Floating Game/DVD Shelf
29,343
386
11
Around a few years ago, a buddy of mine saw a article on the internet on how to make a floating game shelf. He showed me a picture of it and asked me to make one for him. This is what I came up with.
Supplies:
Step 1: Materials
Here is what you need:
An DVD or video game case
Scissors, X-Acto, or Dremel
Phillips screwdriver (or another type, depends on the screw you are using)
L- Brackets (Size does not truly matter as long as it fits in the case and is wide enough to balance the case)
Wall Anchors
Screws compatible with your anchors
Power Drill
Step 2: Carve the Case
Cut a small hole on the side of the case that snaps shut. MAKE SURE it is not on the binding/folding side. Be sure to make the hole large enough to fit the bracket within. You could add two brackets for added stability. (I did not but it would greatly add to the ease of use)
Step 3: Drill the Wall
This is fairly self explanatory, just drill into you're wall. I did not even drill into studs. These shelves are fairly low weight so I did not see a need for a stud. These have been hanging on the wall for years now with no sagging.  Now you insert the wall anchors.
Step 4: Screw on the Brackets
Yet another self-explanatory step, just screw in the the brackets to the anchors.
Step 5: Finish
Now put your games or DVD's on top of the others. I would put more than one supported case per stack as it can ease the weight on the brackets.
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    11 Discussions
    blackholeseeker
    3 years ago
    Maybe you should add sidebars of some kind so when you want a game thats under another game you can pull it out without making a huge mess.
    Qwkredfox
    4 years ago on Introduction
    This would be great to surprise my brother with. :) Love it.
    lhsk8r
    6 years ago
    Grammar nazi alert a DVD or video game case
    lhsk8r
    6 years ago
    Y not just put 2 L brackets up and games on top because then you'll have to double case a game
    dhenry4
    6 years ago
    I was wondering something about the case. If you cut a small hole in the side of the case that snaps closed, isn't there a chance that the case might pop open? I was worried about this and thought to ask before I built this.
    ZaqqChrisE123
    Reply 6 years ago on Introduction
    Haha, I was so tired when I wrote this. Thanks for pointing it out.
