcoding
    Hello jdowdall, I like it, but it would be nice if you followed what Rohals said about "suggest the proper program or proper arduino coding for servos bcoz i followed all steps u suggested but while compiling its showing error and code is not processing further so please suggest proper and right coding as soon as possible…"
    I already got really far and spent money to buy the pieces. That would be great if you could provide me with the coding part. Thx.
    kms62
    were can i get the fobo 3d parts to build?
    naorocks
    4 years ago
    I hope I can build one
