Fairy Wing Harness DIY
732
5
About: I'm just a poor high school student who loves video games, pasta, and sleeping in.
Ahh yet another tutorial for the renaissance fest. Because I am going to be a scrappy fairy I needed a scrappy set of wings. This harness also holds the mask I made for a competition, so it serves a double purpose!
This build cost about $20 dollars and took about 5 hours to complete.
Step 1: Materials
- Random thrift store finds (I used a red bandana, a belt, a scarf, and two ties)
- Needle and thread
- Feathers (I used dyed roaster tails)
If you are making a mask holder you will also need
- 2mm craft foam
- Worbla
- Magnets
Step 2: Sewing the Straps
I wrapped the belt around a mannequin. The harness is made of 3 straps. Two are made from neckties ( the left strap, and the back strap), the other strap I fashioned out of half of a bandanna that I weathered with washes of white, brown, and black paint. I sewed a corner of the bandanna to the belt and tied the other corner to a scarf. I also sewed the two neck ties to the belt.
Note: I only sewed one side of the straps to the belt because I will be looping the other end to the wing holder.
Step 3: Mask Holder
Because this harness doubles as a mask holder, I needed something to hold my mask. I molded a face like blob (I think it looks kind of like a sloth face) out of clay. I heated up a sheet of worbla and carefully molded it over the clay. After I had the shape of the worbla crafted. I put a magnet in nasal region of the worbla cusp (sadly I forgot to take a picture of me attaching the magnet, but pic 3 has a note where I put the magnet).
I cut a sort of triangular shape out of foam and heated a piece of worbla over the foam for strength. I carefully attached the worbla sloth face to the foam/worbla with a little heat. I cut 3 rectangular shapes in the foam/worbla for the straps to loop through, then sewed the straps in.
The last picture is of the magnet I fixed in my masquerade mask.
Step 4: Feathers
If you are not making a mask holder at this point just glue feathers to the worbla and foam back plate, and for the most part I did that as well. However I also made magnetic feather bunches that attach to the wings, and can also attach to my mask. For more info about the feather bunches check out my mask tutorial
Step 5: All Done
Because of the mask and magnet talk this tutorial may be a bit confusing. However it really is just a back plate with feathers on it supported by straps. If you have any questions about this build feel free to message me or comment below :)
If you would like to see how I made the rest of my costume:
Fairy Mask
Tattered Dress
    • Paper Contest
      Paper Contest
    • Weaving Challenge
      Weaving Challenge
    • Tape Contest
      Tape Contest
