Fire Hot Tub
26,908
335
13
i was in search for a hot tub system where 1000 liter of water was ready in about an hour instead of 3 or 4 hours like most projects i've seen..
also it needs to be a camp fire to sit around with a drink or maybe grill some meat untill the water is warm
i still had in memory how hot camp fires got after placing wood above wood causing massive flames
this all combined is what i came up with..
Supplies:
Step 1: Buiding the Fire Cage
this fire cage is build like a camp fire so it can hold long sticks in place and is feeded trough the top ring
the water will be pumped in the bottom ring and then trough the thin tubes to the top ring
from here it will be led to the tub again
Step 2: Filled the Cage With Water for Testing (three Little Holes)..
Step 3: Time to Clean the Test Tub
Step 4: A Pond Pump Is Used With Rubber Hoses From a Radiator
Step 5: Everything Mounted and in Position!!
Step 6: Time to Lit the Fire!!
Step 7: Within Minutes the Flames Are Bursting Out at the Top Creating Massive Heat
Step 8: After Just One Hour the Water Temperature Reaches 40 Gr. Celcius
Step 9: Next Morning, the Water Still Has 30 Gr. Celcius
Step 10: This Thing Did an Awesome Job, Time to Make It for Real!!
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    13 Discussions
    roanbuma
    3 years ago
    Cooled*
    roanbuma
    3 years ago
    If you use plastic tubes it should work in theory, because the plastic isn't gonna burn since it's colled by the water
    JanD28NectarineSoup
    Reply 3 years ago
    yeah, but there is a little problem with money, space and time ;-) but we will get there..
    JanD28JanD28
    Reply 3 years ago
    yeah doesnt mean yes in this context :-)
    treenail
    3 years ago
    Clever idea!
    Using stainless tubing would be trick and the most durable of course. The trade off is cost and welding. Unless you weld and get a deal on materials of course.
    Here's a suggestion that would reduce come welding. Find a muffler shop and have them bend some exhaust pipe into a circle. From what I see in your pictures I can see that you can fabricate and weld.
    The concern about rusting or burning out sure wouldn't bother me. As long as the manifolds are full of water they won't get too hot. When you're done heating the tub, disconnect, drain the heater and leave a small fire inside to warm/evaporate the unit.
    Using a heat exchanger adds complexity for something that is likely not to be used a lot. I would consider adding a thermal switch of some kind to control the pump. You might be building a lobster pot hahaha! Or...trust that people are going to be able to always pay attention to the heated water temp.
    I'm looking forward to the full size build.
    Tom
    JanD28treenail
    Reply 3 years ago
    a stainless steel fire cage will cost me about 500 euro for the tubing here in belgium, the welding i can do myself, i have taken a look at muffler parts, they don't go very sheap as well.. the positive thing about the parts is the super thin wall thickness so the water will heat up quicker..
    JanD28
    3 years ago
    the Final Cage Will be made in stainless steel, copper would be better but the welded joints would not hold this kind of temperatures i think..
    tallemertes
    3 years ago
    I love this idea. Will the heat affect the life expectancy of the pond pump?
    Fretfultallemertes
    Reply 3 years ago
    connect the pump so it pushes cold water from the tub instead of pulling hot water from the fireplace
    euvremer
    3 years ago
    Normally you dont need a pump, the heat will pump naturally the water. As well it would be better to use copper tubing to avoid corrosion
    JanD28euvremer
    Reply 3 years ago
    you're right, but for safety reasons i put a pump so the water doesnt get so Hot when entering the tub..
    eweis
    3 years ago
    please share a buildlog of the real deal
