Flintstones Halloween Costume
40,206
56
10
About: Learn how easy is to design your own clothes! The best Do-it-yourself videos on the web! Join me :D
You can't miss this special halloween costume of The Flintstones! Very easy to do, as always! Enjoy it!
You will need.
About two yards of orange fabric
One XL T-shirt
Scissors
Pins
Chalk
One Tie
Elastic band
Supplies:
Step 1: First Step
First I'm going to make the Fred Flintstone Costume :)
Picture #1 and Picture #2: Make sure that the fabric is long until the knees. Then pin together the fabric.
                                          Asegúrate que la tela sea lo suficientemente larga y ancha. Luego pincha juntas las telas con la ayuda de lso alfileres.
Picture #3 and Picture #4: With the help of another sleeveles T-shirt mark the mold, and cut up the shape of it.
                                           Con la ayuda de una camiseta sin mangas marca el mode y luego cortalo.
Picture #5 and Picture #6: Sew the shoulder and both sides of it
                                          Luego cose los hombros y ambos lados del diseño.
Picture #7 and Picture #8: Don't forget to pin the parts you are going to sew so there for you will have no problems.
                                          No olvides pinchas con los alfileres las partes que vas a coser así te evitas problemas a la hora coserlo en la máquina.
Picture #9 and Picture #10: Use a straight stitch to sew this part
                                            Utiliza una puntada recta para coser esta parte.
Picture #11 and Picture #12: To make the prints grab a cardboard draw the same shape and make like and stencil. With fabric paint black start making it.
                                              Para realizar los prints agarra un pedazo de cartón y dibuja el mismo mode y haz un stencil. Con la pintura para tela empieza a realizar una al lado de otra pero separadas.
Picture #13 and Picture #14 and Picture #15: See how I paint it :)
        Fijate como los pinte :)
Step 2: Second Step
Now the costume for Wilma :)
Picture #16 and Picture #17: From XL sleeveless T-shirt you can make the dress in a few steps.
                                              Desde una camiseta XL sin mangas puedes hacer este vestido en tan solo unos pasos.
Picture #18 and Picture #19: With the chalk mark one sleeve and cut
                                               Con la tiza marca solo una manga y luego corta
Picture #20 and Picture #21: Once you're done, it will look this way.
                                                Una vez que lo hayas terminado de cortar, te quedará así.
Picture #22 and Picture #23: See the part where I put the pins? You need to sew this part now
                                              Mira la parte donde coloqué los alfileres. Debes coser en las mismas
Picture #24 and Picture #25: Now measure just enough elastic band for the waist. Then sew on to the waist line.
                                              Ahora mide la cantidad suficiente de banda elástica que necesitaras para la cintura. Luego cose en la linea de la cintura.
Picture #26 and Picture #27 and Picture #28: You can cut off the hem of the T-shirt or unstitch. Mark in the shape of zigzag and cut off.
                                               Puedes cortar el dobladillo de la camista o descoserlo. Marca en forma de zigzag y luego cortalo.
Picture #29 and Picture #30 and Picture #31: You're done with the dress! Now just make the accesoires :) The one you can find near by.
        El vestido ya esta hecho! Ahora solo falta crear los accesorios :) Los que encuentres cerca y te sean faciles de conseguir.
Good Luck!! ;D
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    10 Discussions
    Joshuah1421
    2 years ago
    Well i tried it thanks a lot we won most creative costume
    sparkyar
    5 years ago on Introduction
    Thanks for the bilingual tutorial
    Gracias por el tutorial bilingue
    cuando la vi a Larissa pense que tambien se disfrazaba Fabbro.jajaja
    ZoDo
    7 years ago on Introduction
    Heh heh...do you have a car that goes with these costumes?
    andyk75
    Hi Gianny,
    nice work! Although might be a bit cold in the late european year. I might prefer dressing up as mammoth... ;-)
    Cheers
    Andreas
