Fixup for the Magnetic Mess
1,457
12
8
Hi.
I brought my cellphone charger and cable to the workshop and dragged the cable connector over the workbench. No problem if it wasn't a magnetic one.
The connector became a ball of tiny steel scraps from the last grinder use. You can imagine how it was, because I have no picture of it, sorry.
Then my instructables spirit told me to show you how I decided to try a desperate cleaning.
Supplies:
Step 1: First I Warmed a Hot Glue Stick to Melt It a Little.
There was nothing I could guess would take all the steel from the contacts so quick and completely than hot glue.
Step 2: The Trial
When it was soft enough for my trial I touched the connector pins with the hot glue stick managing to push the glue all over the steel mess I made. Let it cool down completely or it won't grab the steel powder. Push it out carefully and...
Step 3: Voilá!
There you are. Almost all the mess came glued to the hot glue stick. Repeat enough to clean it all and you are done! Before using the stick again, cut off the used tip.
Just a point: There was a finishing shining sticker that came off together, but I carefully removed it from the hot glue and put it back.
Too simple to a mess so big. The cable was almost going to the trash bin when I had this enlightening, thanks to the many ingenious instructables I've seen here.
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    8 Discussions
    ErikaMarie
    1 year ago
    This is so smart! Something I do is use a blower nozzle off my compressor and blast it off, works great also!
    rbormannErikaMarie
    Reply 1 year ago
    Right, but in this particular case I was afraid of pushing the steel powder further inside the connector, what would destroy it for good.
    burningsuntech
    1 year ago
    This is a neat trick. i have it filed away for future reference. Thanks for sharing the tip. RA
    nramirez10
    1 year ago
    plumbers putty also works, i use it at work to get the gunk out of my magnet impact bits
    rbormannnramirez10
    Reply 1 year ago
    Great, we always get a way to fix these problems.
    allangee
    1 year ago
    That is so obvious -- AFTER SOMEONE ELSE THOUGHT OF IT! Great idea. I already know a couple of magnets I'm going to use this on.
    rbormannallangee
    Reply 1 year ago
    Nice you liked it. I keep my magnets in plastic bags and they always are collecting things, but on the outside of the bags... Good to know I can help somebody.
