Fix Your QuadCopter
79,744
147
46
About: I am an inventive photographer, Pilot, and MacGyver. I love building and modifying things to aid in my adventures. Check out my Website! Have a great day!
One of the hot toys this Christmas was quadcopter drones. They are an awful lot of fun for a great price, and are a lot more fun to learn to fly than larger (more expensive to crash) models.
If you are having repeated problems with broken or bent props, prop guards can help.
Prop Gaurds: http://www.gearbest.com/rc-quadcopters-parts/pp_166087.html
Due to their inexpensive construction and very inexperienced pilots, there are bound to be some breakdowns. In this tutorial I will explain how to replace stripped screws, broken or bent propellers, repair broken LEDs, broken clasps, broken wires, and stop the battery from shorting out the gyroscope.
If your quadcopter if flying unstably, making buzzing noises, not fully lighting up, not charging, flying with a mind of its own, one propeller is not spinning, it is loosing screws, or its shell will not stay closed this is the instructable for you.
For this tutorial you will require:
- A set of small Philips screw drives (my quadcopter required a pH0)
- spare propellers (extras come with most models)
- a hot glue gun
- clear tape
- a soldering iron and fine soldering tip
To open your quadcopter, first remove the four screws on the bottom of the case, then remove the clips near each rotor.
Check Out Our Other Accounts! Like, Subscribe, and Follow to keep up to date with our latest projects. :-)
Just4Fun Media FacebookJust4Fun Media InstagramJust4Fun Media YoutubeJust4Fun Media TwitterJust4Fun Media TumblrJust4Fun Media Website
Supplies:
Step 1: Bent Propellers
It is very common to bend the propellers of your quadcopter, because they are made to be soft as not to hurt people or cause damage to other objects.
Bent propellers are characterized by loss of lift from one propeller (if concave) or a buzzing sound similar to a mosquito and reduced performance (if convex).
Place your quadcopter on a flat surface and observe the propellers at eye level. simply apply pressure to the propellers to bend them back into shape. NOTE: Less is more, repeated bending will severely weaken the propellers leading to cracks or fractures.
Step 2: Replace Broken Propellers
To replace a broken or severely bent propeller simply pull vertically near the center of the propeller then press the new propeller onto the shaft of the rotor.
Make sure that you replace the propeller with the correct replacement as there are A and B propellers which rotate in different directions to increase the stability of your quadcopter.
Replacement Propellers: http://www.gearbest.com/rc-quadcopters-parts/pp_149153.html
NOTE: Repeated removal and replacement of the same propeller can cause the propeller to no longer friction fit and come loose during flight.
Step 3: Stop Battery Shorts
The insulation between the bag battery and the circuit board of most mini quadcopters is very easily dislodged. If your quadcopter will no longer charge, has extremely short battery life, or flies sporadically and seems to control itself once turned on you may be having shoring issues.
After removing the case and the piece of insulating plastic from beneath the battery I attached the piece of insulation to clear tape, then wrapped the battery in clear tape to prevent any short circuits.
Step 4: Re-Attach Broken Wires
If one propeller no longer spins, first turn the quadcopter on and rotate it in different directions, the propeller which is highest should slow down or stop, if the propeller spins when it is the lowest, but will not spin while level check the insulation around the battery to see if it is a shorting issue.
If the propeller will not spin at all check the wires connecting the motor to the circuit board. If one has become detached use a pair of forceps to hold the wire and use a liberal amount of heat with a fine tipped soldering iron to melt the solder and re attach the wire.
Replacement Motors: http://www.gearbest.com/rc-quadcopters-parts/pp_166081.html
NOTE: only add solder if necessary and make sure to use fine grade "high tech" solder as it has a lower melting temperature to avoid frying components and melting wires on compact circuit boards.
Step 5: Replacing LED's
If one of the LED's comes loose from your drone, the most important step is finding the original LED because it is smaller than a grain of rice (approximately 1mm by 1.5mm). If you cannot find the diode you can buy micro LED's for a few cents from commercial electronics stores.
Make sure to note the diode direction markings on the back of the diode and the circuit board (make sure they point the same direction when you place it on the board!)
You will notice that if you place the diode when the motor is still in place it will be pulled in by the magnetic field of the brush-less motor, so the motors must be dropped.
Next using a pair of forceps carefully place the LED back onto the contacts then melt the solder with a fine tipped soldering iron.
After the solder has cooled make sure to turn on the drone to test the LED's before putting the case back together as minor adjustments may be necessary.
