Fire Detection Using Arduino and Flame Sensor
69,318
56
13
Flame sensor is interfaced to arduino to detect Flame. Led and buzzer are interfaced to arduino to indicate the flame.
Hard ware components required:-
1) Flame sensor (Analogue Output)
2)Arduino
3)Bread board
4)LED
5)Buzzer
6)Connecting wires
Step 1: Hard Ware Connections
Flame sensor interfacing to Arduino
Flame sensor to Arduino
vcc -> vcc
gnd -> gnd
A0 -> A0
Led interfacing to Arduino
LED +ve is connected to 9th pin of Arduino
LED -ve is connected to gnd pin of arduino
For detailded description regarding led interfacing refer the below link
https://www.instructables.com/id/LED-blinking-using-Arduino/
Buzzer interfacing to Arduino
Buzzer +ve is connected to 12th pin of Arduino
Buzzer -ve is connected to GND pin of Arduino
Step 2: Programming
#include<SoftwareSerial.h>
int sensorPin = A0; // select the input pin for the LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int led = 9; // Output pin for LED
int buzzer = 12; // Output pin for Buzzer
void setup() {
// declare the ledPin and buzzer as an OUTPUT:
pinMode(led, OUTPUT);
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
void loop()
Serial.println("Welcome to TechPonder Flame Sensor Tutorial");
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue < 100)
Serial.println("Fire Detected");
Serial.println("LED on");
digitalWrite(led,HIGH);
digitalWrite(buzzer,HIGH);
delay(1000);
digitalWrite(led,LOW);
digitalWrite(buzzer,LOW);
delay(sensorValue);
Copy and paste the above code in Arduino ide and upload to Arduino UNO.
Thanks,
TechPonder.
Step 3: Results
Results are displayed on the serial window.
When there is Flame the LED and Buzzer automatically ON and when there is no flame amount Arduino automatically turns off LED and Buzzer.
Here based on our room condition the threshold value we took was 100 for the Flame sensor.
When we place a Flame Near Flame Sensor Arduino automatically turns on the LED and Buzzer. When we remove Flame from the flame sensor Arduino automatically Turns Off LED and buzeer.
Thanks,
TechPonder.
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
13 Discussions
murtaza nihalRanjithaS1
Answer 11 months ago
you can change and play with it and set it to your desired range, its basically range or distance, the fire is closed to sensor
MaryR225
Question 1 year ago on Step 2
Is this all the codes?
ahamed0081
1 year ago
Hi,
I'm trying to make a prototype which can detect fire using flame sensor and send an sms to a allocated mobile number.
Experts on coding please advice me to make the programme
arduinomaster
1 year ago
//you need to include this to make a piezo run that does not buzz by itself.
// the 100 means the Arduino reads the value between 0 and 1024 or 5 to 0 volt.
// if (sensorValue < 100) if sensor reads less then 100 then do {tone(12,300,500); delay(600);}
// 12=pin 300 sound note ,600 minus (500 sound time) makes a delay of 100 milliseconds.
int piezoPin =12;
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
if (sensorValue < 100){
tone(12,300,500);
delay(1000);
else if (piezoPin = LOW);
//this sketch compiles
VaibhavB50
1 year ago
Buzzer is not working when connected in 12th pin and gnd....
andrer119
2 years ago
Hi, What is "100"... Celsius or Fahrenheit? and why does it go down? what is the measurement unit?
alihashmi385
2 years ago
Why threshold is kept 100. What if it is kept to 200 and so?
FebrianS1
2 years ago
How to adjust the distance of fire detection range?
Mersai harshathm
Reply 2 years ago
I used a 330 ohm and it worked fine.
kode1303
3 years ago
Maybe this could be used to control a diy pellet burner. Hmmm ...
