Flip Top Tool Stand
43,359
651
26
About: I run FixThisBuildThat.com where we focus on Woodworking and DIY Projects, Plans and Tools. Come check us out and let us inspire you to build something awesome!
If you liked the video please subscribe to my YouTube channel.
Here is a project that is great for any small shop. Double the effectiveness of your floor space with this Flip Top Tool stand. It can hold any number of benchtop tools including planers, mitersaws, sanders, drill presses, etc.
Tools:
  • Tablesaw (or circular saw)
  • Miter saw
  • Cordless drill
  • Router
  • Pocket hole jig
Materials:
  • 1 sheet 4'x8' 3/4" plywood
  • 2 1x2 8' pine/poplar boards
  • Casters
  • Full extension drawer slides
  • Various mounting hardware and screws
Read the instructable here and you can also get plans with measured drawings over at my website: http://fixthisbuildthat.com/diy-flip-top-tool-stand-plans/
Step 1: Cut and Prepare the Sides, Bottom and Shelf
Cut two side to 30" x 21-1/2" and a bottom and shelf both at 27" x 21-1/2". Drill pockets holes on the underside of the bottom and shelf to connect to the sides.
Drill a 3/4" hole centered 2-5/8" down from the top of each side. This will hold the steel bar used to rotate the top. If you clamp them together it makes keeping the hole aligned easier
Cut 2 slots in each side for the flip top locking hardware. The slots are 3/8″ wide, 1-1/2″ long and 2-5/8″down from the top. I used a router and a straight edge to do this.
Step 2: Assemble the Base
Attach the bottom to the sides with 1-1/4" pocket hole screws. Use a 4-1/2" spacer and mount the shelf 4-1/2" above the bottom shelf using pocket screws.
Cut a 27" x 4-1/2" back and install it on the back of the drawer cavity.
Step 3: Build and Mount the Drawer
Cut the drawer parts to size, 2 sides at 20″ x 4″ and a front and back at 24-1/2″ x 4″.
Drill pocket holes on the ends of the front and back parts and assemble the drawer as shown.
Cut a 26" x 20" drawer bottom and glue and nail/staple the bottom onto the drawer.
Mount 20" full extension drawer slides in the drawer cavity per manufacturer instructions and install the drawer.
Cut a 26-7/8″ x 4-3/8″ false drawer front and attach it to the drawer with 1-1/4" pocket screws from inside the drawer.
Step 4: Add Casters
Flip the assembly over and add casters to the corners. I used 4" double locking casters.
Step 5: Cut and Assemble the Flip Top
Cut two pieces of 3/4″ ply to 27″ x 21-1/2″ and cut four pieces of 1×2 to 27″. Layout a 3/4″ wide section that runs 27″ across the center of the top, this will be where the steel rod goes.
Attach a 1x2 on each side of the channel you just laid out. Use 1-1/4" screws countersunk into the 1x2's.
Cut 5/16" open mortises 1-1/2" deep on the ends of the other 1x2s. Attach them to the outer edges of the top.
Cut four 1x2 pieces to 7-3/8" for blocking and fill in the outer edges between the 1x2's you just installed.
Install the other side of the top with 1-1/4" screws.
Step 6: Install the Locking Hardware
Drill 1" holes, 1/2" deep in each of the 4 corners of the top on both sides (8 in all). The holes are 1" from the sides and 3/4" from the front or back.
Next drill a 3/8" hole through the center of each of the recessed holes.
The locking hardware is a 5/16" 3-1/4" eye bolt held in place by a 3/8" bolt. Run the 3/8" bolt through the holes you drilled in the corners and through the eye of the eye bolt. Lock the 3/8" bolt into place with a lock nut.
Install a fender washer and a start knob on the end of the eye bolt which will lock down on the sides.
Step 7: Install the Top
Clamp the top into place so the channel for the pipe and the holes in the sides are aligned. Run a 3/4" steel pipe through the assembly. Cut the pipe so there is 3/8" sticking out from each side. Drill a pilot hole through the top and through the rod and secure the rod in place with a 1-1/4" screw on each end.
Cut 2 pipe blocks 4" x 2-1/2" and drill a 3/4" hole 1/2" deep in the center of each piece. Attach these pieces to the side of the cart to cover the exposed pipes.
Step 8: Mount Tools
Mount your tools with 3-1/2" lag screws to each side. Center the weight of each tool on the top for easy flipping.
For more info and plans for this project go to my blog post at : http://fixthisbuildthat.com/diy-flip-top-tool-stand-plans/
3 People Made This Project!
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
26 Discussions
OldGuy52
3 years ago
Elegant answer for my crowded shop!
INFINITEKIFF
3 years ago
Very nice build, love the star knob fixtures! My only question is what happens to your cables everytime you flip? Surely these aren't battery operated?
bruce.desertratINFINITEKIFF
Reply 3 years ago
Well all these tools only have a short power cable, just unplug it and tuck the end into the machine before flipping. On the last picture you can see the power cord from the sander tied up with what looks to be a strip of velcro.
ronh45bruce.desertrat
Reply 3 years ago
Naa, that is too mickey mouse, instead add in standard in wall mount electric outlet with combo lightswitch.
Further the board on which you mount your gear should have large bolts in the 4 corners to mount to the base.. then you can quickly switch out one gear for another.
My 2 cents
zeroaxe
3 years ago
Hi there,
First of all, thanks for sharing your work......
But, I do have a question though.... Is this project post really in the spirit of Instructables? Fair enough you share your work here, but to get detailed plans from your website, one has to pay $5 to be able to download them!? Would it not be fair to assume that they are made available here as a PDF download like many other (free) projects? Is this not just another way to make money, or am I just too used to getting free stuff on Instructables?
Just asking you know?
zeroaxezeroaxe
Reply 3 years ago
Just an addition to me previous comment.... By searching the net for "Flip top tool stand" this instructable comes up
https://www.instructables.com/id/COPYRIGHT-FREE-RE-...
Now I would rather say(without sounding rude) that this one refered to here, is much better to follow. Although it is not a PDF document to download, it just seems more logical to follow this structable instead?
Thanks
bones65
3 years ago
Great ible! I've been thinking of making something like this for years! I also took notice of your tool cubbies on the wall.
One question: As the sides are only a plywood sheet thick, is there any side-to-side racking?
Jules13
3 years ago
I made one very similar and have now added the draw. Thanks
CraftAndu
3 years ago
Very clever, good job!
wb8nbs
3 years ago
I made a flipper a few years ago. https://www.youtube.com/watch?v=EuHTNlTYvWs The only issue I have with this design is lateral rigidity of the frame. I put quite a bit of bracing on mine to make sure it was stable with the approximatly 160 pounds of tool bolted on.
Robbin1
3 years ago
nice job, I built mine about 5 years ago, but kept the drawer off so a taller planner could be put on. Great ideas Shop Notes have for tool benches! One idea I came across in a Shop Notes reply to this build is a triangular flip top for smaller items such as grinders, key cutters and sharpeners! I plan to build one soon for my sharpeners, as I have three of different types for different tools. Great job on your build! Any thought on a stain or paint?
wb8nbsRobbin1
Reply 3 years ago
I believe Craftsman sold a triangular table at one time. I've never seen one though.
cbracher
3 years ago
Do the two items needs to be relatively similar in weight or does it matter?
fixthisbuildthatcbracher
Reply 3 years ago
Not really. It just makes it easier to spin when they are similar weights. But I've seen people just go a 70lb planer on one side and nothing on the other. Just gotta control it when you flip it.
