"Free" DvD to IPod
11,921
52
58
In this instructable i will teach you how to convert any DVD movie or movie on to your ipod for 100% FREE OF CHARGE
Step 1: What You Need
THE FOLLOWING ARE THE 2 PROGRAMS YOU WILL NEED TO COMPLETE THE PROCESS:
- DVD Decrypter ~ http://www.mrbass.org/dvdrip/ Once at this site click on "SetupDVDDecrypter_3.5.4.0.exe" to download. Download it and install.
- Videora iPod Converter ~ http://www.videora.com/en-us/Converter/iPod/download.php
NOTE: Videora iPod Converter V 0.91 is the preffered version to use but not to worry the newer versions should work fine. . .
ATTENTION : DO NOT WORRY ABOUT DOWNLOADING THE PROGRAMS THEY ARE TRUSTED SOFTWARE.
Step 2: Start
Put the DVD you want to convert into your DVD-ROM drive and start DVD Decrypter. The disc should eventually be
recognized and you should get a screen like the one below.
Notice DVD Decrypter automatically picks the longest
program which is usually the movie(NOTE: if it does not select the longest file please select the longest just to make shure you get the whole movie).
If you don't have enough free space at the Default destination, you can change the destination by clicking the little yellow folder icon and choosing a new destination.
Step 3: IFO Mode
Make sure you are in IFO mode by pressing "i" or checking under the Mode menu.
Step 4: Stream Processing
Go to the Stream Processing tab and select Enable Stream Processing.
Note: You might have other video and audio options on your DVD. This screen is where you pick which audio and video
track you want. Usually the default is a good choice but if you end up with the wrong video or audio channel (such as the
director's commentary or a foreign language) experiment with other selections in this window.
Step 5: No File Splitting
We need to make sure we end up with one big file containing the entire movie. Go to Tools -> Settings and click on the
IFO Mode tab. Set "Flie Splitting" to none and hit OK.
Step 6: Let It Rip
Click the "DVD to Hard Drive" Rip button and wait for it to finish. When you are done you will hopefully have one big file
ending in ".VOB" wherever "Destination" is set. (above the rip button)
Keep in mind, ripping is fairly hard on DVD drives. If your rip seems to get stuck, try using another computer with a newer
DVD drive. Also, scratched or dirty DVDs don't rip well and also cause the DVD drive to constantly re-read parts of the
disk wearing the drive out. Be aware of that as you rip. Newer drives and perfect DVDs make great rips.
Step 7: ALMOST THERE JUST ONE MORE THING BEFORE YOU START CONVERTING
In this DEMO i will be using an older version of VIDEORA, if you have the newest version it is ok and more user friendly, it comes with instructions and step by step help!
BELOW ARE THE IMAGES OF THE NEW AND OLD VERSIONS
Step 8: Run Videora IPod Converter
RUN THE CONVERTER
Step 9: Convert
Click the Convert tab on the left.
Step 10: Transcode New Video
Click Transcode New Video and find the big VOB file DVD Decrypter created for you. (Hint: look for it in a place like
"C:\DVD_NAME_HERE\VIDEO_TS\VTS_01_01.VOB")
Step 11: Output Videos To...
Click the Setup tab on the left and define where you want the finished product to end up.
Step 12: Quality Profile
Give your video a Title and pick the Quality Profile MPEG-4/320x240/768kbps Stereo/128kbps. (others will work as well,
experiment to find the best choice) Then click Start to begin encoding.
Step 13: Then Wait
Once the movie file is done converting import it into itunes and ENJOY!
IF YOU HAVE ANY QUESTIONS ABOUT ANYTHING WITH THE NEW OR EVEN OLD VERSION OF VIDEORA PLEASE LET ME KNOW AND I WILL HELP YOU ! !
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    58 Discussions
    switchzzp
    3 years ago
    The program was out dated and no longer work for the latest dvd movies. I suggest to have a try on iMoresoft Video Converter Ultimate. It converts your DVDs for personal use to any video format that suits your portable device. Or, vice versa, burn your favorite homemade videos into personalized DVDs and enjoy them on the big screen!
    Step by Step Tutorial: How to Legally Rip Protected DVDs
    RedFlash
    8 years ago on Step 5
    You don't have to tell it to output it to one file. You can rip the files individually and then (of all things) join them together in command line Using this command: copy /b "a.vob" + "b.vob" "c.vob" You can also do it with more than two files.
    finleym50
    9 years ago on Introduction
    Unbiased reviews and side-by-side comparisons ofiPod ConverterSuite gives you enough information to research the ins and outs of a particular product, It can help you decide which iPod Converter Suite is the best to meet your needs.
    Ian+Siobhan
    10 years ago on Introduction
    Okay, so I've been stuck @ 99% for over an hour now...it was speedy to get to the 99% (maybe 30 min tops) but I'm starting to get the feeling it's not gonna hit 100%. I raised the CPU usage to above normal for 1/2 hour in hopes that would help it finish up..but alas it was all for nothing. So I brought it down to just below normal...time elapsed: 1 hr, 52 min...any thoughts? I know how these progs can get hung up, ive been using dvd decrypter and dvd shrink for a few years but this is just nuts.
    rickickIan+Siobhan
    this had happened to me also, it depends on what kind of DVD you are converting this will normal happen with home made DVD'S or recorded DVD'S (the use of a DVD recorder attached to your television recording shows etc.) The bottom line is do not worry about it if all works in the end. This has happened to me as I have made many home videos, all that I do is leave my computer ON overnight and when I get back in the morning my movies are done. This is a great way to get those movies done so your not waiting around for hours!!! May I also suggest if you do this that you Queue other movies if you have more than one and it may go quicker and you will have more movies finished. Another thing is that the amount of time that your Movie takes to convert Depends on how high you put the quality of the sound and video. HINT: after your done check the "Shutdown after Conversion Is Complete" box to prevent hassles. RICKICK,
    wxyzturickick
    i pressed that button and after i re-logged in to my computer and couldn't find the video in my ipod. it was 4mb and i made the quality things all the way. how do you find it ?? thnxs
    rickickwxyztu
    were you outputting it directly to your ipod? because that would be wrong, you are supossed to save the file to a folder on the desktop! in in your documents!
    singju
    I always use Tipard DVD to iPod Converter. It is really excellent with super fast conversion speed and with lossless of quality of your video and audio for you to enjoy your DVD on iPod anywhere and any time.
    For more informaion please come to: http://www.tipard.com/dvd-to-ipod-converter.html
    It is easy to operate. Just few clicks are OK. Here is the specific guide for you to follow: http://www.tipard.com/how-to-put-dvd-movies-on-ipod.html
    Hope it helpful for you.
    Luuke
    looks complicated...but worth the time :) will it work with rented DVD's? blockbuster or w/e...
