GARAGE STORAGE SOLUTION
57,417
359
40
CEILING TOOL STORAGE, USING HINGED PANELS AND PULLY TO SECURE TOOLS OUT OF THE WAY IN CEILING.
Supplies:
Step 1: Step 1
Used 1/2" ply panel to form racking, hinged to ceiling set off from wall about 4inches ,this allows further storage behind and prevents board hitting wall.I used piano hinges for strength and they also help prevent warping and twisting of panels.
Step 2: Step 2
Used nylon reinforced cord , from a boating shop as it has high breaking strain.This is threaded up to small pulleys, again from boat suppliers,mounted in ceilind timbers, I needed two but will depend on roof structure.The cord travels down thru self locking boat cleats , not sure if thats the correct name.
The cord can then be used to raise or lower panels, I lift mine to ceiling as it's fairly low but can be done purely with cord if needed.
Step 3: Step 3
The panels can then be set out to accomodate your tools, simple screws hold a variety of tools but I also used some metal clips, from the garage roof tiles I had left over, to mount tool boxes, also small shallow box formed from ply at base of each panel for odds and ends.
Step 4: Finally
The previous pic shows a heavy tool rack which is strenghthened with timber along the edges to prevent it sagging when lifted to ceiling, only found this required when very heavy tools stored.Also used old cutlery rack from dishwasher to store smaller tools.
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    40 Discussions
    Starsword7
    3 years ago
    Great idea!
    If you had the hing a foot or two from the wall you could have shelves behind it, so this would provide additional storage (maybe for less used items)
    ChristopherJames
    3 years ago
    Now if this were me and my garage, I would forget that I'd have things in storage in the ceiling after a while! Better to have things in plain sight where I won't forget that I've put them!
    EricColbert
    4 years ago on Introduction
    For my storage shed, I maximize space by fully utilizing the walls. I build racks, shelves, and closed cabinetry to store all my items neat and tidily. I do not create any storage using the ceiling space because I have always thought it will not be as sturdy and durable enough to withstand much weight, and especially tools that I have in my garage. However, this pull-out hinged panels idea is still worth a try.
    MarkSindone
    6 years ago on Introduction
    The ceiling storage is a really smart idea and it saves a lot of storage space too! We have always thought the ceiling is a wasted area that is left un-utilized, but it is just not possible to fix shelvings or cabinets on it. Thus, we have fully (or over) utilized our walls so far. But I am a little afraid when it comes to hinges though because they mighy just come tumbling down should the load is heavier than they could hold. I guess I need to seek professional help on that.
    Narlo11
    This is awesome. The amount of tools I have is staggering and take up so much space. This is bar none of of the best storage ideas I have ever seen.
    Blacksedan47
    7 years ago on Introduction
    very nice, the Murphy Bed moved to the shop. i will definately use this for the goodies i dont use as much great idea
    reddnekk
    8 years ago on Introduction
    I am always pleased to find new ideas and suggestions for use in my two-car shop. My wife wants to know when she can put her Ford marquis under cover; I am still teaching her that the ClearCoat paint is intended to take the place of a garage.
    So all you fellows with ideas for making a two-car shop more efficient and friendly, please--Keep IT UP!!
    You know, this really is so much more than storage space... it would be a great kind of home security for your garage tools too. In our neighborhood, we have a lot of problem with people breaking into sheds, outbuildings and garages. This system would make it that much more difficult for would be thieves to make off with your tools. Great instructable. :) Thanks for sharing.
    chefguru
    A better idea to REALLY make it a space-saving work-space for a small garage would be to have the work bench surface hinged to the wall so that it could be folded up (or down) and out of the way to give you an almost flat wall.  You could just fold the bench surface down, and support with the legs at the corners, and you're ready to go.
    If you designed a bench to fold up, and still had the tool racks spaced 4 inches out from the wall, then you could access your tools with the bench folded up against the wall in case you only needed a tool, but didn't need the whole bench.
    I have a 2 car garage, but if I actually want to park 2 cars in it (or 1 car, and my 3 motorcycles), then I don't really have room for a work bench.  However, this might be a really good idea for having the option of actually having a work bench that I would be able to use with hiding tool storage.
    Thanks, good idea.
    IdahoDavid
    12 years ago
    Good idea. BTW the other day I heard about a guy who is actually able to park is car in his garage. What a crazy concept.
    caarnteddIdahoDavid
    What the...? No way! My garage will hold four cars plus my motorcycle and tools. (when it's empty)
    At the moment the only form of transport inside is my motorcycle. there may also be a skateboard in one of the piles.
    xcoastieIdahoDavid
    Reply 11 years ago on Introduction
    My wife has the same silly idea, so I am the one getting up early to scrape ice and warm up her car to protect my valuable man-cave from her car.
    leevonk
    12 years ago
    how does that save space? the tools on the wall stick out about 3 inches.. Maybe if you have a multilayered system where you could pully-down different sets of tools over each other.
    jeffeb3leevonk
    I agree.  If I made something like this picture, I would just leave it down all the time.  Maybe you could space it away from the wall by 4", and then just put pegboard on the wall.  You could get twice the storage with something like this.
    radiorentalleevonk
    Reply 12 years ago
    good point, however I can see this beeing useful to secure your tools if you have kids or sticky fingered neighbours
    neorazz
    im thinking ...good idea heres how i might improve it
    (when i do this i'll post my instructable )
    hinging look at attic retractable stair hinges
    ease of use  needs spring system to help with retracting
    latching  twist handle in center of panel with offset pull rods that would lock panel in place and act as hinge pins  if these were on both ends the panel could open front or back of work area if items on panel were mounted appropriately
    or just reverse the hinge so the panel would open up  behind the walking area of your work area  then its never in the way of  your project
