Food-drivers (How to Make Upcycled Place Settings Made With Screwdrivers Handles) by Samuel Bernier
22,189
305
38
There is weird a phenomenon happening in my kitchen drawer. Somehow, every single item from my flatware is different from the next. I have to say that I don't remember ever buying a table set. Forks, spoons and knives were given to me by family members or friends after moving out of my parents’ place years ago. Many of these utensils probably come from the high school cafeteria where I used to borrow them to eat my lunch and would forget to bring back. I would like, for once, to own one of these nice table sets that you use when mom and dad come for diner.
I also own an incredible amount of screw drivers. I have to say that I love buying tools. The problem is that I also bought two multi-bit screwdrivers, two electric drills and a Dremel... I don't need my old tools anymore. Also, since they were bad quality, the Philips head all got stripped and I only use the flat ones to open paint cans.
Here's how to merge two problems into one cool solution.
Step 1: You Will Need
Acrylic handle screwdrivers
- An old table set
- A metal saw
- A heat gun
- A clamp
Step 2: Heat
The first step is to heat the metal part of the screwdriver. Make sure the air doesn't get on the plastic handle because it will melt like ice. It should take about 30 seconds on full power.
Step 3: Pull
Squeeze the metal part in a clamp and pull on the handle using gloves. My little sister could do it.
This is actually the same process as the manufactured one... but a bit more manual.
Step 4: Repeat
Repeat step 1 and 2 for all unwanted tools.
Step 5: Mark
Use a Sharpie marker to indicate where you'll have to cut the flatware.
Step 6: Cut
You can use a steel cutters, a metal saw, a buffer, a band saw... or whatever you have that can cut steel.
Step 7: Grind
Sand down the excess steel. The flatware handle should be about 2 mm larger than the hole in the acrylic handle.
Step 8: Heat
Use a heat gun or put the flatware in the oven at 300 degrees (no microwave...duh).  It should take about 1 minute with the heat gun. Use glove because it's HOT.  Be careful not to leave it for too long because the flatware might turn brown and get stained by impurities.
Step 9: Insert
While still hot, insert the flatware in the proper handle. Don't breathe the fumes of the acrylic melting or you'll have a big headache. Let everything cool and harden for 30 minutes.
Step 10: Fill the Holes
I used SUGRU to fill the holes left in the handle. Sugru is a kind of silicone paste that hardens in a few hours to leave you the time to do a clean job. It also comes in different colors. If you are experimented with epoxy, this would also do a great finish.
Step 11: Enjoy
Congratulations, you've just made your own handyman place setting. Remember that acrylic won't survive to the dishwasher. It's better to wash these utensils manually.
Holiday Gifts Challenge
First Prize in the
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
38 Discussions
juanbill
3 years ago
I will make a set of those.....great idea!!!!
ValerieAnneM
3 years ago
This is awesome! Toolware?
Doing
3 years ago
Super idea for a going out on his own gift.
JamesW33
3 years ago
I once saw someone call these "chew-drivers".
projectsugru
4 years ago on Introduction
How have we only just found this project!?? This is such an awesome idea!! Just brilliant
this is a fantasmagorious idea.
if only i had a heat gun i'd be doing this right now
super fun and whimsical. gonna share with the readers on my blog - we love repurposed and recycled.
Michael @ Blue Velvet Chair
DidymusB
7 years ago on Step 4
what did you do with the old screwdriver heads? I think they could be used for some stuff similar to some of the work of Mrballeng if you want to look him up. Would hammering on the old heads make them flatten or shatter?
EdRotheDidymusB
Screwdrivers are made of hardened steel; I doubt if you could flatten them much without first annealing the steel. Instead, I would recommend grinding the edge to make it into a small chisel, punch, icepick or such.
black holeEdRothe
I made a great bo shuriken out of an old screwdriver. It's super hard; several times I have thrown it point-first into a concrete wall without damage to the tip.
PS: Love your idea.
EdRothe
Great project!! I'm making a full set of these as a birthday gift to someone with a whimsical sense of humor. He will love 'em.
Maxaxle
7 years ago on Step 11
Note to self: make these when you get your own place.
Kyro Cordeux
This is brilliant, I would be proud to give a set of these a home in my cutlery drawer and I would giggle every time I reach for a spoon. Love it.
fredellarby
7 years ago on Step 2
NOW THAT'S A HEAT GUN.
Handy if the furnace gives out.
Treknology
Depending on the brand of handle you are re-using, it could add a whole new meaning to "Stanley" knife.
Mr Rancher
What are the specs on your heat gun?
I do not have one and if in the future I purchase one, I'd like to be able to accomplish stuff like this if the mood strikes me.
I just don't wanna buy a Mini Cooper when I should have got a Toyota FJ Cruiser, ya know?
agis68
personally i would never eat from my ex screw driver. But if you promise me that all these (spoons and forks) are pretty clear and new then i will try them on my carbonara spaggeti
