Floppy Disk Bag
332,559
390
187
This is a bag I made from floppy disks. I found scads of floppy disks in a dumpster and wanted to make plate mail armor out of it (that is my next floppy project) I found out that a bag would be a great proof of concept project. Here goes...
Check out the update (2008) and my new bag: Floppy Disk Bag: Install Disk 2
Step 1: Required Bits
Drill, hand, regular or trephine
1/8" drill bit
Pliers, I used bulldog pliers
Floppy disks (CRUCIAL)
Links, bits of chain from your local bead store
Nails and a plank o' wood
A pen
Elementary math skills Eg: the ability to count
NOT PICTURED
The hardware for adding a strap
the strap
Step 2: The Matrix
This is the matrix for my bag, feel free to make your own. Also, try to get other colors and incoperate a pattern (I just love the classic beige, black, and blue.)
Step 3: Drill and Link, Horizontal Linking
The horizontal is the most easy to drill because it has premarked holes. for one all you have to do is unlock the disk. Then drill a hole in the divots already in place. Insert the links and squeeze shut
Step 4: Vertical Linking
use your judgment as to where to place the upper and lower holes, just remember that there will be a weak link because there is a weak part of the disk,
Step 5: Consider Making a Template
This will help you drill accurate holes in every disk (you shant need to drill all the holes for the disks that wont be attached on all sides keep this in mind
Step 6: The Edges
How to attatch the edges. Notice that the top holes for the disk on the left are not the same as the top holes for the disk on the right (the same is true for the bottom holes) this is because I measured and eyeballed and found out where those holes will need to be so I can fasten the peices together when I fold it up depending on how you set up the bag these could be side holes or whatever... use your best judgement.
Step 7: Begin Work in the Third Dimension
Begin folding and linking at the corners when every last link in the matrix is complete
Step 8: Almost...
Here is the bag fully formed
Step 9: Because I Had No Tiny Rubber Mac Feet...
Keys make good feet for the bag, trim out the inside and glue them on
Step 10: Attachments
these are what will hold the straps to your bag, these are held on with nuts and bolts. you can find all the strapcessories at your local camping, military surplus or other man-store
Step 11: The Other Side of the Strap
This side wil be held on by looping it through the metal dealie and securing it to itself with a metal ladder to enable adjustment of the strap
Step 12: Power to You, and Other Notes
Upon initial usage of this bag I got three offers to buy one and also realized that it needed some kind of interior reinforcement to make it able to bear weight easily. I suggest sealing the inside with duct or packing tape to keep problems from arising.Enjoy this newfound skill.
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    187 Discussions
    SarahW22
    3 years ago on Introduction
    Great idea....but had to raise an eyebrow at the term "man-store"...good to see sexism is alive and kicking, always just below the surface...
    barnabyjSarahW22
    Reply 3 years ago
    You are being offended for the sake of being offended.
    Viaticus
    7 years ago on Introduction
    Very cool use of floppies. Are those YOUR painted toenails?
    dagelias
    really cool bag! I want to make one out of old CD`s how do you think that will work? ideas on how to do it anyone??
    jwarren3
    7 years ago on Step 12
    Wow! This is really cool :D A question- where did you get your white floppy discs from?? I'm planning on making a multicoloured bag, with black and white also, but I can't find any white ones :/
    reto1jwarren3
    Hi there,
    I have ca. 50 new floppy disks I don't know how to get rid of. I can send them to you for free if you can cover the postage and if you are still interested of course.
    shaawn
    8 years ago on Step 12
    Very nice! You can just put a sleeve into the bag, a lining of some kind. That would keep things from falling through the joins. You can use different materials for different functions, colours, textures. eg: a plastic bag insert - for sweaty sports- wear or frozen foods. Different colours - to match occasions, a padded liner for a laptop...
    imanalchemistshaawn
    Reply 8 years ago on Step 12
    take a look at the next installment of floppy disk bags, it comes canvas lined for just that reason.
    imanalchemistshaawn
    https://www.instructables.com/id/Floppy-Disk-Bag-Install-Disk-2/
    ^there
    zack247
    8 years ago on Introduction
    i think i found a new laptop bag...
    Very creative way to reuse useless floppy disks! i'll be keeping my eye out for floppy disks the next time i go out now, they definitely make better bags than coasters!
    dwendell
    A thought. The stainless steel jump rings seem like they could add up to an substantial total given the quantity you need ( four per disk). Fishing and support ing goods stores (e. g. Bass Pro Shops, Gander Mountain, Sports Authority, Dick's etc.) have small "split rings" (like those used for keys) which are used for fishing tackle.
    They usually sell in paks of 5 or 10 for a little more than what one jump ring seems to cost. If true stainless steel is not available, some fishing ones are labeled as "English stainless" which is actually some kind of plating on either steel or brass, but seems to resist corrosion fairly well. It seems like these would be easy to install as compared to having to bend open and then bend closed the split rings, as long as you buy relatively thin split rings. If opening the split rings is difficult for you (as for me, having lost some feeling in my finger tips as I get old and decrepit), you will find very near the split rings in the sporting goods store a tool called a "split ring pliers" (for about $10). The pliers make opening them simple.
    pleasesmile
    11 years ago on Step 3
    a couple of quick questions!!! Where exactly did you find these "links?" ALSO, could you PLEASE put up how to put on the strap?! I'm planning on making one for Christmas, and I would love to see how you did it! Thanks!
    janettetsmithpleasesmile
    Reply 8 years ago on Step 3
    I make jewelry and we call them 'jump rings'. You can buy them online in a variety of metals from gold and sterling (I would reserve these two for my couture version of the bag) to base metals. The base metal ones are very inexpensive and they are already made for you. :)
    Here's a couple:
    copper
    http://www.gossamerwingsdesigns.com/Jump-Rings-Chain-Maille-7-copper-jump-ring.htm
    stainless steel
    http://www.firemountaingems.com/details.asp?PN=H209247FD
    janettetsmithjanettetsmith
    Also ... open the rings from side to side instead of top to bottom to keep from weakening them.