Step 6: Replacing Removed Screws
You hay have noticed small amounts of silicone on the tips of the screws when you removed them, hot glue is a readily available substitute. Make sure that the hot glue is VERY hot as you do not want it clumping. After reattaching the clips near each rotor, liberally dip each screw tip in hot glue before reinstalling. This will also help to precedent screws from coming dislodged during flight.
Step 7: Broken Clasps
If the clasps that hold the outer casing together break, the upper and lower shell can be held together with small elastics such as used for braces or for holding wires and headphones in their packaging.
NOTE: Make sure to counterbalance the elastic or the quadcopter may have balance issues.
Step 8: Back to the Skies
Hopefully this tutorial has helped to fix your quadcopter, if you are having issues understanding a step or have questions/suggestions feel free to comment below or message me.
Have a great day and fly safe! :-)
If you enjoyed this instructable, make sure to see how you can turn your mini quadcopter into a flying F-14 Tomcat! https://www.instructables.com/id/RC-Paper-Fighter-Jet/
PS Above is a thermal video of my quadcopter taking off.
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    46 Discussions
    JacobT102
    Question 4 months ago
    How/could I reset my fx mini quad drone to what it was when I first got it?
    Bongwamngwevu0
    4 months ago
    Hi I have a DHD copter but now it won't fly buy I charged the battery and put it back
    LanceO14
    Question 4 months ago on Step 1
    After i have charged my aircraft how do i connect it to the remote? They seem to have no connection between each other
    Dark M
    5 months ago
    Bro please help .i buy azi vision DRONE after one month .but this time drone falling one side.how to repair.please help me bro.what is the solution
    Reply please
    MattS478
    Question 5 months ago
    hi there I got a remote controlled x-cam quadcopter for Christmas and managed to crash it straight away lol and now two for the four propellers wont spin which is not letting the copter fly. could anyone help me with this or have a solution for this. thanks
    NicoleM233
    5 months ago
    ss360 battery wires came loose help please
    eterovicivant102
    Answer 7 months ago
    2 of the props rotate clockwise and 2 anti-clockwise. So they are different
    Macca4
    Question 7 months ago on Step 4
    I have 2 wires that look like they should attach to the board, all the motor cables are fine but these seem power related
    jayceedine1
    Question 1 year ago
    I have a jy018 mini drone and the flight controller board has a problem.I can power it on and connect it to my phone via wifi, the video is also working but whenever i turn it on the lights are blinking first then gets a steady light even if i am not yet connected to my phone, by the way the drone is on the ground and level and even if it is connected to my phone the motors wont start when i turn it on. Also the drone cant be turned off by its button i have to take out the battery just to turn it off.
    pritish_12
    Question 1 year ago on Step 1
    My one propeller are moving very slow how to fix that
    AlB79
    1 year ago
    The rod that the propeller attaches to has broken. can that be replaced or is my itherwise perfectly working drone toast?
    LonwaboM
    1 year ago
    Hi, one of the four motors doesnt work, but if I turn the quadcopter upside down it works. Before this discovery I thought of a broken wire, etc. but I dont think thats the reason. Any advise, please.
    4804311532
    1 year ago
    My drone's power button fell out, any solutions? I need all I can get!
    ecy0000
    2 years ago
    Hi, I have a MJX Bugs 3 quadcopter and one of the propeller stopped working after it fell out of the sky. I do not see any physical damage and I have tried to open it up to compare it to working propeller but I do not see any difference either. I do not know what's wrong and what to do.
    Maker Saga
    2 years ago
    Well written and handy! Here's a few more tips in case you want to add them (kinda sorta already covered):
    1. Gyro recalibration for Floureon H101 and Eachine H8 Mini (maybe additional models too):
    On a flat surface, move both sticks down and to the right. You're all set once the drone stops flashing.
    2. Make sure you have the correct type of propeller on the correct motors. If one or more propeller blows air the wrong way, switch it out for the opposite type of propeller. Clockwise (CW) vs counterclockwise (CCW) motors and propellers.
    3. Hair stuck around propellor shaft is the most common issue in our experience!
    4. Dirt or sand in gears:
    Use a dental braces soft pick to remove sand or dirt from gears.
    5. Drone fell in puddle:
    Soak drone in bowl of dry rice or silica dessicant packets. Using a fan or wind instead may cause corrosion.
    6. Motors overheating:
    Some 7.4v toy drones uset motors designed for lower voltages, this is incorrect and may cause the motors to overheat and eventually fry. ( for this one I don't know a solution to this, maybe the author has an idea)
    Hopefully this comment is helpful in some way!
