Fallout 3 T-45d Helmet
151,324
936
133
About: im a fixer,hacker,maker and shaker
Hello, before I start, yes it's another helmet, I can't help it! I'm addicted! But after this I'm getting help, hopefully with the intervention I might be able to make something else for a while, like I don't know, armor or I really want to do some more wood work , but it's still bloody cold here, anyways I'm not sure, but I do know this, this helmet was a great deal of fun to do , it's another pepakura file, but it was a very basic file, the rest of the lid was made with found parts and making parts, lots of people cast there work then go from there, I don't cast, I make one offs, I think casting is fantastic, but I just don't have the time or money or space, maybe one day,
Without further a do, I present, my addiction, my muse,another bloody helmet.......
Step 1: Pepakura File Beginnings
Unfortunately I didn't take many actual making shots, most of the shots here will be static "head" shots, apologies, to be honest I got the pep finished and thought I wouldn't get much further, it was very basic I didn't see the point, but then I found some bits I thought would work, and I decided I'll fiberglass it and bondo it and see where it goes
Step 2: Bondo and Sanding
As before many times, after fiberglass I bondo, this part takes time, I put real thin layers on, sanding as I go and I started a new thing, I'll sand and get the bit I'm working into a good shape, then I'll spray it with any colour it's not important, what is important is looking for low points or bits that look wrong, the paint is unforgiving so it's easier to see
Step 3: More Bondo and Sanding
More bondo and shaping, all theses steps are basically sanding and looking at your work, what looks right and so on,
Step 4: Planning Out
Ok so skipping the days of sanding, we come to planning out, I've got the lid into some form of shape I like, I like to plan out what's what, helps me see the final thing and get my head around where to start and what I want etc, again not thinking to much about finishing it, more just the practice and trying to use real world parts and seeing where I end up
Step 5: Some Detailing
Ok so I'm this far in, might as well stick some detail in and see what happens, I ise stuff called multiput, it's for fixing car exhausts and things, it's two part putty you mix together and can mold and mess with for about an hour before it starts to go off, when it does go off it's rock hard, sandable but really strong , I love it!
Also I started adding real world parts, the light is made up from bits of a torch and a spray can lid, the white nose vents are old rubbers from a skateboard ( thanks Sam! ) the rivets are upholster pins cut down and glued in
Step 6: Paint
I'm not sure what order other people build but this is the way I do, I got as much detail as possible on the main bit of the lid then I start the paint, on this one I primed it with whatever was around, then I used hammeright smooth silver, it's good stuff and gives a good worked surface to weather later
Step 7: Weathering
Right paint is dry and time for one of my favorite bits, weathering, I use a black satin gloss and paint it sections, then use old rags to pat off or rub the paint, I get it how I want it and then add bits of browns and dark colours, till I'm happy, then I walk away, otherwise I'll do it to much!
Step 8: External Parts and Stuff
The main helmet is pretty much done, here I added bits and bobs to make it more like the game helmet, because I can't really afford to spend a fortune on my projects, I've been thrifty, the side bits that screw in are feet from a old unit, the arm that comes from the side is a metal ruler bent and shaped, the red eye piece is the top of a old spray can, the side pipe is a washing machine pipe, there's a small led torch on the arm which I've multiputted up to look old and fixed with a few found bolts, all then painted with the smooth silver then weathered to match the lid, then fitted, I've also started adding the LEDs to put in the main torch and red eye ( the LEDs are a ten string bunch of Christmas light with a battery pack all in one, all gathered up and glued it place)
Step 9: Nearly Done! Promise!
It's getting there, it always amazes me writing these up , it sounds so simple, but what you've just read is about. 6 weeks work, working only on a night after work and when the kids have gone to bed, anyways here we are, looking pretty cool right now, everything's tying in together nicely, pretty much just the main pipes and back bit to do
Step 10: Ten Steps Is Enough! Go Have a Cuppa!
