Faux Amber Resin Key Ring
7,457
72
10
About: Geeky artist. MUST. MAKE. STUFF. More stuff at: rhondachasedesign.com
Real amber is too soft to use on a key chain, but amber made from polyester resin is incredibly strong. Your amber "stone" will have the characteristic honey color and glass-like surface, but will be highly scratch resistant. And, since natural amber has bubbles and bits of nature mixed in the resin, you don't have to stress about working outside or being perfectly precise.
Step 1:
Step 2: What You Need
Resin mold - 25mm half-round
Polyester casting resin - (any kind of casting resin works fine - if you want to use something else, it's mostly just a matter of drying time)
Alcohol dyes - yellow, orange
Flake glitter - copper
Bits of dried plant, bug, or other natural debris
Tweezer
Toothpicks
Wax paper
Gloves
Mixing cups (Dixie cups work well)
1 25mm bezel or bezel tray - should be at least 1mm deep
1 25mm split ring (key ring)
1 16 gauge jump ring (5mm +)
Glue (e-6000, epoxy, etc)
Jewelry pliers optional
Step 3:
Get out all of your resin supplies.
Pour 1-2T of resin to a mixing cup.
When using polyester resin, don't add the hardener until just before you're ready to pour.
Step 4: Yellow
Add enough yellow alcohol dye to make a bright lemon yellow. About 3 drops. Stir well.
Step 5: Orange
Add 1 drop of orange alcohol dye at a time until you have a beautiful amber color.
Step 6: Inclusions
Add a few flakes of copper glitter. Stir well.
Look at the mix to see if you need more glitter. If you add to much the amber will look fake.
Step 7: Additional Inclusions
You can add bits or plant or insects if you want.
Stir well & let them "soak" a few minutes.
Add a drop or two of hardener.
Stir well.
Then pour the resin into your cabochon molds.
Stir with a toothpick so everything doesn't settle into the middle.
Step 8: Add More If You Want
As the resin thickens you can see if you have a good amount of inclusions in the cabochons. If you want to add more, a great way to do this is to take the resin-sticky toothpick and dab it into some "dirt". I had an outdoor table where little bits of debris had blown. It was easy to pull up a tiny amount at a time and add the debris into my molds. Stir very well.
Step 9: More Bits
You can be very precise at this point about what you add.
Step 10: Stir
You will need to gently stir each mold to keep the inclusions evenly distributed.
Also, poke down pieces that float up if they break the surface. It will be easier later if the surface is flat.
Step 11: Set
Once the resin is a jelly consistency, you can stop stirring and just let the resin harden fully. Even though polyester resin hardens quickly, I like to wait until the next day to remove them.
Step 12: Unmold
When the cabochons are fully cured pop them out of the mold by pressing your thumbs on the backs of the cavities. If they don't pop out easily, or seem tacky, stop and wait longer to remove the cabs.
Step 13: Air Dry
Even the cabs seem perfectly dry, try not to handle them much or you might get fingerprints. Set them outside (if possible) and work with them the next day.
This will give you a beautiful glassy finish.
Step 14: Set the Stone
Get out your bezel tray.
See how your amber cabochon fits in the bezel tray. You'll probably have to trim them down a bit. If so, use sand paper to trim the outside edge of the cab base. SAND ONLY THE EDGE.
DO NOT BREATH IN RESIN DUST. Use a mask or sand under water.
Try it in the tray again for size. Sand until it fits. As soon as it goes in, stop sanding. It should be a very snug fit.
Step 15: Glue the Amber
Make a thick (1-2mm) layer of e-6000 glue and use a toothpick to get the glue into the edges.
Step 16: Set!
Set the cabochon into the bezel. Allow glue to dry overnight.
Step 17: Assemble
Add a jump ring to the loop on the bezel. Use two pliers to twist open and twist closed the ring.
Step 18: Split Ring
{"context":{"location":{"href":"https://www.instructables.com/editInstructable/edit/E86VHWBJI4UAXHL/step/2","protocol":"https:","host":"www.instructables.com","hostname":"www.instructables.com","port":"","pathname":"/editInstructable/edit/E86VHWBJI4UAXHL/step/2","search":"","hash":"","origin":"https://www.instructables.com","ancestorOrigins":{}},"jQuery110202524136157348782":1},"selector":"#editor-Object-1489"}
Step 19: Add Keys!
Your keychain is ready for keys! Open the large split ring and thread your keys on.
Step 20: Show Off Your Key Ring
Your faux amber key ring is very strong and durable. It will easily withstand lots of keys, pockets, and purses.
I hope you enjoyed this instructable. Please post your projects if you try it. Thanks!
Plastics Contest
Runner Up in the
Plastics Contest
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    10 Discussions
    Datawolf
    4 months ago
    I love your instructable.
    Have you ever tried to mold a sphere? or to assemble two of your half-spheres?
    Rhonda Chase DesignDatawolf
    Reply 4 months ago
    Yes. I found it was much easier to use round molds than try to match up two halves. Silicon sphere molds are very easy to work with! The blue spheres in the photo were for a cosplay custom order :-)
    Lokisgodhi
    5 months ago
    How scratch resistant are these polyester resin castings? I'm looking to make faux amber grip but it'll be handled much more than a key ring. Would epoxy resin be stronger and less scratch resistant?
    Rhonda Chase DesignLokisgodhi
    Reply 5 months ago
    Polyester resin is at least as scratch resistant, if not more, than epoxy resin. The only thing is, if you have a thin layer without support, it can be more brittle. Polyester resin is often used to cast everyday household items.
    Bsrlin
    5 months ago
    Thank you for sharing this information and guide. I learned a few things, and will try this in the future.
    Rhonda Chase DesignBsrlin
    Reply 5 months ago
    Thanks! Would love to see a pic when you get to it - but no pressure :-)
    henryb
    5 months ago
    Very nice! I may try this in the future.
    A suggestion - you can burnish the edge of th bezel and push it down onto the stone. It would look better than having the gap between bezel and stone.
    Rhonda Chase Designhenryb
    Reply 5 months ago
    You're absolutely right. I could still try burnishing if I want, but I think in the future I would use a much lower bezel tray (I used what I had on hand). Either way would be great :-) Thanks for bringing this up!
    Penolopy Bulnick
    5 months ago
    These look great!
    I love when I see something from you in the recent feed; I always know it's going to be good :D
