Flying Captain America Shield
525,389
544
329
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
This is a flying Captain America shield that you can make out of duct tape and cardboard. Make a couple of these and you can battle it out with your friends Captain America-style!
I had two goals in mind with this project: 1) that the finished shield could be tossed around safely and actually fly stable like a giant Frisbee, and 2) that it could be replicated by almost anyone, independent of their current crafting skills.
For this project I made a couple of different flying shield prototypes. After some experimenting, I eventually reached a design that flew really well . . . and now I'm excited to share it!
I've included a PDF with all the pattern pieces that are required to make this. I worked directly from these finalized pattern pieces to build the finished version of the flying Captain America shield you will see in the following steps and in the video below.
The finished shield is 22.5" in diameter, and weighs 27.5 ounces (780 g). It's hefty, but it flies great. Still, you wouldn't want to knock a little kid in the back of the head with it, but it's certainly a lot safer for throwing around than this version (also made by me).
Here is a video of me throwing my shield roughly a quarter-mile, by my estimate:
And here's a great video of the build process, made by another youtuber!
I was honored to find this. Check it out:
Step 1: Things You Will Need
Here is what you will need to make your own Flying Captain America Shield:
  • Print-out of the attached PDF
  • Flat pieces of cardboard, at least 12" wide across the grain. I used thick double-ply cardboard.
  • Duct tape, one roll of each: red, white, blue, and regular
  • 24" of webbing or other suitable material for handles
  • 74" of 3/4" polypropylene rope
  • Cutting mat (I have a couple--I got a new double-side Alvin brand one, which is very nice)
  • Utility knife with extra blades (and/or heavy-duty hobby knife with extra blades)
  • Hot glue gun
  • Sharp scissors
  • Marking pen, like a Sharpie
In each step I will go into more detail about the materials and tools used.
Step 2: Cut Out Pattern Pieces
Begin by printing out the attached PDF from step one. It will be easier to use the pattern pieces if you print this on a heavier paper like card stock.
Carefully cut out each of the pattern pieces using either a sharp blade or scissors. Use tape to join the two sections that form the larger wedge-shaped piece, as shown in the photo.
Step 3: Cut Out Cardboard Wedges
The shield is made up of 20 individual cardboard wedges that are curled slightly, hot glued together, and then covered with duct tape.
The large wedge-shaped pattern piece labeled "SHIELD" is used to create all the individual sections of cardboard that go together to make the shield.
Trace this pattern piece onto cardboard 20 times, being sure the grain (or lines) of the cardboard run across the narrow width of each wedge-shape.
Use a utility knife with a new, sharp blade to carefully cut out all of these pieces. A sharp blade and cutting mat are a necessity for this step.
Work slowly, be careful, and watch your fingers.
Step 4: Gently Curl Each Shield Piece
For the shield to end up in a slight dome, you will need to gently curl each wedge-shaped piece.
Use both hands to pull each piece over the sharp edge of a table, which will "break" the stiffness of the cardboard. Your curled pieces should be similar in shape to the ones shown in the first photo.
Step 5: Tack Together Quarter-sections of the Shield
Use hot glue to tack the shield pieces together. You don't need to use a ton of glue, as you will be adding plenty of tape later on which will solidify and strengthen the shield.
I recommend beginning by assembling quarter-sections of the shield. This will make it easier to keep things lined up and ensure that the completed shield comes out round. (If you add one piece after the other all the way around the shield, the pieces tend to drift or "creep," and you may not end up exactly where you started.)
Each quarter-section will have five pieces in it. Begin by gluing two pieces together, and then adding the third, fourth and fifth. You don't need to glue the full length of the seam between each two pieces--just the top and bottom couple of inches will do. The most important thing is that the outer edges of the pieces (which will be the outer perimeter of the shield) are lined up evenly.
You will need to gently adjust the curve of each of the pieces so they mate up nicely with each other. There will be small gaps, especially on the top portions of the shield, but this is okay.
