Flip Top Lego Table
4,280
65
12
This table was designed and built for my 2 year old grandson. The top is stained and sealed and is reversible. One side for lego blocks and the other for multi-use. The ends are small shelving units to store Legos, etc.
Step 1: Material List, But With Improvisations...
4'x8' sheet of 3/4 inch plywood
2'x4' sheet of 1/2 inch plywood
4 1x2 pine boards 8'
1 1x3 pine board 6'
6 lego base plates
Wood glue
Contact Adhesive
Sandpaper
Nail gun w/nails
Router
Step 2: Cut List
4 (plywood) 18" long x 8" wide for vertical base pieces
4 (plywood) 22 1/2" long x 6 1/2" wide shelves
2 (plywood) 22 1/2" long x 2 1/2 wide top base supports
2 1x3 boards 31 3/4" long front and back stretchers
8 1x2 boards 22 1/2" long shelf trim
2 1x2 boards 49 1/2" long table top trim, measure and cut to size
2 1x2 boards 25 1/2" long table top trim, measure and cut to size
Step 3: End Support/shelving
Glue and use nail gun to secure shelving ends and trim.
Step 4: Attaching the Front and Back Stretchers
I used metal bracing for extra support.
Step 5: Sizing the Top
Make sure to leave top a little larger so it's not too tight when removing to flip over.
Step 6: Trimming the Top
Trim the top by gluing, then using nail gun to secure. Make sure that the lip on the top and bottom will be equal. Router the edge a bit so it's not such a sharp edge.
Step 7: Adding a Little Trim
I added a little trim to dress it up a bit. Nothing fancy, just used ripped boards.
Step 8: Stain or Paint
I chose to stain the bottom part of the table gray.
Step 9: Stain or Paint the Top
I chose to stain the top and seal it will poly acrylic. Be sure to do both sides of the top.
Step 10: Adding Lego Base Plates
Measure to center plates like you'd like them. tape off and carefully spray adhesive. I used contact adhesive to stick on the Lego base plates. Spray both the table top and the back side of the base plates.
Step 11: Finished Product
This table should bring years of fun and activity to my 2 year old grandson.
Step 12: Addendum to Original
I had enough material, minus the legs, to make another table. I purchased (2) 36 INCH 2"X2" and cut them into four 18" legs and glued them to bottom of table and nailing them with nail gun. Then I braced the ends with some scrap wood I had using my KREG jig. This table seems very sturdy. I plan to clear coat it with spray polyurethane. This table will stay at my residence for my 2 year old grandson, while the blue table went to his house.
Tables and Desks Contest 2016
Third Prize in the
Homemade Gifts Contest 2016
Runner Up in the
    • Arduino Contest 2019
    • Pocket Sized Contest
    • Jewelry Challenge
      Jewelry Challenge
    12 Discussions
    offseid
    2 years ago
    Very well done! I've got a lego table on this site too, but it does not accomodate storage like yours does. Nice!
    varmitwifeoffseid
    Reply 2 years ago
    Thanks! My 2 yr old grandson loves his table. He plays around it all the time, whether with legos or hot wheels on the flip side.
    NebulaIX
    2 years ago
    wow, stunning, how do you flip it over from Lego side to normal side? And also, an improvement if you have not thought of it already: the shelving units on the side that you mentioned were for Lego's could have Lego baseplate a lining it, (as you did for the tabletop, but narrower and smaller) so creations/blocks don't slip off.
    varmitwifeNebulaIX
    Reply 2 years ago
    Thank you. The entire "blue" top flips over. Just raise it up and flip. The shelves on the end have a "lip" so hopefully helps keep things on the shelves.
    varmitwifeNebulaIX
    Reply 2 years ago
    It was a great idea! Thanks for the input...
    seamster
    2 years ago
    Excellent looking table. Looks like the perfect place for a kid to play and create! :)
    varmitwifeseamster
    Reply 2 years ago
    Thank you. I can't wait until Christmas to give it to him.
    BKLaRue
    2 years ago
    This is so killer, my kids would love it. Great work!