The pipes where from a Hoover ( thanks Andy!) and cut to fit, the back of the pipes where there held was made by plumbing parts I had about, they fit together really well, I screwed the plumbing bit into the back of the helmet then fixed to pipe into them, added a few details with multiput and painting, with the multiput I had left I tidied up the inside where the pipes come in and other bits, also making the joins much stronger, anyways that's pretty much how I've made this one, I hope you like it, I'm really pleased how it's come together for no money really,
I will try to move on now, ( secretly I'm making a nord helmet mark 3! But don't tell anyone!) and I'll try to get out there and embrace the cold and get some woodwork done or start on a different project...................maybe!
Thank you so much for having a look , I hope you like the use of found parts and hand made parts, the thrifty way it's come together on a shoe string budget, I'm quite proud of this one , considering I wasn't going to make it to start with, and just see what I could learn ,
Thanks again and feel free to comment but please be gentle, I'm cold turkey with helmets now! ;)
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    • Arduino Contest 2019
    133 Discussions
    psychom1
    Question 6 months ago
    How much did this actually cost to make?
    Magnus_attemptsPsiborg
    Reply 11 months ago
    what paper would you recommend this for A3 or A4?
    -appriciate it
    Magnus_attempts
    Question 11 months ago
    what would I do if I wanted to cast it in resin follow it up until step 2/3 or do something completely different?
    Stop MotionM
    Tip 1 year ago
    If you're making this for some sort of costume, I'd advise you to mix some brown paint and water, dip in a paper towel, and smudge it around to give it a more realistic weathered look. Came out great when I made it! Working on the chest-plate for it right now.
    KimberlyD79
    2 years ago
    So what is "multiput" is there another name for it? I can't find it. I know what bondo is. Is it some kind of epoxy. I was going to make a fallout helmet. I was going to to it without instructions etc. But i like the multiput thing to make some of the details but i Googled multiput and it doesnt seem to exsist.
    matson23KimberlyD79
    Reply 2 years ago
    I'm sorry that's my bad, it's actually called milliput, but my predictive changed it to multi and I didn't realise, sorry about that, it's handy stuff, mix it like playdoh and then it hardens after about 20 minutes
    Psiborg
    2 years ago
    Nice. One of the best Fallout helmets I have seen so far on here. I will be attempting to construct this.
    Yorklogan
    2 years ago
    If was wondering if you coat the entire object in bondo and sand it then resin it or is it the opposite I'm very confused on this
    matson23Yorklogan
    Reply 2 years ago
    It's Fibreglass resin, you can get it at most hardware shops, once you've made the helmet from card, then you use the resin to harden it up, once that's dry, then you use the bondo, yes all of the outside of the helmet, thin layers, sanding as you go to make the shape correct, hope that helps
    Yorklogan
    2 years ago
    And I was wondering what type of resin do you use and how to use it as this is my very first time doing any of this
    Generationmatthew62
    2 years ago
    one of my friends said he wanted to build a full suit of power armor but this is where i come in,i have to build the first model and if its OK with you can i put your instructables name on it and if you let me i will send u a Juggernog fridge with nuka cola of your choice but i also have to make one for Halloween during the summer
    FranciscoC111
    3 years ago
    where is the file? I want to build one
    AndrewB17
    3 years ago
    can someone with a pro account please send me the pdf? would be much apreciated
    matson23AndrewB17
    Reply 3 years ago
    I've never seen it as a pdf, a pdo pepakura file is easier to get, I don't have it anymore, but if you search the Rpf.Com you might find a pdo or pdf file,
    DiegoC85
    3 years ago
    Where is the pepakura prints?
    qwertyasdfqwert
    3 years ago
    I can't download the designer on my computer, could someone put a PDF of the unused to print
    BjarkeMNielsen
    3 years ago
    Hey great build! I have a question; can I use something else than bondo, because I can't get bondo in Denmark?
