Fancy Your Ubuntu
390
6
In this instructable, I will show you how how fancy your Ubuntu (or other linux distribution)
In the screenshots I used Ubuntu 17.10 with desktop enviroment Gnome.
Supplies:
Step 1: Step 1: Install Gnome Tweak Tool
You can use Gnome Tweak Tool to set your theme and icon theme. So the first step is to install Gnome Tweak Tool. To install, open the terminal and type:
sudo apt-get install gnome-tweak-tool
Then press enter. A password is asked, so type your password and press enter again. The installer will ask if you want install gnome-tweak-tool, so press "y" to continue.
Step 2: Step 2: Install a Modern GTK Theme
There are several GTK themes aviable to fancy your ubuntu desktop:
Arc Theme
sudo apt-get install arc-theme
Enter your password again and press "y" if asked if you want to continue.
Numix Theme
To install the Numix theme you first have to add the repositories to get Numix packages. Fire up a Terminal and run the following:
sudo add-apt-repository ppa:numix/ppa
sudo apt-get update
After this its possible to install the Numix GTK theme:
sudo apt-get install numix-gtk-theme
After you have installed the theme you want, you have to set the theme.
Open the application menu and open Gnome Tweak Tool
In the tab Apperance > Themes > Applications, you can choose the application theme.
Step 3: Step 3: Install a Icon Theme
Papirus Icon Theme
sudo add-apt-repository ppa:papirus/papirus
sudo apt-get update
sudo apt-get install papirus-icon-theme
Numix Theme
sudo apt-get install numix-icon-theme-circle
After you have installed the theme you want, you have to set the theme. Open the application menu and open Gnome Tweak Tool In the tab Apperance > Themes > Applicatoins you can choose the application theme.
Step 4: Enjoy!
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
