Fallout 3 Food Lables
67,519
268
36
This Instructable will briefly go over the process I used to make these food Items from Fallout 3.
Step 1: What You'll Need
You will need
-Modge Podge (or the glue of your preference)
-Foam Brush / Paintbrush
-Scissors
-A small box of Jello (For Insta Mash)
-A Can of Something (I used corn (For Pork n' Beans))
-A Box of Mac and Cheese (Umm, for Mac and Cheese)
-Bottles of Coke (For Nuka Cola)
-The Labels Below
-A Printer
-Image Editing Software
But Where can I find X ?
- I got the Coke from the Hispanic Foods section of Smiths. It is Coke De Mexico
- Free Image editing software: IrfanViewThe Gimp
Edit: 6-18-2010
- I added a Sugar Bombs Label  as per KneeCapHill's Request.
Since I tried to keep them printable on a standard printer it is in three pieces(front, top, and side). I also tried adding them as .pdfs which I don't know if that will help anyone or not. It's based on a 14oz (396 g) wheat chex box.
Edit: 8-24-2010
added .pdf files of  other labels per coppeis' request.
Step 2: Go to It
1. Measure the surface area of the Item you wish to apply the label to
2. Re-size the label in your image editor to be sure it fits.
3. Print out the label(s) you want to use.*
4. Cut out the Labels. **
5. For boxed items Fold along the lines
6. "Dry fit" the labels to be sure they are the right size
6. Apply a thin layer of Modge Podge / glue to the Item you are re-labeling.
7. Carefully line up the label BEFORE it touches the glued surface.
8. Work from the middle out to smooth the label into place.
9. Apply a thin layer of glue between any overlapping areas.
10. Brush a thin coat of glue to the outside of the label.
11. (Optional) After allowing to dry use Sand Paper to give the label a worn feel as well as look.
Notes
Click Here to see an Instructable on making Nuka Cola Quantum
I can't emphasize enough the use of THIN layers of glue. If you go and gob a bunch on there not only will it take for ever to dry but it will make you labels all wavy and bumpy looking. (which I suppose you could just blame on 200 years of lying around an irradiated wasteland)
I made all these label from scratch based on Info I found on the Fallout 3 Wiki.
* You will need 2 of the Blamco Mac and Cheese Labels to cover an entire box of Mac and Cheese.
** Look at the way your box is made. You want to cut out and glue down the Label in the same way.
As always "Share and Enjoy"
  • Jewelry Challenge
    Jewelry Challenge
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
36 Discussions
spark2FLAME
8 years ago on Introduction
Wow! Awesome job! Definitely know what I am making for my Fallout Fan Friends. The Nuka-Cola Quantum is especially appealing.
tocsikCrabby
I just tried to bend the cap as little as possible in taking it off then put some hot glue in it an pushed it back on. Just make sure that the cap and rim are completely dry. I haven't had any problems with mine leaking to date. But then it mostly just sits on a shelf. I'd love to hear any other ideas for re-sealing that folks might have though.
Lego_With_Harry
2 years ago
So for anyone else who was doing these projects with GIMP and couldn't find the correct sizing, here's what to do...
-To edit the sizing of the picture, at the top of the screen click image, then go to scale image.
-the next part will be the part you won't want to do, but will be glad you did do, take the width of the box, plus the width of the two sides of the box added together and multiply that by 100 (YES INCLUDE DECIMALS IF THERE ARE ANY!!!) and then put that in for the width of the pic, then GIMP will edit the height automatically for you, and yes its accurate. For example the width of the jello box was 3.3in plus the two side which where 1in each, added together equals 5.3 in, times 100 equaling 530, when you put that in for the width GIMP puts in 814 for the height and you will have the exact size for the jello box. Yes I know, a lot of work, but you where'nt the one who had to make the equation so at least it was easier for you than me.
-Then print it out (IN BLACK AND WHITE!!!) to check the sizing, if it fits well, print it out again in color, discard the B&W version and glue it on!
- So yeah your now done, then just touch up any exposed corners with dark blue or black sharpie and bam, you have some Fallout Items!
Kitten_
3 years ago
No tops for the bottles?
JenniferW81
3 years ago
My daughter is REALLY into Fallout. We even made her a Vault 111 costume for Halloween. Thanks for sharing these. She'll love them!
sprinkles68
5 years ago
You are so awesome for making these to share for free!!!
kmeyers
7 years ago on Introduction
wow. thank you. you did a super job n thanks again for sharing. the best i seen so far
I know this is about the labels but I can't help but ask. Did you make the nuka cola quantum? I want to make it as a gift for my boyfriend but I just can't find out how exactly :[
KneeCapHill
What software did you use to create the layout of the labels ?
Im desperatly trying to create my own labels for some other game props
any advice ?
KneeCapHill
Thx again for adding those sugar bombs ;)
you are the only one on web to have that label
mfrost
For resealing, I stick a small bit of cork from a wine cork under the cap, and then hot glue it. I carry mine around school occasionally, and have never had any leakage issues.
I'd think a little clear silicon would work to seal the caps as well. It's stickier than Hot glue. At least to glass. Depends on how much you use tho I guess.
joseyyesoj12
8 years ago on Step 1
thanx for the tops sides and stuff to sugar bombs i aprecciate ur help and can u put more labels up plz like buffout or mentats?unless u already have them cause im a newb at this site
jmonty
2 things. 1, isnt it blanco mac and cheese? and 2,u should make some nuka cola victory(:
