Fallout 2 Veterans Helmet Build
33,219
518
79
About: just a guy who likes robots, sci-fi, computers and prop making on a very tight budget.
Ever since I read about pepakura helmets, I wanted to build my own. My first attempt was the classic master chief helmet, sadly I was not able to complete it since the cardboard material, I got was to thin and flimsy. My 2nd attempt was an Ironman helmet. Although I was able to complete it, I did not like the way it turned out. So I gave up on pepakura until I came across this link:
http://www.therpf.com/f24/fallout-new-vegas-ncr-ve...
The problem I had with pepakura, is that I always end up with a flimsy looking build. I was not willing to work with fiberglass as we have kids running around the house. what I needed was something to make it solid enough to wear but does not require any special handling procedure or equipment. I read about plaster and glue sticks as alternatives and those are materials I was happy to work with
So here is my 3rd Pepakura build...Fallout 2 veterans helmet.
***update****
My friend updated this build and put up an antenna and LED lights. He also started wearing this together with the vest. :)
Step 1: Materials:
Stick with the basics: Pepakura files are available here:
http://www.therpf.com/f24/fallout-new-vegas-desert...
or you can search on the web for other versions.
  1. cardboards
  2. x-acto knife
  3. glue gun / glue sticks (a lot of it)
  4. plaster of paris
  5. foam
  6. watercolor *optional
  7. spray paint (primer, clear coat, metalic silver and flat black)
  8. plastic sheet for the mask lens
  9. a shower hose or BX cable for the oxygen hose that will stick out of the gas mask.
  10. elmers glue
  11. instant glue
as with any pepakura builds, you print the files and cut them up, fold and stick them together. I found out that it's always easier to pick a portion of the build you want to start at first, cut those and assemble it. rather than cutting everything up and looking for the numbers that match. You can use elmers glue, instant glue or gluegun during assembly. I opted for the glue gun since it made the joints more rigid and stable. Although you really need to work fast with a glue gun.
Step 2: Fitting the Lens and Reinforcing the Joints
After everything has been assembled. It's time to make the lenses. I used an old red plastic sheet cover from a ring binded document I have, any clear plastic would also do. I used this as it was easier to cut. Dont glue it up yet, just see if it fits.
Time to get those glue sticks. what I did was go over every joint of the helmet (on the inside ofcourse) and fill every gap with the glue gun. This made the helmet sturdy enough to be worn. Another method suggested that you melt the glue sticks and pour it on the inside of the helmet. I'm sure that method would be better but as said we got kids running all over and having melted plastic is never a good idea.
You can now start putting plaster on the helmet. I was not able to get a photo of it, since working with plaster meant mixing and splattering. hard to press on a camera with plaster on your fingers. I also put elmers glue on the plaster mixture so it will dry faster.
After drying you need to sand off the rough edges.
Step 3: Spray on the Primer
Make sure the plaster is really dry. Go on and spray paint the whole thing atleast 2 coats. then go back and sand it off. You can either wait until you finished painting the helmet with flat balack before putting the foams in so it will fit on your head or put them on before you spray paint with flat black. I inserted and glued the foams before as flat black application since I wanted everything painted black.
Step 4: Accessorize
I got a lot of electronic junk, including old webcams and old cellular phones. took anything that was light enough to glue on the helmet. The blood red is actually water color (poster paint). I made a template for the logo and just spray painted using the silver paint. I spray painted the red poster color with clear coat just to keep it from fading. Yes, finally you can put on the lens. There you have it. :) Gave this to a friend who was into cosplay.
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest
    Paper Contest
79 Discussions
NickC270
Question 8 weeks ago
Hi I was going to build the helment for a convention this summer, but on the PDF there are no guide lines after page 9. Is there an error with the file?
riocruzNickC270
Answer 5 weeks ago
Hey NickC270, check out my reply below. Can't edit the instructables right now to replace the PDF, but was able to attach the file on the reply.
Hope this helps. And thanks for commenting. Happy building.
riocruzNickC270
Answer 8 weeks ago
Looks like something went wrong when the file was uploaded. You may need to use the pdo files as I can no longer find the original pdf files. Sorry. :(
*****update******
good news I managed to find a file in my email. enjoy making this.
duje.vjesnica
1 year ago
if at all possible it would be nice if you would answer in a window of a few hours since id like to make it as soon as possible. thanks once again
riocruzduje.vjesnica
Reply 1 year ago
sorry, been busy with the holiday rush and all. I'll try checking in more often.
duje.vjesnica
1 year ago
i made it with the antenna and some lights around the "lenses".
in my opinion it looks amazing especially with the vest and the coat not to mention even better when you hold a db shostgun. also i want to thank you for making my cosplay life easier as well.
duje.vjesnica
1 year ago
also quick question: some of the pages dont have visible lines....is this supposed to happen or am i just screwing up?
Reply 1 year ago
in pepakura viewer you can adjust the line thickness to make it more visible. Also use vector printing. you can see all these options under the printer settings.
Archer2500
2 years ago
hey again-
Sorry to bother you with so many questions. Finishing and merging the mask and tail parts together, I don't seem to understand how to wear it.
riocruzArcher2500
Reply 2 years ago
This build comes in 2 parts. One is the helmet and the other is the mask. You wear the mask first like a regular face mask and then simply put on the helmet like a hat. In my case I made some adjustments on the mask so it will my face. You may use velcro or just a string to tie it in place. As for the helmet you can put foam paddings like I did so it will sit perfectly on my head.
riocruzArcher2500
Reply 2 years ago
each side is attached to each other. it's up to you if you want to trim it shorter or extend it a bit so you can slip it on your head. Or you can put velcro on each side so you can open it up and fasten it when wearing it.
Archer2500riocruz
Reply 2 years ago
ah, alright. Thanks so much for the help, will probably upload photos if project is satisfactory.
Archer2500
2 years ago
What is the curved piece under the left floodlight of the helmet?
riocruzArcher2500
Reply 2 years ago
it's just part of the pepakura assembly.
Archer2500riocruz
Reply 2 years ago
The linked files don't seem to have it
Archer2500
2 years ago
Hello, what was the paper used, what solution was used for the tissues and what were the dimensions of this helmet?
