Frederic Chopin-Board
3,867
41
11
About: I make musical instruments the modern way, with a CNC. check out my video content on https://www.youtube.com/user/TwoCherriesIns
I was asked to make a 10" x 24" end grain cutting board about a year ago, I came up with the idea to engrave music notation on it at some point and naturally a cutting board or "Chopin board" would have Frederic Chopin engraved in it. I happen to like the Waltz in C# minor OPA 64 so that's what I used, and this is how id made it.
Step 1: The Plan
I decided that the staff would be integrated into the board so I knew I was going to have to make a pretty precise plan to make sure the engraving would overly it properly. I designed at the end grain and staff veneers in fusion 360.I fist removed all of the staff lines form the sheet music image I found, then I converted it to SVG and imported the SVG into fusion. I could then resize the SVG to the size of my cutting board and layout all of the lines and spaces that would become end grain and layers of veneer.
Step 2: The Lumber/Glue Up
I chose some walnut and maple that had been sitting around in my shop for a wile and began cutting up pasts to create the end grain components. the two side pieces where easy, but the end grain parts the would be between the staff veneers would have to be very accurate so I made them all oversized and milled them to there final dimensions on the CNC.
Each of the layers that would fit between the veneer staff lines would have to be cut and glued up, and milled to final thickness before gluing together with all the veneers in one big glue up. I didn't get any video of this glue up, it was a big mess as I had to work very quickly so the glue didn't prematurely set with this many layers. there where 5 end grain blocks and 4 sets of 9 veneers (5 walnut and 4 maple). Once they had dried I leveled on side on the CNC and used the joiner to flatten both sided to glue on the end blocks.
Step 3: Milling Flat
Once the board was all together I could mill both sideds flat on the CNC and then to final dimension on the drum sander. then I cut the profile on the CNC and cut the engraving with a V bit.
Step 4: Filling in the Engraving
I then filled the engraved lines with CA glue and sanded flat again. I cut the round over with a hand router and finished it up with some coconut oil, and once that had soaked in I applied a mix of coconut oil and bees wax I call Board Butter.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    11 Discussions
    craftyv
    5 months ago on Step 4
    This is such a clever idea and could be developed to have any music, such as: The music from a wedding, a favourite from a movie or any music with significance. Brilliant.
    Alex in NZ
    5 months ago
    This is a truly dreadful pun. Thank you!
    As a question, you said that you "filled the engraved lines with CA glue". I'm thinking that the narrow engravings would be susceptible to damage from knife blades, so could you expand that a bit?
    Thank you for sharing such a beautiful piece :-)
    Alpha_geekAlex in NZ
    Reply 5 months ago
    Yes, the pun is truly dreadful, but it struck a chord with me. Generally I'd prefer a minim-al design, however I'm sure the owner has used it to stave off some hunger pangs, because I can get pretty crotchety if I don't eat regularly ...
    Kink JarfoldAlex in NZ
    Reply 5 months ago
    All Right, Alex, here's one for you Since Chopin had a busy, active and creative mind this Instructable would make Chopin Bored.
    bassman76jazzAlex in NZ
    Reply 5 months ago
    It's possible, only time will tell. The main intent for this was for a serving tray for charcuterie, but I was at a loss for a good charcuterie pun...
    klixtopher
    5 months ago
    This is awesome! I see you used coconut oil and bees wax. Have you used this before? I like the idea but am concerned that the coconut oil might go rancid. I guess the next logical project is a wood fired Beeth-oven.
    bassman76jazzklixtopher
    Reply 5 months ago
    Yes, I'll get right on the beath-oven...
    I haven't had any issues with coconut oil spoiling, I have found it to be better than mineral oil and I've been using it for a couple of years without any problems.
    Kink Jarfold
    Loved it! Very creative. I, however, wouldn't use it for a cutting board. I'd hang it on the wall as art--then, of course, the clever name for it would be lost. Marvelous work. --Kink--
