French Cleat Workshop Organization
66,580
811
39
I've always found keeping my tools easily accessible and visible to be a challenge. When I moved into my new workshop, I looked for a flexible, inexpensive, and easy-to-build solution that would grow with me. I chose to build a system based on French cleats. French cleats let me mix specialized tool holders, pegboard, and cabinets - all on the same strong, easy-to-make wall mounts.
French cleats are a remarkably simple mounting system that use gravity and friction to hold things in place. In the pictures above, you can see a simple shelf I built as an example of how this works. The 45 degree angle facing away from the wall allows the tool holders and shelves to push down and out against it, securely holding heavy loads while still allowing easy adjustments and placement. To put a tool in place, you simply lower it down onto a cleat so that its cleat hooks onto the one mounted to your wall.
To build this cleat system you will need:
  • A saw that can cut long boards at 45 degrees. You can accomplish this with a table saw or a circular saw.
  • A drill
  • A drill bit smaller than your screws
  • A screwdriver (a powered driver is really helpful!)
  • Material for cleats - I used oak 1x4 boards for hanging tools, but 3/4 inch plywood or most other 3/4 inch or thicker wood works well too.
  • A level
  • A pencil for marking
  • A tape measure
  • A stud sensor to locate studs to mount your cleats to
  • Screws long enough to mount your cleats to studs or another strong mounting material.
Note: If you're mounting through drywall, you need to account for the 1/2 inch thick drywall in addition to your cleat material, so you'll probably want screws that are 2.5 inches long or longer.
I also used a few other tools that can make this easier:
  • A laser line level
  • A chalk line
  • A combination square
  • A battery powered impact driver
  • A 45 degree square
  • A countersink bit for my drill
None of these last six tools are absolutely necessary, but they can make the job easier or provide more accuracy.
Supplies:
Step 1: Cutting Cleats
French cleats are easy to make: you simply cut a board lengthwise at a 45 degree angle, leaving enough space to screw each half to the wall or to a hanger or other mount. To cut my cleats, I set my table saw up at a 45 degree angle, marked the boards at their midpoint, lined up the blade so half was on either side of the mark, and ripped 1x4 boards lengthwise.
A few tricks can really help you out:
  • You may have to remove the guard from your saw to make a 45 degree cut (and your saw may tilt left instead of right like mine does) - be careful when you're operating it, and always use a pusher block instead of getting your hands near the blade. A helper is really useful.
  • Cut a scrap piece of lumber that is the same width as the boards you'll be cutting for the actual cleats first to make sure you're making an even cut. You can be a little off, but with a 1x4 you'll want to be pretty close to the middle.
  • Getting a perfect 45 degree cut isn't absolutely necessary - just make sure that you are consistent on which half you use for the wall side and the hanger side if you want them to fit perfectly.
  • If you're using wider material you can decide how big your cleat should be, then simply use the first cut piece to mark the next one for a 90 degree vertical cut if you want them to match.
  • Remember to cut some extras so you have cleats to use to hang things from your new cleat system!
I wanted cleats well above the top of my workbenches and tool carts which meant starting above waist height. That meant that I needed to cut enough strips to allow me to put four cleats spaced one foot apart vertically above that on my workshop wall.
Safety note: to avoid kickback, make sure your blade is set to just above the height of the material you're cutting, and consider using a featherboard on the side of the board between the fence and the blade. I did so when doing most of my cuts, but removed the featherboard to make these shots clearer.
Step 2: Sand and Prep Your Cleats
Your cleats will have a sharp edge, so spend a few minutes with some sandpaper or a sanding block to prevent splinters and cuts later on. As you can see, my sanding block saved my fingers from some nasty splinters!
A few minutes now can make the installation process a lot more comfortable, and can prevent problems later on. This is also a great time to stain your cleats if you want to - you'll see that I did to create some contrast in my bright white shop.
Step 3: Lay Out Your Cleat Setup
Your cleats should be placed so that you can comfortably reach tools that you hang from them. For me, that meant starting just above waist height and placing four rows of cleats 12 inches apart. If you want tighter or wider spacing, feel free to adjust how you place your cleats, bearing in mind the size and type of tools and cabinets you may want to hang.
I used a laser level to give me a nice straight line along my wall, and then snapped a chalk line to have an easy reference. If you don't have a laser level or a chalk line, you can simply measure up from the floor or down from the ceiling (look for the surface with less variance - my basement shop has a real drop in the concrete floor!). The key with measured markings is to make sure you level the first cleat, then keep each level after that equally spaced and level as well.
Step 4: Locate Studs and Prepare Your First Cleat
It's important to have something solid to mount your cleats to, so you'll want to locate your studs. Using a stud sensor, you can usually find them quite easily.
Note: Remember that most US construction places studs 16 inches on center (or, in other words, every stud's center should be 16 inches away from the previous stud's center). Once you find the first stud, you can mark 16 inches away for each successive one - just make sure to verify using your stud sensor!
