Fast Hot Glue Mold for Small Things
62,542
121
40
Here I will show to you how to make a fast, simple and cheap hot glue mold to reproduce small things.
Step 1: Materials
You will need:
1. Some oil
2. Hot glue gun
Step 2: Preparing the Thing
The small thing that you want to make a mold must support a temperature about 100 degree Celsius, that is the hot glue temperature.
I choose a half-dollar coin, but you could choose anything else.
First put the object above a smooth surface. Then spray a little oil on it and spread it evenly with a piece of cotton. Spread a bit around too.
Step 3: Making the Mold
Wait for the hot glue heats well and slowly apply it above and around the object. Use your hand to push the glue rod inside the gun, to help the flux exit evenly. Try to avoid make bubbles (sometimes is difficult).
Step 4: Separating the Object
Wait until the glue cools well and carefully peel the mold out of the object.
Now you have a fine plastic mold with all the details of the object.
Step 5: Reproducing the Object
Spread a little oil inside the mold.
Now fill the mold with the material of your choice. I choose epoxy, but you could use another material, like clay or acrylic resin.
Step 6: Finalizing
Wait for the material to harden and carefully retires it.
Make the finishing, cut the scraps and paint it, if you want.
Have fun!
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    40 Discussions
    ArticAkita
    3 years ago
    how neat! need to try this on a few foreign pennies I have one has a chuckar bird Canadian the other has a starfish on it from the Bahama republic. (I love it when I find odd coins mingled in my change from town!)
    Georgemk
    5 years ago on Step 6
    Will it works If I use silicone?
    ilovegm
    6 years ago on Introduction
    that epoxy could have made a more durable mold.
    hot glue is cheaper though
    imBobertRobert
    7 years ago on Step 6
    would i be able to reverse it? like use clay and use that as the cast, then put hot glue into that cast?
    dbrt60imBobertRobert
    I think that it's possible. The clay must be a little more dry, maybe. Try it! Don't forget to tell me the result. :)
    imBobertRobertdbrt60
    it worked OK. the mold was hard to get out so i left a little bit hanging out and then cut it off. the clay crumbled after about 5 uses, but it was worth it!
    Lindsleykenobr100
    Reply 8 years ago on Step 6
    Yes, you can make both sides, but you have to make align marks and good oil lubrication between them.
    LadyBoi
    I wonder if you could use this method for doing stamps? Just gluing the hot glue mold onto a piece of wood or cork... hmm, something to try...
    Lindsleyblackdragon27
    Reply 8 years ago on Step 2
    Maybe you have to make a two halves mold. It depends of the details of the object.