Step 6: Join the Quarter-sections
Once you have all four quarter-sections completed, you are ready to assemble the final dome-shape. You may notice that the four sections are not quite 90 degrees, as you might have thought they would be. Don't worry, this is correct and everything will fit together nicely.
Begin by joining two sets of quarter-sections so you have two completed halves.
Now join both halves. This may take an extra set of hands to hold them together while the hot glue cools, since the two halves will naturally want to pull apart. This is where the dome takes it's final shape, as you force these two halves together.
You should now have a "naked" Captain America shield. You're half-way there!
You'll be tempted to take it outside and try to throw it. Don't do it. Resist the urge!
Step 7: Reinforce Backside of Shield
Use strips of regular duct tape to reinforce the seams between the glued sections on the backside of the shield. Make sure you press down firmly so the tape sticks well.
Step 8: The Secret to Making It Fly...
A length of suitably heavy rope needs to be added to the underside perimeter of the shield, which is the trick to making it stable enough to fly like a Frisbee. It also provides a nice lip for looks, as well as a place to grip for throwing or catching.
You will need about 74" of 3/4" polypropylene rope, which can be purchased by the foot at most hardware stores.
To keep the rope from fraying when you trim it to length, wrap a few inches of tape around the cut ends. You could use a lighter or torch to fuse the ends as well, but it will all be covered with tape soon enough, so it's probably not worth the effort.
Use hot glue to firmly glue the rope down along the underside edge of the shield.
Step 9: Cover the Edge With Red Duct Tape
Use 6- or 7-inch strips of red duct tape to tape over the rope and edge of the shield. Try to keep the tape as tight up to the rope as possible so there aren't any big air pockets along the inside lip of the shield.
Note that for all pieces of duct tape that you use from here on, you will want to cut them off of the rolls rather than tear them off. This will help keep things clean and neat. This is where a sharp pair of scissors comes in very handy.
Step 10: Cover Backside of Shield
Cover the backside of the shield with strips of regular duct tape.
Try to be as efficient in covering as you can in order to keep the weight down, but make sure every bit of cardboard is covered.
Step 11: Attach Handles
You have some options here.
I had some 1 1/2" webbing that I salvaged off of an old gym bag which worked very well as handles for my shield. If you have some 3/4" webbing, that would work equally well. You could also just as easily fashion some handles out of a few layers of duct tape.
Whatever you choose, cut two strips of your material about 12" each (add a little more if you have bulky forearms). Hot glue the ends down, positioning the handles similarly to what is shown in this photo, and reinforce all around with more duct tape.
Step 12: Cover Top of Shield
Cut strips of red duct tape and cover the top of the shield. Try to keep everything as smooth and wrinkle-free as possible.
Step 13: Add Center Blue Circle
The pattern piece labeled "CENTER CIRCLE" is used to draw out the shapes that will be used to make the center blue circle on the shield.
Lay out three 24" strips of blue duct tape, overlapping each piece about 1/4", similar to what is shown in the second photo. (I initially only laid out enough blue tape to draw out 6 pattern pieces, so I had to do this part twice.)
Trace the pattern piece 12 times onto the blue tape, and use a sharp hobby knife or utility knife to cut out the wedge-shapes. When you pull them up off the cutting mat, be sure to pull them up starting with the layer of tape that is on the bottom. This way the separate pieces of tape that make up each wedge will all stay in place.
You should be able to see where the exact center of the shield is, based on where the cardboard wedges meet. If you can't see this through the layers of tape, squish the tape down with your fingers to feel where the center of the shield is. Make a mark or poke a small hole with a pin if you need to, to use as guide to help you place the blue wedge-shapes in the center of the shield.
Step 14: Add White Ring
The white ring is made from white duct tape, and is completed in similar fashion to the center blue circle.