Once you have your studs marked, you're ready to transfer those measurements to your cleat for the screws that will hold it to the wall. You can be off by a bit, but you want the screws to be close to the center of the stud so they provide solid support. You can see that I measured both horizontally and vertically (using a combination square) on my cleats to make sure I drilled my screw holes with enough wood to support the cleat. Make sure to take advantage of every stud that you can for more strength - my six foot long boards ended up with four screws holding them up.
Since my cleats would have tools hanging right against them and they're made of oak which won't let the screw sink into it, I chose to countersink the holes for my screws. You can skip that step if you don't mind a slightly protruding screw or you are using plywood for your cleats, but you will probably want to pre-drill the holes to prevent splitting the cleats.
Step 5: Mount Your Cleat to the Wall
Hold your cleat up along the marks you made on the wall in step 3, and then place a level along the top. Screw one end in using a screw long enough to hold solidly through the surface. Since I'm mounting mine over drywall, I chose 2 3/4 inch heavy duty deck screws to make sure I can hold up heavy tools.
Once one end is in, you can move to the other end. Ensure the cleat is still level - it's ok to move slightly from your line, as you'll use this cleat as your base for the rest, and being level counts for more than following the line. With the board level, screw in the other end.
Continue through the rest of the screws you marked out. You've got your first cleat up!
Step 6: Mount Additional Cleats
To make mounting more cleats easy, simply cut two boards to the same length as the space you want between your cleats.
Note: If you cut the end of your spacer blocks at a 45 degree angle, they'll take advantage of the cleat's design to stay in place, but you'll have to allow for the length of the 45 degree cut in your measurements. To do this, just cut the 45 degree bevel first, then make your measurement from the "low" end of the angle. Hold onto your spacers once you're done since they'll help you put cleats onto heavy cabinets which need support from multiple cleats in the future.
It's easy to transfer your measurements from the first cleat to the second: just place a straight edge long enough to reach from the first cleat to the second over the middle of each screw and transfer your mark up. A level will ensure you're staying on track, but this is safe to eyeball too.
Now repeat the pre-drilling and mounting process you used for the prior cleat. Remember to use your level - a little difference from cleat to cleat is acceptable, so don't worry about perfection.
Repeat this process for each cleat you want to mount. Once you're done, your rail system is ready to hold things!
Step 7: Build Tool Holders and Mounts
Once you have cleats on your walls you can build tool holders, mount cabinets or shelves, or hang any of a multitude of tough to store workshop or household items on your cleats. I've included pictures of some of the tool holders I built for my shop here to get you started.
Here are a few tricks that I found useful:
  • Use small angled blocks to provide additional support. The three jig saws you see in the pictures above were too heavy for an unsupported shelf, so I added simple 45 degree spacers that keep it stable.
  • Be careful when designing shelves or mounts for heavy objects. If you have a deeper shelf or a heavier object, you may need to lower the shelf below the cleat to take advantage of how the cleats work (force is directed downwards and out). See RuudvandeLooij's comment below for an illustration of how to do this.
  • Light but tall tool holders may only need one cleat - my handsaw rack has a cleat just below its top edge, and rests against the lower cleat.
  • Heavy cabinets should get multiple cleats - to properly space them, just re-use the blocks you used to space the original cleats on the wall.
  • Tough to mount tools like the plate joiner in the pictures make take some thought. My first design efforts weren't very safe, and I had to re-design the rotating clips to hold it more securely to keep my toes safe!
  • Building many smaller cleat mounts allows you to move things around easily. I've used the flexibility of the cleat system to adapt my storage to how I'm working, and I can move tools for projects to be closer together for easy access.
  • Small magnets like those used a the top of the handsaw holder can help hold tools in place. If you don't have magnets, a simple tie or bungee cord can also work.
  • Use small scraps to create a lip around shelves to prevent items from falling off.
  • When mounting pegboard, it helps to build a narrow frame behind the pegboard. This keeps the cleats from blocking pegboard holes and makes the pegboard itself less flimsy.
As you work with your french cleat system you'll probably find yourself coming up with more and more ideas - it's a great way to re-purpose shop scrap into useful storage.
Shelving Contest
Third Prize in the
Shelving Contest
  • IoT Challenge
    IoT Challenge
  • Woodworking Contest
    Woodworking Contest
39 Discussions
BarryT52
Tip 4 months ago
I’d suggest always hang edged tools with the working edge inwards. However careful we think we are, it pays to be cautious and safety conscious.
lsymms
12 months ago
super cool. Be careful with magnets as the metal on metal will create a galvanic connection and promote rust. Best to use coated magnets or cover them with an insulator.
kevin_culp
1 year ago
Excellent tutorial! Thank you for writing this. Combined with several videos on YouTube (including April’s), this gave me some great ideas for building my tool wall and holders.
