Four T Puzzle
12,621
66
11
About: I like to design and build random things.
The goal of the puzzle is to fit the four T shaped blocks into the box, with the pieces flat. The box itself has two sides so there are two versions to fit the pieces. The first side has a larger area so it is pretty easy to fit all the pieces into the space. This side of the box has multiple solutions. Next, you flip the box over and the sides are thicker, giving you less area to place the T pieces. Notice that the previous solutions don't fit anymore. The actual solution requires a unique pattern for the T pieces to work.
I understand the inventor of this puzzle is Peter Haject and multiple versions (wood and plastic) with different shapes/sizes are spread across the web. I felt like this version was pretty easy to make but if you are not up to it, feel to purchase a similar version from online.
This video shows the solution. Skip it and don't go past Step 10 if you want to try to figure it out on your own.
Supplies:
Step 1: Tools/Materials
Tools:
  • Table Saw
  • Router / Table
  • Ruler or Calipers
  • Pencil
  • Sander
  • Wood clamps
Materials:
  • Wood: 1.5" x 24" x 1/2" thick
  • Wood: 3.5" x 3.5" x 5/16" thick
  • Wood glue
  • Paint/Stain (optional)
Step 2: T Build
Start by cutting a strip of wood to 1/2" x 1/2" x 24" long. You don't need 24" but the extra length allows for a few extra Ts which is a good thing if you are known to mess up like me.
Step 3: T Parts
You will need 4 of each of these pieces. Hold off on the rounds for now.
Step 4: T Assembly
I glued the Ts together. For centering, I used a few of the extra parts (shorter pieces). Again, you might want to hold off on rounding the edges until the final fit check.
Step 5: Box Floor
I used a table saw for all straight cuts.
Step 6: Box Sides
Cut a 1/2" thick board down 1.5" wide. I used a router to cut the rabbet joint.
Step 7: Box Sides
Similar to the other sides except more passes on the router.
Step 8: Ready for Assembly
Step 9: Glue
I used wood glue and clamps to secure the sides and floor. Break sharp edges and clean up with sanding.
Step 10: Can You Figure It Out?
With the dimensions shown for the T (Step 4) and the dimensions shown here, can you figure out a layout that works?
Step 11: Cover (optional)
This part is optional. I didn't make it but it helps with storage.
Step 12: Puzzle Patterns
Ok, here is the solution. The first picture shows one example of how to fit the Ts into the larger box. The second picture shows the optimized placement for the smaller box. You might have noticed that the parts still don't fit into the dimensions shown in Step 10. The key is shown in the next step.
Step 13: Ts in Box
As you can see in the first pictures, the Ts easy fit into the box. I modeled a 1/16" gap on all sides for this layout. For the second version, rotation is the the key to making the pattern fit into the box. Also, rounded corners on the Ts help if your dimensions are a little off.
Step 14: Puzzle Inside Cover
This picture shows the optional cover.
Step 15: Final Pictures - Puzzle 1
For contrast, I used Danish oil on the box and black cherry stain for the T blocks.
Step 16: Final Pictures - Puzzle 2
Here is the complete puzzle showing the second solution. Thanks for viewing!
Step 17: Update
More advanced version added. See Here.
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    11 Discussions
    jkmorgan9
    Question 1 year ago on Step 10
    I am trying to make this. The larger box is way too big for the T’s. Maybe the decimals are throwing me off, I like fractions ;). Should the inner diameter be 3.125 instead of 3.375? Or 3 1/8 vs the 3 3/8? Let me know. Thanks
    mtairymdjkmorgan9
    Answer 1 year ago
    You might be reading it wrong. It's not a diameter in Step 10. Those are the X & Y dimensions.
    jkmorgan9jkmorgan9
    Answer 1 year ago
    Ok Thanks. I guess from the video the larger side has a 1/16 inch gap around per instructions, but the instructions say the diameter is 3.375. I guess my other question is am I reading the the diameter wrong for the larger side? Anyway your project looks cool and thanks for the video and detailed instruction. I plan on making the Z too.
    mtairymdjkmorgan9
    Answer 1 year ago
    Correct. The larger side (3.375" x 3.375") is too large for the Ts. It's almost too easy to solve (5 year old level). The other side is the challenge (2.875"). Feel free to reduce the large box down to something slightly larger than 3.125". Note that dimensions shown in step 12 show that solution at 3.127".
    If you have already built to the dimensions, I suggest going to the more advance version shown in step 13. This version makes good use of the 3.375" side.
    Hobbytik
    1 year ago
    Hello,
    The inventor is Dr. Peter Hajek, born in the Czech Republic and for a long time working as doctor in London. Good to know!
    jmacuk
    Question 1 year ago on Introduction
    I'm trying to add this to one of my collections but don't see an option to do so. Is there some restriction on this instructable?
    1 answer
    mtairymdjmacuk
    Answer 1 year ago
    Thanks. No restrictions but i think the new website rollout made it harder to find. Scroll down a little. You will see icons appear on the top right of the screen. Click on the 3 dots. Next, click "add to collection". Yep, it's intuitive :).
    mrwonton
    1 year ago
    Cool, very (T)ricky
