Faux Brick Walls
25,329
275
46
About: My wife and I have a home haunt called Terror On 20Th....I love to build props...everything from a casket to pneumatic monsters! I am also a presenter, speaker and course teacher at Halloween conventions.
We will be making "brick" walls and sections... Using joint compound
Supplies and tools needed:
1. you will need Joint Compound, a 4.5 gallon container is around $25. at any Hardware store, I bought this at the Home Depot.
2. masking tape to make the joint lines, 1/2 inch looks the best but it's hard to find...I buy the 1 inch tape and cut it down with a razor knife. A level, carpenters pencil or marker
3. a few different size putty knife's and a tape measure.
4. 1 brick to use as a template
5. brick colored flat latex interior wall paint, light gray flat wall paint, (you can use white) and some flat black paint
6. a bit of 80 grit sand paper
7. paint brush, floor tarp, water and rags
Step 1: Getting the Brick Look
1.Using the brick as a pattern, set it on the floor and use it to draw a line on the wall. Every few feet use the brick to draw a line on the wall. Use the straight edge level to connect the lines all the way across the area.
2. Using the 1/2 inch tape, apply it directly to the wall just on top of the line...this is now your grout line.
3. Using the brick now repeat that step for the next row of brick....I keep repeating this until all of the "rows" are done.
4. Now using the brick, set it back on the floor and draw a line on the side, this is the layout for the brick
5. start using the tape vertically...repeat this step all the way across...you will now have a "row" of brick laid out with the tape.
6. Now start the second row by starting the first brick at the center of the first...this will give you the alternating patter.
7. just repeat until you have the section covered with tape!
Step 2: Applying the Compound
Not much to this, you want to lay it on about 1/2 an inch thick, try not to cover all of the tape as you will need to peel it off. I sort of just goop it on and smooth it over the area.
Be sure to peel off the tape BEFORE the compound dries...or you will not be able to get it off! I work on peeling off small sections at a time...if you push one finger down on the tape you can peel the tape off up to where you are pushing and it will break off.....I use a bucket to throw the compound covered tape into.
Step 3: Build Up a Few Bricks
After the bricks have dried...about 24 hours I will tape around a few bricks and apply another coat of compound, just to build up a few of them and help sell the look.
Step 4: Finish Your Brick Look
1. I use the putty knife to knock down some of the sharp edges, you can also knock it down a bit with some sand paper.
2. For smaller brick sections I use more compound to build up the surrounding areas of the brick to make it look as if the stucco has fallen away exposing the brick.
Step 5: Paint
!. Using the brick colored flat paint I brush it on each brick...for large sections you can also use a thick roller and just roll it on.
2. In a small container I use the brick color and add some black...just enough to change the color...then I paint random bricks in the different shade.
3. On the darker bricks, after they dry I go over with a dry brush of the light colored paint. It gives more of an aged look.
Step 6: Finish Paint
All of the grout lines were hand painted with a light gray....keep a wet rag handy to wipe off the paint you will get on the brick!
After the grout lines are dry I go over the wall with the gray or white paint...I "clean" off some with a wet rag....this washing effect really sells the look of real brick.
Finally the outer edges of the stucco are painted the same color of the wall.
This can really change the look of a room!!
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest
    Paper Contest
  • Organization Contest
46 Discussions
boocat
3 months ago
Terrific looking!
ElizabethLeona
Question 5 months ago on Step 4
Loved it. Thanks for sharing. What can I use for an outside wall? Will appreciate your reply.
Artuino
6 months ago
fantastic work!..very creative.
rjbosco
6 months ago
It looks fantastic! One benefit you had in your project is that you were working with cinder block, which has a rough texture. That makes the grout lines look more realistic. I suspect if working on a drywall “canvas” the grout lines might look a little too clean. Still, very impressive.
bvargorjbosco
Reply 6 months ago
There are sanded faux finishes at THD that you could use to simulate mortar in between the bricks and I imagine that you could just mix mason sand in with latex paint and get a similar effect. Block has the wrong particle size to simulate mortar anyway.
Mobilyeah
6 months ago
I love it, It's not too hard. I think i will try. Thanks
EmptyChild
6 months ago
Nice. Curious how long this takes?
A couple ideas for people with less patience...
#1. Paint the wall grout color, get a brick sized sponge & paint the bricks on. (probably use guide lines) I've seen this done on a garage floor just using the bare concrete for the grout color. (They used a clear sealant on top)
#2. Paint the whole surface brick color, using faux finish techniques, so its not monochrome. Then add the grout lines on top. Saw a professional artist do this for a bar. (May take considerable skill.)
These won't be as realistic as yours, but from a distance you can fool a lot of people.
JasonF205EmptyChild
Reply 6 months ago
Really only took a few hours each night....first 2 nights I let the compound dry 24hrs and the last night was the paint.....that did take a while on the full wall.
Pa1963
6 months ago
Definiely faster and prolly cheaper to go to Home Depot and buy a 4' x 8' sheet of faux brick. $26.97/sheet here in L.A. area. Otherwise, awesome job!
JasonF205Pa1963
Reply 6 months ago
yes but it doesn't look very real and if you are doing a 12' wall you will see the seams. For about $30 I can do a whole wall.
jpdurocheJasonF205
Reply 6 months ago
And I saw your Skulls Great Job!! going to try my hand at those...
LucDaRocka1
6 months ago
Definitely giving me ideas about a Coyote and Roadrunner brick wall.
makemesomecookies
6 months ago
That wall is beautiful! Thanks for sharing.
Brian M V
6 months ago
thanks for sharing your techniques!
hope to be trying this in the near future!
handmadewithashley
6 months ago
that's so neat! Saving it for future reference :)