I have found that more often than not I need to extend the holder below the wall-mounted cleat and add a spacer to keep the holder and tool (or shelf or bin) from rotating forward and falling to the floor. Of course, lowering the center of gravity or using extended braces below the holder help tremendously, too.
One suggestion for storing heavy tools vertically, such as a circular saw: use a toggle clamp to secure the top edge of the tool. This holds it in place really well. A couple of dollars spent on the toggle clamp is money well spent, IMHO. See the photos of my circular saw holder for an example.
6DA0767D-FB6A-44CF-98FF-74AFFB3A7190.jpegC92484E4-8B5B-4F0D-A78D-BB900DF1D6C6.jpeg9C4F8E73-14D1-46A3-BBCC-B51A43FEDF9A.jpeg
yellowcatt
1 year ago
I have always known this as 'split batten
hanger'. When I was moving house I made some stacking crates out of OSB
board.
When I was adding strips of wood to the bottom of the crates as locators so the crates would
stack easily without sliding off each other I realised that if I made them as French Cleats/Split
Battens then I could hang the crates on the workshop wall as cupboards.
Maybe I should take some photos and write it up as an Instructable.
jpmarth
1 year ago
This has inspired me! A fan of having a shelf system that allows me to rearrange as needed.
DavidS80Elmwood upcycles
Reply 2 years ago
Thanks! I'm continuing to really enjoy the system, and have slowly expanded it around more than half of my workshop. I finally have a way to get all of my long clamps up on cleat-based racks now, which makes them far more accessible.
jimrittenour
2 years ago
I'll try my best to describe what a friend of mine did to deal with some of these sub-topic issues.
He cut the angles on both the top AND bottom of the cleats. Then he simply cut lengths of wood with corresponding cuts to act as sliders between the rows of cleats. With this he could move these sliders to positions where the need for maintaining the space from the wall to the shelf/jig...... was desired. Seemed handy to me.
ruudcreates
3 years ago
I've a question/remark on the second image, the simple shelf. At the moment I'm thinking about making a tool board for myself in the near future and the French cleat system is one of two design i'm thinking about. So I've read my part about them and what to do and what not. But when I look at the shelf I'm afraid it's not very secure and will tip very easily with a little weight on it. I think it would be much better to lower the shelf and obtain a much more stable shelf or other tool holder.
But furthermore well written and good to read, so voted for you.
JC41ruudcreates
Reply 2 years ago
Great sub-discussion. Just to weigh in on the different approaches (lowering the mass vs adding a brace): Lowering the mass seems the best way to deal with heavy objects like cabinets, since you can mount at an arbitrary height. For objects that don't allow for positioning of the cleat (like a simple shelf), lowering the mass means you have to add in a vertical member which moves the shelf away from the wall, taking up more space. So in that case, the brace approach is a good one. Both great ideas -- thanks!
DavidS80JC41
Reply 2 years ago
JC41 - I agree with your assessment. I've also been surprised at how strong even a direct mount without lowering is. The relatively heavy circular saw mount that I was a bit worried about has been extremely stable.
My heaviest items still get mounted to multiple cleats.
My most recent addition is a 4 foot long cleat mounted vertical powerstrip - it attaches to multiple cleats, and lets me have more outlets easily available when I'm working. Multiple cleats mean that it doesn't pull away from the wall when I pull a cord out.
fmei62ruudcreates
Reply 3 years ago
I Agree that you are thinking with logic is more stable. Thanks for the idea
DavidS80ruudcreates
Reply 3 years ago
RuudvandeLooij - You're correct, you'll get a more stable shelf if it is lower. The small shelf shown in the image is sufficiently strong to hold things like bottles of glue, tape measures, and other smaller, lighter items. If you put heavy items on a deep shelf, you're absolutely right, physics will not work in your favor.
I've done two things when placing heavier items on cleats: I either use a taller design, or I add simple braces. My circular saw shelf uses braces and is quite stable. My longer saw holders for both my handsaws and my reciprocating saws work as you show.
DavidS80DavidS80
Reply 3 years ago
As a follow-up - I've added a note about this in the final step, and I referenced your diagram. Thanks for including it!
ruudcreatesDavidS80
Reply 3 years ago
No problem. I always like when people make constructive comments on my Instructables so I like to do it where I can. And it was a good test for my Paint - Photoshop combo skills.
fraser02
3 years ago
thats awesome, great organisation!
very inspirational... i need to redo my workshop!
joshdont
3 years ago
Beautiful photos, nice instruction, and wonderful implementation! Kudos for rocking an 826 Michigan shirt!
DavidS80joshdont
Reply 3 years ago
Thank you - I'm tickled someone noticed the shirt, I figured it might be a fun way to give them a little extra exposure.
fmei62DavidS80
Reply 3 years ago
Thank you VM David80 for sharing and congratulations for your works!. i'm in the way to make one of this.
