DIY Full Color Mixing 3D Printer
25,591
144
16
About: I make things, and I sometimes attend classes at Columbia University - but primarily - I make things ~ especially from scratch... Please don't mind the currently perceived dearth of designs on my page, I ver...
This Instructables is going to be a work in progress... It's not going to be completed yet, but I wanted to get it started now and I'll work on it over the next couple of weeks to make it a comprehensive Instructable...
Here's a video I made explaining the set-up and how it all works. I'll make a better set of videos that detail everything individually in the near future, but this video should work for now.
Video
So if you are interested in the project - like it, favorite it, save it, then check back in a couple weeks and it should be done...
I did all of this on a Rostock Max that I completely redesigned and rebuilt to utilize the diamond hotend and full color mixing with the new Repetier firmware... I built mine around a delta, however, I want to make this Instructables as universal as possible so you can set it up on any machine you'd like... But I'll mostly be covering deltas because that is what I have/use... But a basic Cartesian FDM printer should be no problem also. (It's actually easier, deltas can be tricky)
__________________________________________________________
Sites to follow
Here are my pages/profiles that I'll be referring to a lot... So follow me on them and you'll get updates as I post them
My Thingiverse
My YouTube Channel
If you would like to connect with me on a professional level here's my Linkedin. (I'm always open to new connections, gotta get to that 500+ connection status, LOL)
My Linkedin
Here's what I plan to cover in this comprehensive Instructable
1) Getting the controller board ready for three extruders... I hacked a Rambo board to drive three extruders, however, you can use any board you want... (most people use a rumba due to it having all the pins/components needed for 3 extruders native on the board)
2) Rewriting Repetier firmware to get color mixing working on your machine.
3) How to install, configure, and use the diamond hotend - tips / tricks / lessons learned / etc...
4) My original bowden extruder design and various ways to mount the three extruders for your set-up
5) My universal magnetic effector plate and accompanying hotend mounts for quickly swapping various hotends. (delta specific)
6) How to design multi-color models and making STLs that can be exported and used as a individual STLs or combining them into an AMF file for slicing...
7) Configuring color mixing in Repetier and Slic3r to print above mentioned multi-color models.
8) Anything else I can think of later that I can't think of now.
9) Comprehensive overview of Quantum Mechanical Entanglement as it pertains to multi-color printing (just kidding, I don't understand that shit... But I will cover multi-color printing throughly)
Step 1: Getting Everything in Order
Step 2: The Diamond Hotend
Step 3: Configuring Firmware
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    16 Discussions
    OmarM173
    8 months ago
    now i am done with extruder and firmware except steps/mm for extruders but what to do know with slicer to print colored 3d models like in photos ?
    KIKI23
    Tip 9 months ago on Introduction
    Were the tootorial ? I by pro download pdf but its nothing
    Frosttoys
    2 years ago
    Its been quite a while since this was updated. Is this project still in the works or has it been abandoned? Just really curious about how you did the mixing with solid filament and seemingly no process to get the filaments to mix together so their pigments would mesh and create the new color.
    dintid
    2 years ago
    You know you can save as draft and then publish it all when you are done?
    Reprap.me, the maker of the Original Diamond Hotend, are working on a 5way Diamond Hotend now. Just to answer @Tengo10
    Heatsinks not being properly prepared on this photo, but the Diamond tip is :)
    Tengo10
    3 years ago
    pretty amazing.
    I like how you put all the hot ends into one. I only saw them in a separated setup. Is this possible with 5 for a full colored printer or is this to much to rewrite the code?
    JJPowellyTengo10
    Reply 3 years ago
    You can do 5... It's just a lot going on... But wouldn't be difficult... I plan on doing a 5 lead one in the future which will give me white and black... Then I'll truly have full color
    Tengo10JJPowelly
    Reply 3 years ago
    I'm going to buy my self a prusa i3, from sunhoky I think. I think I will try your idea after I completely understand how everything is working and I'm getting great quality prints... could take some time but yeah, everyone need a hobby.
    bschranTengo10
    Reply 2 years ago
    im with you :D
    i got a prusia i3 on its way gonna get that running smooth and this will be one of my later mods... this is awesomeness incarnate and will be cheaper then the full cymk(w) one that is out there currently.
    thormjJJPowelly
    Reply 3 years ago
    Make it 6, and you can have an alpha channel.
    Franco PonticelliJJPowelly
    Reply 3 years ago
    Isn't the CMYK color space the one you need to get a full spectrum? That would require 4 leads. Traditional printers use more colors for additional accuracy but 4 looks like the bare minimum.
    JJPowellyFranco Ponticelli
    Reply 3 years ago
    CMYK - Cyan, Magenta, Yellow, Black - is what works on paper printers... But that only works because it utilizes the white of the paper with the mixing... On a 3d printer, you don't have that so you will need a white feed.
    thepalsrus
    2 years ago
    Do you have a link to the diamond hotend mount you used in your video? You said that you were planning on putting it on thingiverse?
    crita
    2 years ago
    That is awesome!
    I came across a printer at geeetech.com, this printer 301, mix with 3 colors, i was wondering if it can also print full color
    http://www.geeetech.com/geeetech-rostock-301-mix-color-3d-printer-p-1008.html
    GraemeK2
    3 years ago
    This is awe-inspiring Jason! You mentioned in your colour mixing video that the people who designed the diamond hotend are considering doing a 5 in 1 hotend? Where did you hear this? I can't find any sources about it online. Also if they don't happen to produce a new nozzle have you considered adding flux capacitors to the three inputs on the diamond to double the amount of filaments you are allowed? it's a project these italian makers are working on http://www.thingiverse.com/thing:301982. You could add PVA in the sixth channel so you can make some awesome prints that require no clean up. I was also wondering what your opinion is on using this setup once black and white are added as a method to do full colour figurines of 3d scanned people. I'm worried that the transitions colours required to do small details like eyes or lips would waste a ton of filament. The other concern would be the difficulty of getting a slicer to read a .fbx or .ply file and then convert it into ratios of how much each extruder needs to push out filament to meet that colour profile.
    BuildAThing
    3 years ago
    JJPowelly,
    I am amazed with amount of work you have done with your printers and personal designs! I have a Pursa I3 that I am going to convert the print head to a remote drive like your delta. Could you share the stepper motor drive assembly that you made. I have a MK8 direct drive style extruder and I want to convert it to run a Bowden tube like you did with your drives. I am a little new yet to printing so I hope the above made sense.
    I have found your Thingverse account and I really like all of your night lights too!
    Good work,
    Mark