Trace the pattern piece labeled "WHITE CIRCLE" 8 or 9 times onto two strips of white duct tape, as shown in the second photo.
For placement of the white ring on the shield, I just eyeballed it. The goal is to have three rings of equal width (red, white, red). If it looks funny or crooked, you can always pull it up and re-do it.
A more precise method would be to use a ruler or measuring tape to place a few marks around the shield from the center point to aid in the placement of the white ring. The inside edge of the white ring should be placed about 7 1/8" (181 mm) from the center point of the shield. (Thanks to Iron-Man227 for this tip!)
Step 15: Add Center Star
The center star is completed similar to the method used in the last two steps, using the pattern piece labeled "STAR" to draw out the five sections that make up the star.
When the shield is held level on the left arm, the star should be pointing up. Place all the star pieces accordingly.
Step 16: Clean Up the Shield, and You're Done!
A little bit of denatured alcohol on a rag will quickly clean off any marker lines left over from tracing your pattern pieces, and will leave your shield looking slick and shiny.
That's it. You're done!
It may take some practice to be able to throw it well--if you have a hard time throwing a Frisbee, you may struggle with this. Practice with a regular Frisbee if you need to, and work your way up to your awesome homemade Captain America shield. Remember to whip your wrist as you release the shield, to give it plenty of spin.
I'd love to see some photos of your finished shield if you make one. Just upload a photo or two and post them with a comment.
Thanks for checking this out.
Launch It! Challenge
Runner Up in the
Halloween Props Challenge
Finalist in the
Make It Move Challenge
Second Prize in the
52 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
329 Discussions
King_Juan
3 months ago
It's too bad Cap. America doesn't even have a shield anymore.... :(
snorlaxprime
6 months ago
Thanks for a the good instructions. I use it as the base to make a Wonder Woman shield for my daughter.
Holt207
11 months ago
I think this is wonderful. But I made one when I was younger using this but I lost it. Do you happen to know the dimensions of this because I would really like to take this idea and bring it to a metal shield.
meowmac
2 years ago
Um. I confused on how you drew on the duck tape and removed it from your table without ruining the duck tape. Can you explain it for me?
AryanB13meowmac
Reply 1 year ago
I glued a circle chart paper and painted it. red , blue.
seamstermeowmac
Reply 2 years ago
Hi, that's a good question!
To pull the tape off of the cutting mat, I would use the tip of my hobby knife turned sideways to gently slide under a corner of the tape to lift it up. You can then gently pull the whole piece up.
Coty9
1 year ago
can you plz tell me the measurements because I can't print out the temples
seamsterCoty9
Reply 1 year ago
I'm not sure what the measurements are, unfortunately. All the various pieces were created by hand through trial and error, and it would be impossible to transmit it through written measurements - hence, the pdf template which is printable.
RobynB6
2 years ago
I would like to make a tiny one for my 19 month old for his Halloween costume.. any suggestions for doing that?
seamsterRobynB6
Reply 2 years ago
I think you could actually just print the pattern at a smaller scale (from your print options window when you print stuff).
Then all the steps will be the same once you've got a smaller scale pattern printed. Good luck! :)
seamster
2 years ago
I think I did it from edges inward, concentrically.
mark40shotgunseamster
Reply 2 years ago
thanks. It's coming along nicely, will post picture when finished.
mark40shotgun
2 years ago
Gonna use for a school project (More cost effective than steel diy alternative). I don't suppose there are 1:1 scale templates (30" diameter), are there?
seamstermark40shotgun
Reply 2 years ago
No, but you could certainly scale them up, in a variety of ways (either with photo editing, just printing the pattern at a bigger scale, or even by printing the template and using a copier to scale it up. A little trial and error is all that's needed, I'd say.)
Just shoot for the wedge pieces to be about 15.5 inches long, and that should get you very close to 30" total diameter when you're done.
OmT6
2 years ago
Can i use fevibond (rubber based adhesive ) instead of hot glue
